RE: Fly Eagle F-18 1:6    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Fly Eagle F-18 1:6
Page: <<   < prev  1 [2]
Login
RE: Fly Eagle F-18 1:6 - 1/7/2010 5:11 AM
Peter A
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: jetnuno
Hi Raul
Nice pics and nice work.
If you look carefully to pic nº2, the rudder movement will not be ok if you don't put ball links on the rudder shaft side. The pin from the sullivan type link shall neve be aligned with the rudder horn. FEJ used to send aluminium with ball brass links to allow this movement.
Keep us posted.
Regards
Nuno
Actually that is not true I am using the same system, the Alum horm on the rudder rod is not 90 degrees to the rudder axle, it is angled (or twisted) to match the line of push pull system on the servo side. It actually works very well.
Hide Signatures
(in reply to jetnuno)
       Post #: 26
RE: Fly Eagle F-18 1:6 - 1/7/2010 6:28 AM
jet time
Score: 120
Last Login: 5/21/2013
Status: offline
I got mine and put it together for the AMA show this weekend. They just keep getting better and better! This thing is unreal right out of the box! I will post some shots from the show. I have the armament on it and it is big. Everything is a perfect fit and finish.
I also have the F-4 that is pictured on the web in the German drone. It even has a speed brake behind the mains (with the sevo installed already!) that after all these years I didn't know existed. The fit and finish is EXCELLENT! And for all of you that are concerned, the gear work fantastic and the pipe is impresive. Another couple of winners!!
Lowell
_____________________________
Lowell Wexler
RC Jets Direct, Fly Eagle, Global Jet Club, Jet Cat
Hide Signatures
(in reply to Peter A)
       Post #: 27
RE: Fly Eagle F-18 1:6 - 1/7/2010 8:49 PM
jetnuno
Score: 105
Status: online
Ok. You're right..
Looking carefully at the pic, it's visible that both rudder horn and push rods have the same line due to "twisted" horn.
Nice touch.
Hide Signatures
       Post #: 28
RE: Fly Eagle F-18 1:6 - 11/11/2011 1:50 PM
joenz
Score: 100
Last Login: 3/13/2012
Status: offline
Hi!
We have the FEJ F-18 1:6 with two front flaps.  We can't find the  travel setting for these flaps. FEJ doesn't have the exact instruction manual for this model. All ideas from you guys will be of great help and will be highly appreciated.
Thanks a lot!
joenz
Hide Signatures
       Post #: 29
RE: Fly Eagle F-18 1:6 - 11/11/2011 6:52 PM
jeteye
Score: 110
Status: offline
quote:
ORIGINAL: olnico
The P-200SX is just perfect with the 1/7th scale F-18F at 230 N.
The 1/6th scale one is going to be underpowered with a Mammoth. Bare in mind that this airframe generate a tremendous amount of drag with a Y pipe...
I'd go for the new Behotec 300...
The 1/6th F-18 will not be underpowered with the Mammoth.  I'll match my Mammoth powered F-15 with anything on the market.  It will be a great combination as you will discover.
The General-Jet Central,Team JR-Horizon Hobby,Fly Eagle Jets,Robart,"Jets Over Kentucky week", ElectroDynamics,
Hide Signatures
(in reply to olnico)
       Post #: 30
RE: Fly Eagle F-18 1:6 - 11/12/2011 6:14 PM
rbxbear44
Score: 100
Status: offline
quote:
ORIGINAL: joenz
Hi!
Thanks a lot!
joenz
Joenz,
I am getting ready to begin a 1/6 F-18 build for a friend. This one is in the Honeycomb, latest construction and will have a twin turbine setup. Using 2 EvoJet 160vx's, turned down to meet AMA guidelines. This one has the new, full length Slats rather than to two separated with a pivot rod running the length of the Slat into a servo box under the wing farings. So, I don't know if I will be of any help for you on this. If you do have the Split Slats, I would suggest PM'ing KMarks since he built one with those and came up with a good modification for proper strength and function.
This is very impressive with the sheer size (look closely at the 1/6 Pilot sitting on the Strake) and after a very thorough inspection of the airframe, formers, plates and servo boxes...FEJ has done a fantastic job with their processes and I look forward to this build.
Rex
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to joenz)
       Post #: 31
RE: Fly Eagle F-18 1:6 - 11/12/2011 8:57 PM
F86Skyblazer
Score: 100
Last Login: 11/22/2012
Status: offline
Hi Jeteye
reading your comments about the possible performance with the turbine you mentioned is enough you are right. Comment jeteye:The 1/6th F-18 will not be underpowered with the Mammoth
But if you ever have seen the B300F in operation you will change your comment quickly.
Kind regards
F86 Skyblazer
Hide Signatures
(in reply to rbxbear44)
       Post #: 32
RE: Fly Eagle F-18 1:6 - 11/12/2011 10:05 PM
Wap4life
Score: 110
Status: online
Rex
I hope you share your build, that f-18 1/6 is on my short list!
