RE: Goldberg super Chipmunk build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Goldberg super Chipmunk build
Page: <<   < prev  2 3 4 5 [6] 7 8 9 10 11   next >   >>
Login
RE: Goldberg super Chipmunk build - 5/20/2010 7:59 PM
Alex7403
Score: 126
Last Login: 3/27/2012
Status: offline
dragonov3 how did you do the fueling system?
I was thinking about two fuel dots one for filling on one side and another with a T from the muffler.
Alex
_____________________________
Ultra Sport Brotherhood #3.
Ya know, a cat is longer from head to tail than from tail to head.
Hide Signatures
(in reply to dragonov3)
       Post #: 126
RE: Goldberg super Chipmunk build - 5/20/2010 8:15 PM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
Alex, you only need one. Just let it vent out of the muffler
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to Alex7403)
       Post #: 127
RE: Goldberg super Chipmunk build - 5/20/2010 8:34 PM
Alex7403
Score: 126
Status: offline
Thanks Mike I was thinking about it and it looked too simple but I guess I like that, less parts less chance of failure.
Alex
Hide Signatures
(in reply to MinnFlyer)
       Post #: 128
RE: Goldberg super Chipmunk build - 5/20/2010 9:06 PM
dragonov3
Score: 111
Last Login: 2/23/2013
Status: offline
quote:
ORIGINAL: Alex7403
Good looking airplane dragonov3,
I worked on mine today and here is where I'm at:
1. The rod of the elevator halves need to be hidden otherwise the oil will creep in, the problem is that the rudder doesnt move on it as an axle = the bar moves up and down a bit,
as the plan goes it has enough space to move in the tail section piece, I think to put it in a nyrod sleeve and glue it there, your input please how did you solve it?
Alex7403: The rod that is exposed between the elevator halves will be covered by the precut balsa that is supplied with the kit. I did not have any problem with fuel soak there on my last chipmunk, so I will do the same thing. Using a pitts muffler helps to divert the exhaust down and away from the plane.
I used the stock tail wheel assembly as it seemed to work great before, so I saw no need to change it.
I am using the slimline excel fueler. I have used these on several of my airplanes, they are easy to install and you only need a two line setup. They are great for cowled in engines. I have one on my H9 Edge 540, GP Ultimate Bi-plane and my World Models Midget Mustang.
Humilitas occidit superbiam.
Hide Signatures
       Post #: 129
RE: Goldberg super Chipmunk build - 5/20/2010 11:20 PM
TonyBuilder
Score: 148
Last Login: 6/20/2013
Status: online
Hey Alex, I see that you installed the elevator and the ruder, are you going to cover her with them installed and if so is this not harder to do? Can you remind me what hinge you are using? Secondly, what will you be covering this bird with?
TB
Fly, fly, fly!!!!
Hide Signatures
(in reply to TonyBuilder)
       Post #: 130
RE: Goldberg super Chipmunk build - 5/21/2010 3:29 AM
Alex7403
Score: 126
Status: offline
Thanks dragonov3.
Yes TB I'm gonna cover her with hinges installed.
The hinges are SIG easy hinges (CA hinges) not the GP, I learned to work with them and never had problems.
the idea is to put a stripe of covering on the hinge line about 1/4" from every surface than just cover on it, the problem with this method is the corners which is hard to get into because of the control surfaces but I learned how to deal with it too.
the benefits are huge: if you have a mistake with the control surface you know about it during the building stage and not when the airplane is already covered, second the covering is sealed and you dont have glue on the covering from hinging, you have no knocks from off line hinges etc'.
CA hinges are very good with this method, I learned to do it this way and very happy.
covering I'm gonna do with monokote, I heard ultracoat is better but again I learned to work with monokte and there are several big benefits to it like matching spray paint to some basic colors, trim solvent, lots of colors and some minuses too.
Alex
< Message edited by Alex7403 -- 5/21/2010 8:27 AM >
Hide Signatures
       Post #: 131
RE: Goldberg super Chipmunk build - 6/2/2010 7:16 AM
TonyBuilder
Score: 148
Status: online
Anyone tried the Robart struts for the CG Super Chipmunk? They look like a nice finishing touch if you want to give it a realistic landing gear look. I will have to put it on my second string wish list.
TB
Fly, fly, fly!!!!
