Thumbs vs. Pinch method    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ParkZone F-27Q Stryker - RTF
Seller:  nrthwing
Details:   $150.00   |  6/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> IMAC >> Thumbs vs. Pinch method
Page: [1] 2   next >   >>
[Poll]
I fly thumbs only
  50% (142)
I fly forefinger and thumb AKA, the pinch method
  49% (137)
Total Votes : 279
(last vote on : 10/23/2012 6:34 PM)
(Poll will run till: -- )
Login
Thumbs vs. Pinch method - 1/7/2010 12:01 AM
BillyGoat
Score: 105
Last Login: 5/16/2011
Status: offline
Ok I know this topic gets beat to death on a regular basis. However I'm NOT looking for opinions over which one is best.
The reason for the poll is I'm writing an un-biased thumb vs. pinch article for our club newsletter. Polls in the past polled the general R/C population and those results consistently come out pretty even between the two.
So the reason for this poll in this forum is to see if the results are the same for those that fly competition.
I’ll also welcome any insight that may help with the article.
Thanks for participating.
I will be posting the same poll in the Pattern section.
Hide Signatures
       Post #: 1
RE: Thumbs vs. Pinch method - 1/7/2010 1:25 AM
BarracudaHockey
Score: 280
Last Login: 6/18/2013
Status: offline
Hmm.....hard question.
I fly pinch on my helis, thumbs on my planes
I didn't even realize I was doing it till someone that spots for me a lot asked me about it.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to BillyGoat)
       Post #: 2
RE: Thumbs vs. Pinch method - 1/7/2010 1:59 AM
FlyerRick
Score: 100
Last Login: 4/30/2012
Status: offline
Actually neither one of the two ways is better than the other from a control stand point. It is all a matter of personal preferance from the pilots comfort level. Its simply...one way feels better to a pilot than the other.
People try to read too much into things at times with massave amounts of ego and over complication!
"If your plane goes up, it WILL come down...your choice of decent is CRITICAL"
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 3
RE: Thumbs vs. Pinch method - 1/7/2010 2:11 AM
Mastertech
Score: 108
Status: offline
You missed one option,
I fly thumbs on the throttle/rudder and pinch the right.
Be a kid forever, fly models.
Hide Signatures
(in reply to FlyerRick)
       Post #: 4
RE: Thumbs vs. Pinch method - 1/7/2010 3:58 PM
BillyGoat
Score: 105
Status: offline
quote:
ORIGINAL: BarracudaHockey
Well since this is the IMAC form choose the option that applies to airplanes.
Hide Signatures
       Post #: 5
RE: Thumbs vs. Pinch method - 1/7/2010 4:03 PM
BillyGoat
Score: 105
Status: offline
quote:
ORIGINAL: Mastertech
Just trying to keep it simple. If you anaylize it there are several other options that could be added to the mix.
Hide Signatures
(in reply to Mastertech)
       Post #: 6
RE: Thumbs vs. Pinch method - 1/7/2010 9:37 PM
Gremlin Castle
Score: 110
Last Login: 6/15/2013
Status: offline
I fly thumb and forefinger because I learned to fly on single stick transmitters. There is no best way, only the way that work for the individual.
Up elevator is not always your friend.
Hide Signatures
       Post #: 7
RE: Thumbs vs. Pinch method - 1/23/2010 12:38 AM
Montague
Score: 105
Last Login: 1/18/2012
Status: offline
I do this as well, and this is the first time I've run into someone else who does it.
I also use a neckstrap which really helps me keep the TX stable.
Kirk Montague Adams
Free State Aeromodelers, Laurel, MD : http://freestateaeromodelers.org
Hide Signatures
       Post #: 8
RE: Thumbs vs. Pinch method - 1/26/2010 7:49 AM
nmking09
Score: 105
Last Login: 4/29/2013
Status: offline
I end up pulling my neck off when I use a neck strap. No matter how long I make it, I still end up pulling on the transmitter when I fly and end up looking like a hunch back when I land.
Those convinced against their will are of the same opinion still. -Dale Carnegie
Hide Signatures
(in reply to Montague)
       Post #: 9
RE: Thumbs vs. Pinch method - 1/27/2010 5:44 PM
Montague
Score: 105
Status: offline
Sounds like you probably bend the sticks a bit over time as well?
Neck straps are certainly not for everyone.
Just like your style holding the sticks, or where you put your other fingers on the transmitter, or which finger you use on which switch, or how you program, how much expo, rate switches (all together, or on each control) and all that good stuff.
I don't think any of it has a better or worse, just preferences.
Kirk Montague Adams
Hide Signatures
(in reply to nmking09)
       Post #: 10
RE: Thumbs vs. Pinch method - 2/4/2010 10:03 AM
RappyPilot
Score: 130
Last Login: 7/30/2012
Status: offline
I pinch with my heli's and fly thumbs with my planes and then to make things even more interesting prefer to fly fly Mode 2 with my heli's and Mode 3 with my planes.
Hide Signatures
       Post #: 11
RE: Thumbs vs. Pinch method - 2/7/2010 2:21 AM
Tommygun
Score: 130
Last Login: 6/13/2013
Status: offline
quote:
ORIGINAL: Montague
I do this too. I dunno, for some reason I just can't pinch the left stick at all, it's just not comfortable. But it's made all the difference in my flying by pinching the right.
The original Tommygun
Hide Signatures
       Post #: 12
RE: Thumbs vs. Pinch method - 2/21/2010 8:07 AM
rambler53
Score: 122
Last Login: 5/23/2011
Status: offline
I do both. Thumbs on take off and aerobatic flight.
Pinch on landing or touch and go both hands.
