Gas Jet Boaters
RE: Gas Jet Boaters
RE: Gas Jet Boaters
Dana .. contact Peter Hawkins about which hull from your own stable to use , add a delta on the keel ,
re-build one of your deck-molds to a more jet-boat-style .. and you'll have a winner.
Only rival on the USA market is the MHZ-jetsprint .. I'm sure you can beat their pricing ,
and i can vouch your laminating skills.
I recomment using this deck ... making the opening more to front , and a nice wide rim for attaching a windowscreen.
RE: Gas Jet Boaters
Thanks guys . I just started a build design today . I'll post some photo's in a few weeks . I was thinking 34" in length . What's your opinion on that ?
RE: Gas Jet Boaters
excellent work on BOTH boats. I grew up having jet boats and it is something you'll always have a craving for once you own one!! what kind of speeds are these puppies gettin with a stock 26? You loose a lot of speed with a real jet pump over a prop...less efficiant. just wondering...
what about a catamaran with a center pod for the pump?? I used to own one that was 19' with a BBC. I'd like to find something like that
anyone make a hull like that?
here's a pic of DOCKMAN's boat!!
[img]file:///C:/DOCUME~1/User/LOCALS~1/Temp/moz-screenshot.jpg[/img]
RE: Gas Jet Boaters
Hi guys
I am also building a plug for molding a sprint hull. just wish i could work as fast as what Dana is.
just noticed the shot of the rear of the hull still has a v keel. you prob know this but the pump will require a flat delta keel.
cheers
steve
cheers
steve
RE: Gas Jet Boaters
Thanks for sharing . Nice job . Yes I realize the pump requires a delta keel for the intake but I thought I'd make the V hull first then shave the back for the delta keel . Then add the strakes . Thanks for your input though .
Yes Scott this is only the plug . Hope to be molding very soon .