Hide Signatures
       Post #: 132
RE: Goldberg super Chipmunk build - 6/8/2010 6:03 AM
dragonov3
Score: 111
Status: offline
Hey all! How is everybody doing on their Chipmunk build. I started covering mine today, went to shrink the first large piece of covering on the wing then my heat gun died. Heat gun was about 20 years old lol. Dang it, had to stop covering. Was hoping to get the wing covered tonight. Will buy new heat gun tomorrow and keep moving. Anybody close to having theirs done? Painted wheel pants, spinner and cowl this last weekend. All came out good. Hope to have it complete and maiden it this weekend. Keeping my fingers crossed.
Hide Signatures
       Post #: 133
RE: Goldberg super Chipmunk build - 6/8/2010 6:57 AM
Smashmaster
Score: 100
Status: offline
Take your heat gun apart and take a look. Mine had a solder joint break.
I redid the solder joint and it works fine.
Fred
Hide Signatures
       Post #: 134
RE: Goldberg super Chipmunk build - 6/8/2010 4:52 PM
TonyBuilder
Score: 148
Status: online
Well, I have been flying a lot (a good thing) and working on my Cub, but I am almost ready for covering myself. Just need to tie up a few loose ends and get her ready for covering. I have all my radio equipment and I re-hinged using Robart hinge points, I am still trying to decide what to cover her with. Anybody used the FS canopy, and wheel pants?
TB
Fly, fly, fly!!!!
Hide Signatures
       Post #: 135
RE: Goldberg super Chipmunk build - 6/8/2010 6:54 PM
Alex7403
Score: 126
Status: offline
I had to shorten the the LG that goes into the wing by 1/4" and did the flap rods to servo so it will move without stress, sanded and started covering the wing, my battery will sit near the D former of the fuselage.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 136
RE: Goldberg super Chipmunk build - 6/17/2010 3:55 PM
TonyBuilder
Score: 148
Status: online
Alex, how’s the plane coming? I am working to get my plane ready for covering. My goal is to have her ready by next weekend, just a few things to get finished before final sanding and covering prep. My biggest obstacle was the flap. I came up with this set-up and hopefully this will work. If the budget will allow, I may do the Robart struts.
TB
Click for fullsize
Click for fullsize
Fly, fly, fly!!!!
Hide Signatures
       Post #: 137
RE: Goldberg super Chipmunk build - 6/18/2010 2:25 AM
Alex7403
Score: 126
Status: offline
Hi TB
As for my Chipmunk I covered and finished the wing, now I'm covering the fuselage (I'll add pictures later).
Total dry weight comes to be something like 6.8 pounds means I might add a pilot figure....
I had terrible problems with the black monokote - doesn't shrink I'm making holes too easy, called tower and they send a new one right away (wow Thanks).
just the blacknot the white, red, orange, blue, just the black.
TB, nice setup for the flaps servo check if its not too high and touching other servos it looks right but better to know it sooner than later.
Alex
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 138
RE: Goldberg super Chipmunk build - 6/18/2010 3:00 AM
TonyBuilder
Score: 148
Status: online
Alex, I like your color scheme. I am thinking yellow, as the main color, some black and maybe so red. I think I will try UltraCoat for the covering. Now I am getting excited about my plane.
TB
Fly, fly, fly!!!!
Hide Signatures
       Post #: 139
RE: Goldberg super Chipmunk build - 6/18/2010 3:03 AM
Alex7403
Score: 126
Status: offline
Thanks, I like those red and white wing tips I'm doing it for all my planes, you can see them from a mile.
Hide Signatures
       Post #: 140
RE: Goldberg super Chipmunk build - 6/18/2010 8:02 AM
TonyBuilder
Score: 148
Status: online
The other day I was flying my Avistar trainer, it dead sticked and when I got to it (a safe landing) and picked it up, fuel was poring out of the nose, I got it back to the pits to find the fuselage flooded with fuel. The fuel line broke at the fuel tank (hens the dead stick).
So now I will be installing drains in all the fuselages where fuel can collect if there is a leak. I am using a small grommet for the finishing touch; I will install this after covering, and then seal it with epoxy on the inside.
Click for fullsize
Click for fullsize
Fly, fly, fly!!!!
Hide Signatures
       Post #: 141
RE: Goldberg super Chipmunk build - 6/22/2010 8:50 AM
Alex7403
Score: 126
Status: offline
I finished the da_n thing OMG everything was a problem at the end but now its finished.
dry weight 7.75 lb dont know how I got there well the pilot is 3 oz and there is a balsa belly pan...
hope to fly it on wednesday there are many things that need after flight adjustment like the ailerons.
the wheel pants I'm gonna install after I see the LG is holding the landings.
