RE: Tomahawk-Design Bae Hawk 1: 3.5    Gallery
Logged in as Guest
Users viewing this topic: dos007
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Tomahawk-Design Bae Hawk 1: 3.5
Page: <<   < prev  22 23 [24] 25 26 27 28 29 30 31   next >   >>
Login
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/5/2012 8:11 PM
Carsten Groen
Score: 100
Last Login: 5/21/2013
Status: offline
Wow, thats nice !!
My friend here also has the THawk F5, currently building on it.
Very nice plane, and looooong
_____________________________
Carsten Groen
Hide Signatures
(in reply to jetpilot)
       Post #: 576
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/7/2012 8:51 AM
helicrazy06
Score: 100
Last Login: 5/20/2013
Status: offline
Hello everybody , i need your advise for the electronic hawk , i command the hawk from tomahawk and i will pick up it at the jetpower show , wich electronic do i need to buy for it ,with servos for exemple do you use on yours ? what is the best configuration?
Many Thanks
Nicolas
www.helicrazy.com
Hide Signatures
(in reply to Carsten Groen)
       Post #: 577
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/7/2012 10:37 AM
schroedm
Score: 103
Last Login: 5/22/2013
Status: offline
There's no "best" setup but here's my setup which would take some beating..........
2 x 8911 on elev
1 x 8911 on rudder
2 x 8911 on flaps
2 x 8411 on ailerons
2 x DES707 on main gear doors
1 x DES707 on nose steering
Powerbox Cockpit SRS
Powerbox iGyro
2 x Double action Jetronic Valves (one for mains, one for nose leg)
1 x Jetronic zero loss brake valve
Rgds,
Mark
Hide Signatures
(in reply to helicrazy06)
       Post #: 578
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/7/2012 11:06 AM
David Gladwin
Score: 110
Status: offline
..........and an even better one, I think, that which is going into my Skygate Hawk :
Ailerons JR MP80T brushless.
Stabs JR 6311 HV,
Flaps JR 6301
All controlled from a Weatronics 12-22 gyro 111 plus GPS which allows extreme accuracy in set up and full system analysis. !!
Plus an Intairco integrated Dual gear valve with speed regulators plus my own design emergency gear extension system (see next RCJI) giving you a second chance to get the gear down in the event of an air leak (ala MacD Phantom and BAC Jet Provost !)
That said, I am sure the PB Cockpit or competition plus an iGyro ( a rather more capable gyro system than the Wea gyros which are also very good) is also a really excellent set up, currently evaluating just such a system in a Reaction.
Regards,
David.
Hide Signatures
(in reply to schroedm)
       Post #: 579
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/7/2012 8:00 PM
jetpilot
Score: 110
Status: offline
Not sure what a des707 is but the main doors need a strong servo.
Scott
Scott C. Marr
Hide Signatures
(in reply to David Gladwin)
       Post #: 580
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/8/2012 9:19 AM
helicrazy06
Score: 100
Status: offline
thanks guys for the info , have a good flights with your hawk
Hide Signatures
       Post #: 581
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/8/2012 9:34 AM
tobba
Score: 100
Status: offline
Guys here's a shot of Thomas' spring upgrade and adjuster.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 582
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/8/2012 4:25 PM
jetpilot
Score: 110
Status: offline
Cool!
Scott C. Marr
Hide Signatures
(in reply to tobba)
       Post #: 583
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 5:21 PM
Carsten Groen
Score: 100
Status: offline
So, my Hawk has just been painted by my friend Kasper Holger (CarbonsCustoms here on RCU).
He did a wonderful job, although I have not seen it in real life yet, but should get my hands on it in less than a week.
He sent some pics of the plane during the process, hope you like it (paint masks etc etc from Ralle/Tailormadedecals)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Carsten Groen
Hide Signatures
       Post #: 584
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 5:23 PM
Carsten Groen
Score: 100
Status: offline
The last few (and Kasper posing with the plane )
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Carsten Groen
Hide Signatures
       Post #: 585
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 6:16 PM
bcovish
Score: 1018
Status: offline
Beautiful. But the more I see them fly, the more I want one. I've got a lot of wants now especially since I've been haulin' Scott's stuff around.
Bob-O
Austin TX
Hide Signatures
       Post #: 586
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 6:33 PM
jetpilot
Score: 110
Status: offline
Gorgeous!!
Scott C. Marr
Hide Signatures
(in reply to bcovish)
       Post #: 587
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 6:54 PM
Carsten Groen
Score: 100
Status: offline
Thanks Guys
I'm really looking forward to get it in the air, probably with shaking legs
Any "last minute" recommandations regarding CG, throws, and maybe elevator compensation with the two flap positions ?
Also, the new spring update to the main oleos, do you just removed the spring in there, and substitute with the new stuff or (got mine a few days back, and havn't looked at it in detail yet...) ?
Carsten Groen
Hide Signatures
       Post #: 588
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 7:12 PM
F86_SABRE
Score: 100
Status: offline
Congrats Carsten....nice plane and nice job well done!
Reuben
Hide Signatures
       Post #: 589
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 7:45 PM
jetpilot
Score: 110
Status: offline
Hey Carsten,
I fly mine on high rate elevator and aileron with a lot of throw. I use low rate on rudder as it is very effective. . I will get you my throw.
If you can't hold nose in the air after touchdown until you stop then starting pushing weight back.
