jelaird
Joined: 1/12/2002 From: Gilbert, AZ, USA Status: offline
I can't express how happy I am with my ZDZ-80 vertical performance with just a Bambula 26x8 prop on a H9 Sukhoi. It kicks royal booty. Up-lines are unlimited and always get some good comments from pals. But starting this baby is getting me frustrated. I get a pop with choke after 3 flips with any throttle setting between 50% and 10%, but after opening the choke, it takes 5 flips before I start getting individual pops like it is going to take but it never does. As a matter of necessity, I literally have to flip harder and move the throttle up to 50% before I get it to light off (15 flips min.). After the first flight and "warm" it takes about 5 flips before I get the idea that it needs choke on again, after that pop, it takes about 10 killer flips unchoked. I looked at the RCShowcase web site and went for the timing procedure. With my sensor in the stock position against the end of bracket's slot travel, I measured 6mm between magnet and sensor, compared to the 7mm needed. I gladly advanced the timing by 1 mm and next time out I got remarkable starts. 2 flips to pop from cold with choke, 3 flips without choke. The rest of the day it started on the first flip with no choke (excellent for me). Too bad, my vertical performance was lost and only marginal at best. I went 1/8th leaner on the high needle with no improvement. I decided to return the sensor to the stock setting next time out just to make sure it wasn't an anomaly and sure enough...top end was back but hard starts were the order of the day. With 20 flights and 4 gallons through it, my needles have wound up to 1/2 turn out on the low and 1 turn out on the high. Does any body think I need to go back through the entire mixture procedure to get my top end back at the easy-start timing? Should my ignition module be sent in? Maybe my 26x8 break-in prop needs to come off and replaced with the 26-10. I will take the cowl off and do up some RPM numbers with needle settings next weekend but until then, please reply with any advice you have. Thx
_____________________________
Jack Chaos, panic, & disorder - my work here is done.