The motor I ended up with is tower 75 with 12x8 - 13x6 props.
Radio is Hitec Aurora 9 with total 6 servos, also the ailerons are on separate channels something I wanted to try.
Until now I didnt use the supplied decals but in this case it was asking for it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Alex7403 -- 6/22/2010 12:09 PM >
Hide Signatures
       Post #: 142
RE: Goldberg super Chipmunk build - 6/22/2010 3:36 PM
TonyBuilder
Score: 148
Status: online
Alex looks really good. I just ordered my covering; I am going with the UltraCoat covering. I see you had to put the batteries in the tail section; do you have a hatch for access? I decided to go with a Saito 100 instead of the OS 61, so I am waiting on the new engine, should be here any day now. I will pre balance before covering, and I may do a hatch on the bottom of the tail section for balancing. I am shooting to be ready to maiden my plane the fallowing weekend.
TB
Fly, fly, fly!!!!
Hide Signatures
       Post #: 143
RE: Goldberg super Chipmunk build - 6/24/2010 2:51 AM
Alex7403
Score: 126
Status: offline
Well I tried to fly it today and the day wasn’t so successful depends how you look at it….
I taxied it and took off lost control and it crashed not severely luckily only the prop was broken.
It behaved as tail heavy (first mistake) and the throws are huge (second mistake).
We lifted it from the wing tips at the spars and the tail went down, when I checked its CG upside down it was perfect but when I hold it up right its very tail heavy.
This pitts style muffler on the tower 75 makes a funny noise like its 25 engine…
Except for my ego and the prop this time everything is fine and fixable, one soul less.
I need to stop flying this way I guess.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Alex7403 -- 6/24/2010 5:09 AM >
Hide Signatures
       Post #: 144
RE: Goldberg super Chipmunk build - 6/25/2010 7:28 AM
TonyBuilder
Score: 148
Status: online
Alex, the plane looks great, sorry to hear about the first flight woes. I installed the Saito engine and throttle linkage. Fuel proofed the interior and painted the firewall. Tomorrow I will cover this bird with the help of my mentor. I went with the inverted installation and my use a pitts muffler for the Saito.
TB
Click for fullsize
Click for fullsize
Fly, fly, fly!!!!
Hide Signatures
       Post #: 145
RE: Goldberg super Chipmunk build - 6/25/2010 7:39 AM
Alex7403
Score: 126
Status: offline
Thanks TB, and looks good TB your cowl will have much less holes in it.
I wouldnt use that linkage connection on anything important like elevator or ailerons because its very unreliable.
best of luck and post pictures.
Alex
Hide Signatures
       Post #: 146
RE: Goldberg super Chipmunk build - 6/26/2010 8:01 AM
TonyBuilder
Score: 148
Status: online
Well, I finally got her ready for covering, pre balanced showed she was just a tight bit nose heavy with the battery placed in front of the servo tray, so there is room to move it back, or forward for final balancing. This is my first covering job, I went with UltraCote. I had the help of my mentor to get started, and then I finished on my own. I got the wing done short of painting the wing tips and the plastic on the belly. I found the UltraCote very easy to work with; I did melt one of the plastic wing tips, got to aggressive with the heat gun. Some bondo will take care of that. All in all, she is coming together nicely, next on to the ailerons, and flaps, then to the fuselage.
TB
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fly, fly, fly!!!!
Hide Signatures
       Post #: 147
RE: Goldberg super Chipmunk build - 6/26/2010 10:58 AM
Alex7403
Score: 126
Status: offline
Its coming out very nice Tony are you sure its your first kit and covering?
I believe its gonna fly really well too you are a kit builder so say good bye to ARFs from now on.
Alex
Hide Signatures
       Post #: 148
RE: Goldberg super Chipmunk build - 6/26/2010 5:53 PM
Live Wire
Score: 6334
Status: offline
Thats what you call , Iron on covering Looking great.
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
       Post #: 149
RE: Goldberg super Chipmunk build - 6/27/2010 7:36 AM
TonyBuilder
Score: 148
Status: online
quote:
ORIGINAL: Live Wire
That ironing board has sat in my closet collecting dust for years, many times I thought I would just toss it, now it has a very nice home as my covering ironing board, works great.
TB
Fly, fly, fly!!!!
Hide Signatures
(in reply to Live Wire)
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