Wap
Hide Signatures
(in reply to F86Skyblazer)
       Post #: 33
RE: Fly Eagle F-18 1:6 - 11/12/2011 10:13 PM
FenderBean
Score: 119
Status: online
Well I tell you I have flown my f16 a few times now and it flies like a dream lands like a trainer
People seem to be impressed with. I know I am
is the F-18 made of the new material?
< Message edited by FenderBean -- 11/13/2011 3:20 AM >
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to Wap4life)
       Post #: 34
RE: Fly Eagle F-18 1:6 - 11/13/2011 3:46 AM
jeteye
Score: 110
Status: offline
quote:
ORIGINAL: F86Skyblazer
Hi Jeteye
Kind regards
F86 Skyblazer
With the max thrust limit in the U.S. I'm pleased with what I have.
< Message edited by jeteye -- 11/13/2011 4:18 AM >
Hide Signatures
       Post #: 35
RE: Fly Eagle F-18 1:6 - 11/15/2011 2:12 PM
joenz
Score: 100
Status: offline
Thank you Rex! Looking forward for more photos of your F-18
Joenz
Hide Signatures
       Post #: 36
RE: Fly Eagle F-18 1:6 - 5/25/2012 8:58 AM
Paul Turbine Jet Man
Score: 100
Last Login: 5/10/2013
Status: offline
Hi guys.
I have recently just finished building my 1/6 super Hornet ( old version about 16 months old now) and was hoping that someone could tell me what centre of gravity and ended up using on this particular plane as a nice stable setup.
Either with or Without fuel ! any info is good
The manual says 220mm BUT I'm not taking that is not 100% correct as they always seem to be different.
I'm running two Merlin 110 turbines giving me about 22 - 23 kg of thrust with straight pipes so the efficiency should be quite nice compared to one big engine with a split pipe.
I owned the fly Eagle 1/7 super Hornet before but never really had much success with that one as it weighed about 25 kg dry.
This much bigger 1/6 version with twin turbine is only weighs 26 kg dry so I'm pretty certain it can fly okay compared to the other one.
But just generally looking for feedback from anyone who has had experience with flying this particular model. Any control through rates for positions anything would be greatly appreciated.
Have also got hydraulic retracts in this and they work exceptionally well. i have splayed the gear out another 40 mm wider on the rears so it has a wider track on the ground
Click for fullsize
Click for fullsize
Click for fullsize
Dont buy it if you arn''t going to fly it.
Hide Signatures
(in reply to joenz)
       Post #: 37
RE: Fly Eagle F-18 1:6 - 5/25/2012 8:40 PM
David Jackson
Score: 111
Status: offline
You got some really nice toys! Good luck with your F-18, hope to see some flight video.
Hide Signatures
(in reply to Paul Turbine Jet Man)
       Post #: 38
RE: Fly Eagle F-18 1:6 - 5/25/2012 9:25 PM
tassos p
Score: 100
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: Paul Turbine Jet Man
You can find some of our findings about this model here:
http://www.rcuniverse.com/forum/fb.asp?m=9599028
Good luck with the maiden
Tassos
Hide Signatures
       Post #: 39
RE: Fly Eagle F-18 1:6 - 5/28/2012 3:07 AM
Score: 100
Status: offline
Thanks mate !
yes i do and I'm very lucky to have them............ what you haven't seen is the other half of the shed.....
i will get someone to video it for sure and post the result.
Hide Signatures
(in reply to David Jackson)
       Post #: 40
RE: Fly Eagle F-18 1:6 - 5/28/2012 4:17 AM
Score: 100
Status: offline
Thank you very much for the link i had a good read. i will post there as well encase anyone else is subscribed to that thread as well.
what is really freaking me out though at the moment is WHAT IS THE REAL CG.
manufacture says 220 mm your saying 180mm ( from experience)
99% of the time i would go with people who say its different after testing vs some random Chinese measurement BUT
Your talking about the slats version F18 being potentially different to the standard wing version i have.
i would have thought that both airframes would have the same CG based on the physical shape of the plan being identical BUT perhaps they are different i don't know.
a change of 40 mm in CG would be 1kg + of led so its not something i want to guess to much on! has anyone else flown this monster 1/6 and have any info on CG findings that can help me confirm Tassos findings.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ONE thing i keep looking at is the two pics below. 1/7 170mm 1/6 220 mm the physical size difference would suggest that the smaller 1/7 wing having 170 mm and a 1/6 having 220mm would sound about right considering the physically larger wing ?
@ 180 mm the CG is only 10mm further back than the 1/7 plane that is 420 mm shorter in length .......... the percentage difference just don't add up to me !
< Message edited by Paul Turbine Jet Man -- 5/28/2012 4:39 AM >
Hide Signatures
(in reply to tassos p)
       Post #: 41
RE: Fly Eagle F-18 1:6 - 5/28/2012 3:00 PM
jetspud
Score: 100
Status: offline
What hydraulic kit are you useing for your gear
David
Hide Signatures
       Post #: 42
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
