3.3 oiling mod    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Slash 4x4 roller with TQ 2.4GHz Traxxas Link - Kit
Seller:  Callifas38
Details:   $150.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> 3.3 oiling mod
Page: [1]
Login
3.3 oiling mod - 1/1/2010 5:41 AM
jdw652
Score: 100
Last Login: 1/17/2013
Status: offline
i went through 12 gallons of byron's gen2 fuel this year and 7 rear crank bearings. each time i took the motor apart the bearings were dry. so i came up with this mod does any one see why it wont work.
Hide Signatures
       Post #: 1
RE: 3.3 oiling mod - 1/1/2010 5:50 AM
absolutemayhem
Score: 105
Last Login: 9/26/2010
Status: offline
if that hole is were it looks like...you might of just ruined your motor. cause now it will not be able to compress the crank case as good therefor destroying preformance. i would cover that hole up and look into modding the crank to direct some flow into the bearing.
_____________________________
REVO NINJA .28, MBX5T, FLM pede hv maxx, rc18t brushless, DX3S,
Hide Signatures
(in reply to jdw652)
       Post #: 2
RE: 3.3 oiling mod - 1/1/2010 5:54 AM
mxdubbs
Score: 100
Last Login: 9/24/2011
Status: offline
... Well it was an idea but  I do agree with mayham,You probebly ruined your motor but If it works tell us it would be cool to have a new engine mod that works.
Stampede vxl!!!
Revo 3.3 <The best truck ever)
Hide Signatures
(in reply to absolutemayhem)
       Post #: 3
RE: 3.3 oiling mod - 1/1/2010 6:40 AM
MiamizFinest
Score: 140
Last Login: 5/25/2013
Status: offline
You can throw that motor in the trash seeing as its pretty much worthless right now
-= 100 Is Only The Beginning =-
-= Made In Dade =-
Hide Signatures
(in reply to mxdubbs)
       Post #: 4
RE: 3.3 oiling mod - 1/1/2010 7:27 AM
jdw652
Score: 100
Status: offline
well it is an old motor so i don't care. the crank shaft sits so close to the bearing that i cant see blow by being a problem. if any one stopped to think about it no matter how much you mod the crank you can not direct oil to the bearing. because it comes from the center of the shaft and centrifugal force sends it to the con rod and bottom of the piston.
and man its like a pack of dogs jumping on 3 legged cat in theses forums. that was some fast negativity.
Hide Signatures
(in reply to MiamizFinest)
       Post #: 5
RE: 3.3 oiling mod - 1/1/2010 7:59 AM
rangerfredbob
Score: 115
Last Login: 5/23/2013
Status: offline
if you are really worried about the flow, leave the seal on the rear half of the bearing, you would need aftermarket bearings or two front bearings but that should take care of it, or at least get it good enough
Hide Signatures
       Post #: 6
RE: 3.3 oiling mod - 1/1/2010 10:34 AM
absolutemayhem
Score: 105
Status: offline
its pertty easy to mod the crank. most motor cranks are shaped in a V..the 3.3 is a O..simply cut it so you can increase exposure to the bearing...btw i hope you dont think what i write is negitive, im just trying to to help you out...if you lived here in the US i would mod your crank for free if you sent it to me. but i know shipping from up north is expensive
Hide Signatures
(in reply to rangerfredbob)
       Post #: 7
RE: 3.3 oiling mod - 1/1/2010 6:12 PM
rcslsafut
Score: 101
Last Login: 1/8/2013
Status: offline
twelve gallons!!!!!!!!
holy cow man ,thats a LOT of running
i would think that if the engine bearing needed to be
directly lubed .The factory would have compensated for that lubrication!
The engine is like other two cycle engines, meaning the oil in the fuel goes down into
the bottom of the engine to lube the bearings and comes up along the sides of the
sleeve to be withdrawn into the engine .the whole reason for doing it this way is to lube the
bottom end of the engine! If you went through seven bearings in twelve gallons ,i would call
that normal wear and tear.As for the engine block, you could epoxy the hole in so i wouldn't
throw it away. i have used pc7 for a lot of engine aplications with great results.
keep your arms and legs in the ride at all times
and HAVE FUN!!!!!!!!!!!!
Hide Signatures
       Post #: 8
RE: 3.3 oiling mod - 1/1/2010 7:14 PM
jdw652
Score: 100
Status: offline
i have 10 crank cases this is a junk one. you can buy the case and bearings cheaper than just the beatings on eBay. the problem is that the bearing is not getting lubed at all as you can see the crank completely blocks the bearing and i know i cant be the only one with this problem. maybe that Byron fuel just spins the motor too fast i don't know. I'll try it as soon as i finish my engine load bank and let you know how it works. oh and the 12 gallons was with 3 motors/trucks and they all blew out the rear bearing
Hide Signatures
(in reply to rcslsafut)
       Post #: 9
RE: 3.3 oiling mod - 1/5/2010 1:26 AM
xxxtsuperstud18
Score: 100
Last Login: 9/1/2011
Status: offline
12 gallons at $30 a gallon hmmm $360 on fuel alone!!!
Losi 8ight, Losi XXX-T, Traxxas T-Maxx, Havoc Heli, Sharpshooter Heli
Hide Signatures
       Post #: 10
RE: 3.3 oiling mod - 1/5/2010 3:11 AM
piddlefoot
Score: 101
Last Login: 4/11/2010
From: hervey bayaustralian best town ppfftt, AUSTRALIA
Status: offline
No offence, and yea this is negative feedback, but what your trying to do is pretty much pointless.
Did these engines sieze from lack of lube ? No , then dont waste your time.
My 3.3 engines have not had these issues.
Even though you might think the gap is tiny, fuel oil does get back there every run, or, the bearing would get glowing red hot and sieze first hard run or cause so much resistance from oversizing cause the engine to shudder to a stop, and you would then find metal shards right through the engine.
Congratulations though, on having enough nouse to have a go, and post as well.
Good on ya for trying.l love to see people by-pass the $$$ mods and do it them self. Like wheely bars etc.
Really hope you get lucky here, but l dont like the odds.
Hide Signatures
(in reply to xxxtsuperstud18)
       Post #: 11
RE: 3.3 oiling mod - 1/5/2010 4:46 AM
jdw652
Score: 100
Status: offline
super stud thanks for doing the math now i feel much better about this hobby. lol
as far as the engine seizing no the engine did not seize but the bearing was so poorly lubed that they would fail on an average of 1 to 1.5 gallons and i just took my motors apart and you can take the total to 10 bearings i used this year. when they come out there is no oil on them at all the reason i can say that is they come out in several pieces. so no I'm not burning off the oil when i remove them.
Hide Signatures
(in reply to piddlefoot)
       Post #: 12
RE: 3.3 oiling mod - 1/6/2010 10:40 AM
ArloRogers
Score: 105
Last Login: 4/18/2013
Status: offline
Ever think that it might be the shaft. Hmmmmmm
T-Maxx Fan
Hide Signatures
       Post #: 13
RE: 3.3 oiling mod - 1/6/2010 4:15 PM
jdw652
Score: 100
Status: offline
do you want to explain that a bit more thats kind of a vague responce. the shaft design or these 3 shafts i have or what?
Hide Signatures
(in reply to ArloRogers)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.805RCU1
