Starter motor runs when battery is plugged in
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> Starter motor runs when battery is plugged in
Page: [1]
Login
Starter motor runs when battery is plugged in - 7/9/2003 5:42:02 PM
NO1
Status: offline
Matt,
I just installed my new 120 and when I plug in the battery pack
for the turbine, the starter motor engages and runs. Doesn't matter if the Rx is on or off.
I also noticed I get a blank screen on the GSU. I have only let the motor run about 4 seconds. All connections are per instructions.
Any suggestions......
Ron Ballard
Decatur, Indiana
       Post #: 1
Check your cables - 7/9/2003 6:52:04 PM
Kevin_W
Status: offline
Sounds like you might have gotten one of mis-wired cables.
http://www.rcuniverse.com/forum/tm.asp?m=894669]
_____________________________
Kevin Whitlow
Texas Jetcat rep
(in reply to NO1)
       Post #: 2
Yup - 7/9/2003 6:57:38 PM
NO1
Status: offline
Just talked with Don Kanuk, even though the plugs ends match up, the cable is still defective..
We learn every day............
rb
(in reply to NO1)
       Post #: 3
Hi Ron, - 7/9/2003 8:48:43 PM
mr_matt
Status: online
When you say the cable ends match up, did you also check the orientation of the wires to the mechanical cut out? (it is a 2 step process, if both checks are not correct it is a problem.
Just want to make sure there is not something going on we do not understand?
Sorry about the inconvenience.
Matt
JetCat rep
(in reply to NO1)
       Post #: 4
INCORRECT WIRING - 7/9/2003 9:40:26 PM
NO1
Status: offline
Matt,
When I originally read the thread describing the bad cable, I
thought if the ends plugged into each other and wire colors matched, the cable was ok. However, "upon further investigation"
they are indeed soldered incorrectly. I have the cable and ECU packaged up for retorn. Don recommended that I call Bob Wilcox
to get a replacement. Is this ok??
rb
(in reply to NO1)
       Post #: 5
Absolutely Ron - 7/9/2003 10:22:30 PM
mr_matt
Status: online
Call Bob, I talked to him about 20 minutes ago, he is expecting your call.
Sorry for this, hopefully we can get you back in the air soon.
Matt
JetCat rep
(in reply to NO1)
       Post #: 6
New Sobriety Test--Wire a Graupner Plug - 7/10/2003 8:19:31 PM
Tom Antlfinger
Status: offline
Matt:
When those Black Forest, backward plug-wiring, gentlemen appear this week in your neighborhood, please remind them that Octoberfest doesn't start until October........ Till then, have them keep it down to (1) O'Douls before bed.... :>))
Tom
(in reply to NO1)
       Post #: 7
Re: New Sobriety Test--Wire a Graupner Plug - 7/10/2003 10:15:59 PM
mr_matt
Status: online
[QUOTE]Originally posted by Tom Antlfinger
please remind them that Octoberfest doesn't start until October........ [/QUOTE]
Boy you got that right! I am going to be "reminding" them of a lot of stuff I can assure you!
Although I heard they are coming "bearing gifts" both small and BIG....they know how things work I think!!
Matt
JetCat rep
(in reply to NO1)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.312RCU5