I can't for the life of me remember if I have any elevator trim mixed with flaps. I will check when i get home in a few hrs. I don't think I do though.
The new spring stuff looks like a complete replacement for the old. It looks like an adjuster and some springs. I think the thing to do would to be to pull out old stuff and replace with new and make ready the jet full of fuel. Then simulate compression manually and see if it bottoms out to the strut cover. If so then dismantle and extend the adjuster out necessary length. Also the jet shouldnt sag in back when just sitting. Watching the video of factory hawk 100 is a good example of what its not suppossed to look like. That was even with smaller motor.
I don't have mine yet but it looks like the adjuster goes in then the springs on top. Basically what I have done to mine using the dowel stop.
I follow up when I get home.
Scott
Scott C. Marr
Hide Signatures
(in reply to F86_SABRE)
       Post #: 590
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 8:38 PM
Carbon-Customs
Score: 105
Status: offline
what Mister Green is saying, is that hees HOPING to get his hawk back this thursday, but im not sure i will give it back, afterall it is totally fitted, and my TX matches his, so its just to fuel it and fly - i even stole his model setup from the TX and copied to my own when he wassent looking... [:p]
A little something about the Thawk hawk...
i think its a pitty that the rivets is so tiny on the surface on the model, after the clearcoat they are almost gone. I know the rivets are perfect scale (as everything else on the model) but the paint thickness is not 1/3,5, i think the details should have been a bit exaggeratedl like on a skymaster model and so on.
but this is the only thing. this bird is really the lamborghini of RC jets, everything is just SO good quality.
Im proud of the model, and that Carsten trusted me his Hawk, afterall if i did a terrible job, then the model would be wrecked, because, if it should need a new paintjob, it would gain an extra 1kg of paint (and go over 25kg) and loose all of the surface details because of the sanding.
And i so not want to be the person to wreck a 10000€ kit ;-)
i look forward to make the next kickass jet, the Thawk F5
Kasper H
JetCat P300RX 1:5,5 F-16 - Better to have too much power and not need it, than need it and not have it
Hide Signatures
       Post #: 591
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 8:42 PM
bcovish
Score: 1018
Status: offline
Just curious, what is the estimated weight ready to fly less fuel
Bob-O
Austin TX
Hide Signatures
(in reply to Carbon-Customs)
       Post #: 592
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 8:44 PM
Carbon-Customs
Score: 105
Status: offline
you can make it under 20
Kasper H
Hide Signatures
       Post #: 593
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 8:52 PM
bcovish
Score: 1018
Status: offline
Wow, that's 44 pounds, that's lite.
Bob-O
Austin TX
Hide Signatures
       Post #: 594
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/24/2012 8:55 PM
Carbon-Customs
Score: 105
Status: offline
its unreal when you lift the elevator
most of the spars in the model is made of 8mm think herex with 49g cloth on both sides, its VERY light and stronger than the light plywood normally used.
Kasper H
Hide Signatures
       Post #: 595
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/25/2012 3:28 AM
jetpilot
Score: 110
Status: offline
My elevator throws about 6cm up and down from center. Ill check ailerons next.
No mix trim on elevator when flaps deployed at either setting.
I still cant believe how fast you finished yours!
best of luck!
Scott
Scott C. Marr
Hide Signatures
       Post #: 596
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/25/2012 3:51 AM
FenderBean
Score: 119
Status: offline
is there a website for this kit or the company that makes it? Love the size and detail
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 597
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/25/2012 4:01 AM
bcovish
Score: 1018
Status: offline
quote:
ORIGINAL: FenderBean
http://tomahawk-design.com/
Bob-O
Austin TX
Hide Signatures
(in reply to FenderBean)
       Post #: 598
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/25/2012 7:14 AM
marc s
Score: 110
Status: offline
Looks superb Carsten, and great job on the paint Kasper
Happy to have been 'involved' in this project if only by supplying a few small parts here and there. I wish you a successful maiden and many, many enjoyable flights..................
marcs
Hide Signatures
       Post #: 599
RE: Tomahawk-Design Bae Hawk 1: 3.5 - 7/25/2012 10:15 AM
Carsten Groen
Score: 100
Status: offline
@Kasper:
You know I will always trust you my planes , but you will have to surrender the Hawk to me in a few days
@Scott,
all inputs are more than welcome
(the 6cm throw on elevator, is that measured at leading or trailing edge ?)
I assume that neutral is when the trailing edge is on the dividing line of the elevator cover ?
I have put the CG in the middle of the two numbers given by Tomahawk on the CD (between 310 and 325 mm), hope that will be ok...
It took more or less exactlly two months to finish it for painting, and yes, I have been quite busy with it, but if this thread hadn't existed, or if I had not had all the super help from you guys, it would not have been possible (at all!). So a big thank you all
The last week before Kasper got the plane for painting, he was staying here at my house for 4 days, and he helped A LOT (50 hours or so) to make the canopy/cockpit, which was a lot of work, and some things had to be figured out along the build. Luckily Kasper is a real pro builder (as well as a super painter and pilot), so I did get a lot of help with that!
@MarcS: It's your small gadgets that puts the extra touch on the install, all these little things that you perhaps could do without, but using them makes it soooo much more nice and easy !!
Carsten Groen
Hide Signatures
(in reply to marc s)
       Post #: 600
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
