RE: Goldberg super Chipmunk build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Goldberg super Chipmunk build Page: <<   < prev  2 3 4 5 6 7 8 9 10 [11]
Login
RE: Goldberg super Chipmunk build - 1/19/2012 12:10 AM
motoman326
Score: 100
Last Login: 5/25/2013
Status: offline
Another question for the great minds that prowl these forums......
I was going to use the OS 65 LA but I recently acquired an OS 61 SF
Which would be the better engine for this plane…
Discuss…..
Hide Signatures
(in reply to motoman326)
       Post #: 251
RE: Goldberg super Chipmunk build - 1/21/2012 9:33 PM
dragonov3
Score: 111
Last Login: 2/23/2013
Status: offline
The .61 SF will power the plane nicely. You should have no problems with it. I have one of these engines waiting for a plane to install it in.
Dan
_____________________________
Humilitas occidit superbiam.
Hide Signatures
       Post #: 252
RE: Goldberg super Chipmunk build - 1/23/2012 8:37 PM
Hab
Score: 100
Last Login: 4/28/2013
Status: offline
Hi guys, Any one used another taiwheel set up besides the stock? Like a Du Bro or Ohio semiscale pull-pull set up?
Hide Signatures
       Post #: 253
RE: Goldberg super Chipmunk build - 1/26/2012 1:25 AM
motoman326
Score: 100
Status: offline
Thanks Dan,
I was leaning that way, You pushed me over...
Hide Signatures
(in reply to Hab)
       Post #: 254
RE: Goldberg super Chipmunk build - 8/28/2012 1:14 AM
Hab
Score: 100
Status: offline
Well , I know this thread is over a year old now, but figured I'd post. I F-I-N-A-L-L-Y got to maiden
mine the other day after being tied up with other issuse for the past year.
Ah... yeah. I do like this one! This is a cool flying and handling airplane. Like having the extra power on hand that I put in it.
Pulls vertical with no problem ( at half) with the YS. Rolling is very graciuos. On first, took 2 "beeps"/ clicks of left
aileron ... couple beeps of rudder... couple more beeps of up ele. ... NICE! Flies and looks awesome in the air.
Was able to squeeze in 5 flights before the sun set. Landing was a little too hot... wants to keep flying even with
throttle chopped on final when lined up. Fast glide. Ys wants (and I've been told from others) the YS .91 needs a 13/10 - 14/12
Be trying a 13/8 on it next time out even though they say a 10, to see if that slows it down a little on approach. If not, it's manageable.
Very happy with this one and it's a really fun airplane to fly . Glad I built this one.
Hide Signatures
       Post #: 255
RE: Goldberg super Chipmunk build - 8/28/2012 1:25 AM
dragonov3
Score: 111
Status: offline
Congratulations!!! Do you have any photos of the finished plane. Seeing it complete is my favoriten part.
Hide Signatures
(in reply to Hab)
       Post #: 256
RE: Goldberg super Chipmunk build - 8/28/2012 4:07 AM
Hab
Score: 100
Status: offline
Thanks!
Yes... Posted 3 pics a while back. Two of the photos were on the balancer.
I had a problem trying to post pics on here before. Friend in my club finally got them posted up for me. Wish I'd have of been able to get out
earlier in the season with this. Tried last year, had problems with the YS right off the get go when I first tried for it last year.
Had other issues that rolled around that set me back a few steps.
Decided Sat. it was time. This plane needs to get airborne before the season ends and another year rolls by.
Had a very good day, Sunday, with it. That was it's maiden.
Loved when it rotated off the ground for the first time, and it's handling characteristics... then making a few fly-by passes and it only taking a few clicks of trim.
wow ..... "I'm liking this one" Wasn't sure how this was going to handle with the YS, but it's a dream to fly.
Got two YS .91's off fleabay for good prices 2 yrs ago when this build started. When I first mounted the chosen one for the Chip, had no luck
with first run -in. Tried the other (of course that one also had issues) What it was doing, ~1st .91~ as described when reading tech and other forums, pulling air into the system causing a lean run.
Common thing. Gaskets.
Went threw that motor with a gasket rebuild. Did gaskets, o-rings , diaphram, set lash ... etc
The other unfortunately needs a crank ( which is still available from YS) At some point I'll end up going through that one, complete.
Now; so far as they say when set right, this motor runs awesome and doesn't need to be touched.
VERY happy with this plane / combo. I'll try to get a vid posted one of these days.
Hide Signatures
(in reply to dragonov3)
       Post #: 257
RE: Goldberg super Chipmunk build - 8/28/2012 4:14 AM
Hab
Score: 100
Status: offline
Post # 200 shows .....
Hide Signatures
       Post #: 258
RE: Goldberg super Chipmunk build - 10/5/2012 5:16 PM
motoman326
Score: 100
Status: offline
Well, finished up the chipmunk, left out the smoke system but did add retracts and flaps.
Total weight 8lbs 13 Oz (Yikes)
Went with the OS 65 LA
3004 serovs all around. Will report after the maiden.
I'll see if I can figure out how to post photos
Thanks to everyone....
Hide Signatures
(in reply to Hab)
       Post #: 259
RE: Goldberg super Chipmunk build - 10/5/2012 5:22 PM
motoman326
Score: 100
Status: offline
I posted it in my gallery and hangar.
