well i got boared waiting for the apache build so i ended up buying this it came with a hs 645mg for throttle and a hs-705mg 1/4 scale servo for steering, both seam to work well so thats a bonus, it did come with rudder, strut and pipe mount it was removed for shipping. so i brought the seaducer cat a x-mass gifts from gizmomotors 1 x Baxter 500ML Iv Bag kit complet 2 x Baxter 500ml Gas Bags 1 x In Line Fuel Filter 1 x Aeromarine Stainless Steel round 1/4 Collet (will have to grind 2 fit the rcmk) 1 x Radio Box Tape radioboxtape 1 x SPEEDMASTER THROTTLE ARM 1 x Kwik Fill Fuel Pump kit 1 x Rcmk S-254 EVO ENGINE and from redlinemotors i brought 1 x 90 qd/redline hot pipe. 1 x 100 degree hot pipe header 1 x water cooled exhust flange to suit and from ebay.com.au i brought 1 x new venom 1200 mha hump pack for the prop i spoke to Brent Daily form propwroks west and brought a 6617/3-400c-LL racers edge series prop to try out for the first run on land to set up the carb i made this up out of old retic parts the seller forgot to send the engine mounts for it he pulled the motor out and left the mounts on the motor, a couple of days ago i got the tracking number for the engine mounts to be shipped to me for free, but it will take around 2 weeks to get to australia. this will only be used for fun, not for racing its abit ruff, but its a used cat the bottom looks like its been trued and the motor mounts moved back, im looking forward to getting all the bits here so i can have a play, but ive got a lot of waiting to do, a couple of weeks atlest and mabe more for the prop. thanks shane
_____________________________
Thanks shane
Hide Signatures
