RE: Shrike flight report    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Shrike flight report
Page: <<   < prev  1 2 [3]
Login
RE: Shrike flight report - 2/2/2010 3:30 PM
Leo
Score: 100
Last Login: 4/14/2013
Status: offline
Thanks, The trim tabs are cut from the elevator halves, sanded to shape and secured in place with piano wire.
I have followed the specs of the full size aircraft (supplied with the plans) i.e.+3 deg at wing root, -3,5 deg. at wing tip and +0,75 deg. at stabilizer.
It is concievable that the required elevator up-trim on my Shrike is a result of human error. (or sloppy craftmanship;-)
Hide Signatures
(in reply to jetfixr)
       Post #: 51
RE: Shrike flight report - 2/2/2010 4:18 PM
didiwatt
Score: 100
Last Login: 5/21/2013
Status: offline
Leo:
Was your +3 degrees on the wing root also tranferred to the firewall? I think I opened a can of worms here. My plans call for 0/0/0 on all three. Might just stick to that and let ya know how it goes. You are to hard on yourself. The trim could be a result of a kazillion things interacting. Beautiful plane........... Thanks for the help
Paul
_____________________________
Light travels faster than sound. This is why some people appear bright until you hear them speak!!!
Hide Signatures
(in reply to Leo)
       Post #: 52
RE: Shrike flight report - 2/2/2010 4:57 PM
Leo
Score: 100
Status: offline
Thanks for the kind words. The wing incidence at the nacelles is close to 0 degrees and there is no up- or downthrust in the motor mounts
/Leo
Hide Signatures
(in reply to didiwatt)
       Post #: 53
RE: Shrike flight report - 2/3/2010 4:50 AM
jetfixr
Score: 100
Last Login: 5/20/2013
Status: offline
Paul,
Do you have a link to the airplane you are building? I would like to see it.
Leo,
I doubt it is sloppy craftsmanship. I have also set my firewalls to 0,0. I am going to try to find out what the actual incidence of the real aircraft is and see if it matches the plans. I bet it does since this design is pretty scale.
Hide Signatures
(in reply to Leo)
       Post #: 54
RE: Shrike flight report - 2/3/2010 3:55 PM
didiwatt
Score: 100
Status: offline
I don't have a thread going on the build. Can see the plane on the manufacturers website and a link to an earlier model I buidt and flew but I think you have already seen it. Wesite address is giantscaletwins.com
Paul
Hide Signatures
       Post #: 55
RE: Shrike flight report - 2/4/2010 10:17 AM
jetfixr
Score: 100
Status: offline
I remember now. Yours was the yellow one with red stripes right? I am glad to see you are building another one. Are you going to finish this one out like your first one, or are you making changes?
Hide Signatures
       Post #: 56
RE: Shrike flight report - 2/4/2010 1:44 PM
Leo
Score: 100
Status: offline
Paul, Very nice looking Commander. The colour scheme is surely good for visibility too.
In order to avoid tip stall in the high tapered wing, I would recommend the same amount of washout as on the full size aircraft
They seem to be very forgiving planes. Even with one engine out:
http://www.airliners.net/photo/Aero-Commander-680E/1479466/L/
< Message edited by Leo -- 2/4/2010 7:35 PM >
Hide Signatures
       Post #: 57
RE: Shrike flight report - 2/22/2010 4:32 AM
ghost flyer
Score: 100
Last Login: 3/8/2013
Status: offline
I just got an Aero Commander at an auction. I believe it might be a Bridi Shrike. It has a 78 inch wingspan and is about 56 inches long. Fiberglass fuse. I was wondering what the CG and throws would be on this bird?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 58
RE: Shrike flight report - 2/22/2010 5:36 AM
ram3500-RCU
Score: 145
Status: offline
Can't help as I sold my kit, but I just wanted to say, looks like someone did a fine job on that one.
Cheers,
Gary P. / use Steel Powder for ballast not lead. PM me for more information.
Hide Signatures
(in reply to ghost flyer)
       Post #: 59
RE: Shrike flight report - 2/22/2010 6:34 AM
jetfixr
Score: 100
Status: offline
I think I have a copy of the plans for that airplane. I will check later tonight and see if I can get you that information. Great looking airplane!
Hide Signatures
       Post #: 60
RE: Shrike flight report - 2/22/2010 6:53 AM
Patto
Score: 103
Last Login: 3/17/2013
Status: offline
Yeah, someone appears to have really put a lot of time into that plane, based on the pictures. Very cool!
Hide Signatures
       Post #: 61
RE: Shrike flight report - 2/24/2010 6:42 AM
ghost flyer
Score: 100
Status: offline
There are even curtains on the windows and an instrument panel with gauges. The paint job is like glass. Wish iy had retracts. Sadly though there is some hanger damage.
Ghost Flyer
Hide Signatures
(in reply to Patto)
       Post #: 62
RE: Shrike flight report - 2/24/2010 7:01 AM
jetfixr
Score: 100
Status: offline
Sorry it took so long to get back to you. The plans show the CG to be 76mm back from the leading edge of the wing, however I don't see any control surface throws on them. They must be in an instruction manual somewhere. Hope this helps.
Jeff
Hide Signatures
       Post #: 63
RE: Shrike flight report - 2/24/2010 7:28 AM
ghost flyer
Score: 100
Status: offline
Thanks a bunch, It helps a lot.
Hide Signatures
       Post #: 64
RE: Shrike flight report - 2/24/2010 7:31 AM
jetfixr
Score: 100
Status: offline
No problem! Are you going to be able to get video when you fly it?
Hide Signatures
       Post #: 65
RE: Shrike flight report - 2/25/2010 3:58 AM
ghost flyer
Score: 100
Status: offline
I need to find a good OS .46 FX first. The engines that were in it are OS 40 MAX V engines which are rear exhaust and won't work in it. I have one good OS .46 FX and as soon as I lay my hands on a second one I can start on it. It was definitely built to be a display plane as no pushrod is going to the front wheel. Video from the cockpit OK?
Ghost Flyer
Hide Signatures
       Post #: 66
RE: Shrike flight report - 2/25/2010 8:07 AM
jetfixr
Score: 100
Status: offline
That would be awesome!
Hide Signatures
       Post #: 67
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.344RCU1