Hide Signatures
       Post #: 260
RE: Goldberg super Chipmunk build - 10/6/2012 6:09 AM
Kyosho Joe
Score: 100
Last Login: 4/16/2013
Status: offline
My dad and I built A Goldberg Super Chipmunk back around 1990 or so. I still have it. Though it is in sorta rough shape. Needs recovered and I think mice got into the wings and chewed the ribs a little bit. Could probably be R & R'd  but not sure exactly how you would restore a 30 year old model. Besides recovering the plane  do the the glued joints get old and brittle? Can you reg lue these? Anyway, I am interested in building a new one. Is the kit offered today the exact same as the old kit of 30 years ago? New to the forums. Please advise
Hide Signatures
       Post #: 261
RE: Goldberg super Chipmunk build - 10/6/2012 3:13 PM
matadco
Score: 105
Last Login: 2/28/2013
Status: offline
I too built a Goldburg chippy when they first came out back in the late '80s. I left the hobby for a number of years and got back in '06 and built another. Although my memory is poor, I believe the kits are the same exceept for pirce. I think I only paid something in the $50 range back then.
Hide Signatures
(in reply to Kyosho Joe)
       Post #: 262
RE: Goldberg super Chipmunk build - 10/7/2012 12:47 AM
VincentJ
Score: 145
Last Login: 5/24/2013
Status: offline
Carl Goldberg Classics is still offering the Super Chipmunk.  I built one about two years ago.  Still very good quality.  The glue joints on your dad's plane may have gotten brittle over time especially if it was assembled with Ambroid, which was a pretty popular glue back then.  I put a Saito 100 in mine and it flies GREAT.
VJ
Hide Signatures
       Post #: 263
RE: Goldberg super Chipmunk build - 10/10/2012 1:48 PM
acdii
Score: 155
Last Login: 5/20/2013
Status: offline
I picked up an original CG Chipmunk a few weeks ago, and going to put a Magnum 91 FS on it.  Researching retracts, but not finding much on what type to put on it. 90* 100*?  If 90* do the Eflite electrics fit it?
I haven't started the build yet, just gathering gear.  I may or may not use Ultracote on it, I have a few rolls set aside in case I do, but I may go the Koverall route and dope instead.  I already have 2 builds going right now, a TF 1/7th P-51C, and a SIG 4*120.  The 120 is getting a DLE20, not sure yet what I want to put on the Stang, whether another DLE20, or a 4 stroke. The DLE just does not sound right for the Mustang.  I like the sound of the 91 though, but that will be a tad under powered for the Stang since I built a bit on the heavy side with retracts and scale doors.  It Must have a 1.20 on it.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to VincentJ)
       Post #: 264
RE: Goldberg super Chipmunk build - 10/10/2012 2:04 PM
VincentJ
Score: 145
Status: offline
Acdii, may I suggest Solartex.  It is so easy to apply and a whole lot stronger than ultraCote.  It comes in various colors, or you can buy it  Natural and paint it.  I covered my Chipmunk in UltraCote  and I am constantly re-shrinking the covering . Koverall is a very good choice  with a down side of a lot of work to install.
VJ
Hide Signatures
(in reply to acdii)
       Post #: 265
RE: Goldberg super Chipmunk build - 10/10/2012 8:28 PM
motoman326
Score: 100
Status: offline
Acdii, I put the 60 size 90 degrees E-Flite retracts in my chipmunk. They are scale so the rotate back toward the trailing edge. I had to reinforce the spar since I cut through it to make the wheel fit. I also had to bend my own struts since the electric retracts wouldn't allow the wheels to fully retract. I heard E-Flite has 90 degree rotating retracts now so they might fit better.
Still trying to figure out how to post photos...anyone?????anyone???? (Bueller....Bueller)
Hide Signatures
       Post #: 266
RE: Goldberg super Chipmunk build - 10/10/2012 8:48 PM
motoman326
Score: 100
Status: offline
[URL=http://s1230.photobucket.com/albums/ee484/jreshirron/?action=view¤t=RetractVideo.mp4] [/URL]
http://s1230.photobucket.com/albums/ee484/jreshirron/?action=view&current=RetractVideo.mp4
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 267
RE: Goldberg super Chipmunk build - 10/10/2012 8:49 PM
motoman326
Score: 100
Status: offline
Hide Signatures
       Post #: 268
RE: Goldberg super Chipmunk build - 10/10/2012 8:58 PM
motoman326
Score: 100
Status: offline
Whew,
Well I think I got it figured out. Let me know what you think. I plan to maiden her as soon as I get a nice weekend (and my flying buddy is back in town)
Hide Signatures
       Post #: 269
RE: Goldberg super Chipmunk build - 10/21/2012 3:45 AM
Kyosho Joe
Score: 100
Status: offline
quote:
ORIGINAL: VincentJ
I just dug it out of the upstars of the the barn and cleaned it up. It cleaned up pretty well. But I would never try and fly it. It's just a neato wall hanger at this point. I'm going hang it up in my basement hobbie shop I'm putting together since I'm getting back into the hobbie. And I want to build a new one...
Hide Signatures
       Post #: 270
RE: Goldberg super Chipmunk build - 10/22/2012 12:51 AM
acdii
Score: 155
Status: offline
quote:
ORIGINAL: motoman326
Thanks, I have them on my wish list now.  I had originally planned to put my Magnum 91 FS on it, but my Mustang is further along and needs an engine, and the 91 seems to be a pretty good runner for it.  So, depending on swap meets and sales, I dont know what motor will go it it, so it will sit until then. I still have plenty to work on in the meantime, a 4*120, and the Mustang, and I have a 52 FS that needs a home, so maybe a SIG Cub.
Hide Signatures
       Post #: 271
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
