Design & CG Excel Spread Sheet
Tower Hobbies
Logged in as Guest
  Printable Version
Avonds F-15 RTF - RTF
Seller:  BAGOSTIX
Details:   $4,200.00   |  11/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Design & CG Excel Spread Sheet
Page: [1]
Login
Design & CG Excel Spread Sheet - 7/9/2003 12:40:05 AM
Wizardofflight
Status: offline
This is the beta version and first public release of this RC design spread sheet.
http://www.angelfire.com/scifi2/wizardofflight/images/RC_Aircraft_Design.zip
It is divided into 4 separate pages:
1. Gliders
2. Power
3. Canards
4. Flying Wings
The basis for this spread sheet comes from a CG program that published in “Soar Tech” (don’t remember the issue). Plus information from a number of other various sources. It started out mainly as a CG calculator and has expanded to calculate other basic parameters. Such as Tail Volume Coefficients, MAC, static margin, Aerodynamic Center, also it give a conversion from a standard tail configuration to a V-Tail.
To use the sheet fill in the gray areas with the aircraft’s data (all units are in inches). The yellow fields will reflect the calculations based on that data. While the blue fields will then show the suggested minimums, (NOTE: this data is presented for comparison purposes only.)
Suggestions and constructive criticisms are always welcome.
Alan Sinclair
[email]wizardofflight@hotmail.com[/email]
       Post #: 1
Thanks Alan - 7/9/2003 1:50:58 AM
Dave_Gherardini
Status: offline
Ha Alan. Thanks for the spread sheet. This will come in very handy.
Thanks agin..
Dave G
(in reply to Wizardofflight)
       Post #: 2
Design & CG Excel Spread Sheet - 7/9/2003 2:03:23 AM
hattend
Status: offline
Looks good, can't wait to put it to use.
Don
       Post #: 3
Design & CG Excel Spread Sheet - 7/9/2003 5:28:55 AM
Tall Paul
Status: offline
Can the c.g. for the flying wing be changed?
And what is it right now?
       Post #: 4
Design & CG Excel Spread Sheet - 7/10/2003 6:45:17 AM
glidaguy28
Status: offline
hi Alan cant access your web page......can you help me....or e-mail me your program...thanks Glidaguy
       Post #: 5
Design & CG Excel Spread Sheet - 7/10/2003 10:24:03 AM
Wizardofflight
Status: offline
for the flying wing change the areas in gray with your data and it should do the rest.
If not let me know and I'll fix it.
I have gone over my bandwidth limit today.
I've attached it.
Alan
Click to see the file in new window.Attachment.zip
< Message edited by Wizardofflight -- Jul 10 2003 3:22PM >
       Post #: 6
Design & CG Excel Spread Sheet - 7/10/2003 10:03:20 PM
Tall Paul
Status: offline
Well, there's a typo in the Area heading in the grey area also.
Easy fix.
It does look like a good tool. The numbers I've worked so far agree with other sources.
I do like to know what the c.g. the sheets use, in case I want to change it.
Usually I set in a straight wing of 10" chord and see what the c.g. computes to, but it's a nicety to see where square one is.
       Post #: 7
Design & CG Excel Spread Sheet - 7/11/2003 2:29:43 AM
Wizardofflight
Status: offline
Tall Paul
Sorry, I guess I’m not understanding the question, “… what the c.g. the sheets use, …” Is this referring to the formula?
I’ll can to dig up where I got the data from. I have had this spread sheet sitting around for awhile and the memory is a bit fuzzy.
Alan
       Post #: 8
Design & CG Excel Spread Sheet - 7/11/2003 2:37:14 AM
hattend
Status: offline
I think he wants to know what the CG percentage is so if he wanted to change the parameter, which cell would he have to go into to change it.
Your spreadsheet has a set CG point calculated by the formulas, which cell would he have to change to move the CG forward or back from the point calculated now?
That about right, Tall Paul?
I could be out to lunch
Don
       Post #: 9
Design & CG Excel Spread Sheet - 7/11/2003 2:52:50 AM
DICKEYBIRD
Status: offline
Hi Alan, great tool....thanks very much!
Question: I'm working with a friend on his variable CG canard project (Don't ask! :rolleyes and am wondering if your program will compute the CG for a canard just by entering negative numbers into the "Distance from leading edge wing to leading edge tailplane and Distance from AC of wing to AC of stab" fields, if not, how?
_____________________________
"He who dies with the most good Cox engines wins!"
       Post #: 10
Design & CG Excel Spread Sheet - 7/11/2003 3:41:52 AM
glidaguy28
Status: offline
thanks Wizard...glidaguy
       Post #: 11
Design & CG Excel Spread Sheet - 7/11/2003 5:48:41 AM
Tall Paul
Status: offline
[QUOTE]Originally posted by hattend
Don
[/QUOTE]
Close... I like to know what the fixed values are in addition to which of them are variable.
The c.g. in the "wing" section is 18%.
12.3% (negative) for the "canard" section..
40% in the "power" section
and 37% in "glider"..
but apparently the option to change isn't part of the sheet.
I'd prefer that option.
       Post #: 12
Design & CG Excel Spread Sheet - 7/11/2003 5:47:01 PM
DICKEYBIRD
Status: offline
Oops, sorry Alan....I failed to heed Paul's favorite warning: "RTFB." I read your instructions and saw that you have canards covered.
Thanks again for a great little program!
       Post #: 13
Design & CG Excel Spread Sheet - 7/11/2003 7:30:43 PM
Wizardofflight
Status: offline
Tall Paul
I'll dig up the reference material and my notes this week end and let you know.
Have a great day.
Alan
       Post #: 14
Design & CG Excel Spread Sheet - 7/12/2003 10:33:11 AM
Wizardofflight
Status: offline
[QUOTE]Originally posted by Tall Paul
[/QUOTE]
Tall Paul
Here are the equations that are used to calculate the CG for the flying wing. They were derived from equations published originally by Ron Van Putte, June1980, Model Aviation and then they were used in a Basic program printed in Soar Tech.
CG = P + ACw
P = (R^2 + (R X T) + T^2)/(15(T + R))
R = Wing Root Chord
T = Wing Tip Chord
The CG in % MACw is calculated for each combination of variables.
I hope this helps.
Alan
< Message edited by Wizardofflight -- Jul 12 2003 5:57AM >
       Post #: 15
Design & CG Excel Spread Sheet - 7/12/2003 9:46:15 PM
Tall Paul
Status: offline
Thanks... it calculates where the c.g. should be...
       Post #: 16
RE: Design & CG Excel Spread Sheet - 9/15/2003 9:18:09 PM
RRW_SOAR
Status: offline
Hey! This is what I've been looking for, although I don't understand all the terms.
Will you please give a hand? I'd like to know what they mean or if there is a link where I can find more info.
Here I go:
1. Leading edge sweep offset (LESO): I thought that Root_chord = Tip_chord + LESO but I'm wrong...
2. Static margin?
3. P?
4. DIH angle and the related in this frame (wing loc. etc.)
Thanks in advance.
Ricardo,
Chile, South America
     &nb
