TonyBuilder
Score: 148 Joined: 3/28/2010 Last Login: 6/18/2013 From: Austin ,
TX, USA Status: offline
I flew the Chipmunk this weekend for her maiden, and she was an amazing plane. After running a few tanks threw the Saito 100, I took her up for the maiden. With all the excitement and adrenalin, I did not check the muffler. The engine was still rich, and I was taking it easy, it sounded weak as I took of but it still got up and in the air fine, a little trim and she was flying the pattern high up. After a few rounds, I brought her in and on approach a dead stick was on hand. I was shaking and excited but still managed to bring her in safely. After fueling her up and tuning the engine, I a bystander pointed out that the muffler was loose. So I tightened it up and out we went. This time she was running a lot stronger, and I was able to see how she was handling. The first day I hade a few dead sticks on approach as the engine was still breaking in, landings were a little faster than I am use to but all were manageable. I did not use the flaps yet as I was not sure how the plane would react. I ran just about a half a gallon the first day. When I got home, I went over the plane and decided to install the Slimline inverted Pitt's muffler. This muffler has a much better connection to the motor, just one joint, and it is rock solid. The stock muffler with 90-degree adapter and all has three joints, and I could see it constantly needing to be tightened. The next day I ran about a gallon threw her, adjusted the engine and had her running very well for the second day. This plane flies so nicely, and it is such a joy. The thrill factor of flying this kit over an ARF plane is 10 fold. I haven’t gone crazy with her yet as I am waiting until the engine is fully broken in, and I am comfortable with her reliability. I did try the flaps and found they really shoot the plane up, and it is a matter of getting the timing down as to when to deploy them, but they are fun to use. The Saito 100 is a great engine for this plane, not too much power, I was able to fly around at 1/3 throttle and keep her up, at full throttle she moves nicely. TB
_____________________________
Fly, fly, fly!!!!
Hide Signatures