I can blimp the throttle and finely handle elevator/aileron controls pinching, when it counts most, near the ground.
Hide Signatures
(in reply to Tommygun)
       Post #: 13
RE: Thumbs vs. Pinch method - 2/23/2010 6:12 AM
Carpilot
Score: 100
Last Login: 4/1/2010
Status: offline
I use both methods depending on what kind of flying I am doing.
For more precise maneuvers I use the pinch method and for yankin and bankin I use the thumb method. I takeoff and land using the pinch method also.
Harken to ye N00bs! Thee shalt lock thine tail wheel afore attempting to leave thine surly bonds!
Hide Signatures
       Post #: 14
RE: Thumbs vs. Pinch method - 2/25/2010 8:57 AM
JOHNS3D
Score: 108
Last Login: 10/28/2011
Status: offline
dang im confuse.....what do you call pinch? i know thumbs means, i fly thumbs and finger.
OMP Extra 300 100cc - DLE111
AW Extra 300 50cc - DLE55
Hide Signatures
(in reply to Carpilot)
       Post #: 15
RE: Thumbs vs. Pinch method - 3/5/2010 5:13 AM
Syssa Pilot
Score: 105
Last Login: 3/16/2013
Status: offline
quote:
ORIGINAL: JOHNS3D
If you hold the sticks between your thumb and your finger thats  "pinch"      I use thumbs when I hold the transmiter and pinch when aI use a tray, which mi do most of the time    Dave
Hide Signatures
(in reply to JOHNS3D)
       Post #: 16
RE: Thumbs vs. Pinch method - 3/11/2010 5:41 AM
PLANE JIM
Score: 171
Last Login: 5/31/2013
Status: offline
how about the guy that has no hands?
"IF YOU HAVE TOO MANY AIRPLANES -FLY BOLDLY AND REDUCE YOUR NUMBER"
Hide Signatures
(in reply to Syssa Pilot)
       Post #: 17
RE: Thumbs vs. Pinch method - 5/3/2010 8:08 PM
el-John-o
Score: 100
Last Login: 11/9/2010
Status: offline
I fly um, neither.  I have my thumbs on top of the sticks and my index fingers curled around the top of the sticks, it feels most natural for me.  I "push up" on the sticks with my thumbs and pull down with my index fingers, that just makes the planes motions and my motions feel more natural.  Does anyone else do anything similar?
Hide Signatures
(in reply to PLANE JIM)
       Post #: 18
RE: Thumbs vs. Pinch method - 6/2/2010 8:33 AM
blademaker22
Score: 110
Last Login: 3/12/2012
Status: offline
quote:
ORIGINAL: el-John-o
I fly um, neither.  I have my thumbs on top of the sticks and my index fingers curled around the top of the sticks, it feels most natural for me.  I ''push up'' on the sticks with my thumbs and pull down with my index fingers, that just makes the planes motions and my motions feel more natural.  Does anyone else do anything similar?
Yup. That's exactly how I fly.
Hide Signatures
(in reply to el-John-o)
       Post #: 19
RE: Thumbs vs. Pinch method - 6/16/2010 10:28 AM
jongurley
Score: 100
Last Login: 6/9/2013
Status: offline
I am thumbs,, faster reaction for helis and such..
"Practice, confidence and arrogance makes you a better pilot, few can use these to the best of their ability" JONGURLEY 3:16
Hide Signatures
(in reply to blademaker22)
       Post #: 20
RE: Thumbs vs. Pinch method - 8/3/2010 3:48 AM
jet22b
Score: 110
Status: offline
Me, I just love to pinch!!!!
Sonny
aka
jet22b
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
(in reply to jongurley)
       Post #: 21
RE: Thumbs vs. Pinch method - 8/3/2010 6:42 AM
Charlie P.
Score: 202
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: el-John-o
I'm somewhere in this camp. Pseudo-pinch. I wear a neck strap but still primarily hold the radio in my left with thumb on throttle/rudder (mode 2). My right is mostly thumb but I "cover" with curled index. Probably to prevent thumb slip-off.
My rates and mix switches I assign to the right and the left is the low-idle, kill, gear, flaps - all the landing type controls.
Charlie P. (NY) "Gravity is weak but persistant".
AMA 747089/IMAA 30723
Hide Signatures
       Post #: 22
RE: Thumbs vs. Pinch method - 8/4/2010 10:11 PM
vertical grimmace
Score: 164
Status: offline
I have a friend that lost his arm in a car accident. He fabricated a false arm that has his TX mounted on it. He flies with his left hand only Pinky on the Throttle rudder and index on the Aileron Elevator. Really impressive and nice to see him continue with the hobby.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to Charlie P.)
       Post #: 23
RE: Thumbs vs. Pinch method - 8/4/2010 11:17 PM
scale only 4 me
Score: 329
Status: offline
There was a guy at our field that was born missing a lower arm,,it was amazing how well he fly with one hand and his stub,,, Helis too
Hide Signatures
(in reply to vertical grimmace)
       Post #: 24
RE: Thumbs vs. Pinch method - 8/19/2010 5:05 PM
da Rock
Score: 265
Status: offline
Right stick = pinch
Left stick = thumb
(that makes 3 of us ???)
Back in the days when slotcars were a big thing, they discovered that guys who worked the throttle with just their thumb weren't as fast as guys who used their index finger on the throttle. At first the index-finger guys took heat for "affecting a look". After awhile that vanished because they were the ones who won all the time. Others picked it up and started winning all the time too. Everybody picked it up and everybody was winning again. The index finger was more accurate, faster, and had more "reach".
Good flying wit ya today
Hide Signatures
(in reply to scale only 4 me)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
