nitro models Fly king 1.20 pusher, webar 120
hello to all
i would like to share with you my latest project
it is a 1.20 flyKing pusher jet made by nitroplanes,( KMP have one as well)
http://www.nitroplanes.com/flying-ca...er-rc-jet.html
the setup that will install on this model is:
TX JR9303 2.4
RX ASSAN 9ch 2.4
7.4 lipo 2650mah 40c
Ubec 8A 6v
ALIE: 2X DS821
ELEV: HS5645
RUDD: HS 475
TH: HS475
front wheel - HS5645
airvalve - HS81MG
engine: Webra speed 1.20+pump with master 3-blade pusher prop 13X8
air retract LDG
the fuse:
full fiberglass red\yellow schem
TX JR9303 2.4
RX ASSAN 9ch 2.4
Ubec 8A 6v
ALIE: 2X DS821
ELEV: HS5645
RUDD: HS 475
TH: HS475
airvalve - HS81MG
air retract LDG
the fuse:
RE: nitro models Fly king 1.20 pusher, webar 120
rudder and elev servo + vertical stab /elev install:
the elevator and stab are conected to the FG fuse with 2 3mm bolts, which i found not strong enough to support such a big surface
so i have add 2 ALU tubes to support the elev stab.
i will add pictures soon
engine install:
the TH servo located at the front and the engine is way back, so to get the most effcient TH stick movment of the TH pushrod, i have used a ball link on the webra carb.
this is not final i may move the servo back if this wont work properly
i will add more pics as i progress with the install future work:
LDG air retracts
struts
air system
fuel tank location: as this is a pump engine , i can put the tank anywhere
acsess door: i may want to use this door as AIR BRAKE still need to check this out ...
LDG air retracts
struts
air system
accesories door & fuel tank install:
other sussgestions will be appriciated
i have installed the ACC door, i added to paper hings as axis so it be easy for open and close, it is fasten with 2 scews only
i find it hard to decise which fuel tank to use as the original one is too small for the webrav 1.20, 320cc.
i have few option to choose from:
1. a 500cc square
2. 2 BVM ducted fan fuel tanks that i have joined togather
3. any du-bro from 450cc-600cc, i got planty
the 500cc one is the nost easy to fit in, all i need to do is to make a hole for the fuel stopper and pipe lines
please remember that due to the engine config as rear, the fuel tank is facing to the front while the fuel tube will be routed to the BACK.
1. a 500cc square
a p60-80 with no problem
but you will need to do some renforsments in the fuse, much more than waht i did
some CF and epoxy will be more than enough
the wings are OK with no issue
maybe some wood at the LDG box to make it stronger
you got lots of place in the fuse
look at the pics that i added
cheers
cheers
My Feedback: (22)
You're in a jets forum, if somebody asks about a turbine install, it's because they want to use a turbine Your build thread is cool, I suspect it would be received a little more in the extreme speed prop planes forum though where they talk about prop jets often.
It's a cool looking airplane, I'd be extremely careful about a turbine install in this one though with that T tail, doesn't look like a lot of structure there.
i agree
how can i move all my threads to the extreem prop furom?
http://www.rcuniverse.com/forum/m_93...tm.htm#9395398
My Feedback: (22)
Hi Gadi,
You'll need to ask a moderator to move it.
Please don't take my comments as negative, I think any build thread is really cool, I just notice you have gotten almost no responses here, and I think it's simply because this is the jets forum, I think you'd get more of the recognition you deserve for doing a full build thread in a more appropriate forum
