Deception Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> Deception Build
Page: [1] 2 3 4 5 6 7 8 9   next >   >>
Login
Deception Build - 1/14/2010 7:57 PM
edp
Score: 100
Last Login: 6/18/2013
Status: offline
Well the work bench is clean. I just finished up the Miles Reed Fun Fly this morning. I builds just like any Bridi kit. Glue four blocks together and carve an airplane. I have the wing and stab sheeting edged and glued. I laid out the fin/rudder parts and have a few fit issues which are easy fixes. I am not using any CA as it is to hard to plane, carve or sand.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Ed Peel AMA 2680 NECPO#58
Alliance Balsa Bees Inc #492
Hide Signatures
       Post #: 1
RE: Deception Build - 1/14/2010 11:09 PM
KLXMASTER14
Score: 105
Last Login: 6/19/2013
Status: offline
Very tastefully done colors on the "Fun Fly". Can't wait to see what do do with the Deception.
-Robert
2012 NSRCA D7 Intermediate Champion
West Coast Regional Director- Classic Pattern Assn
Hide Signatures
(in reply to edp)
       Post #: 2
RE: Deception Build - 1/14/2010 11:13 PM
KLXMASTER14
Score: 105
Status: offline
Deleted- double post.
Hide Signatures
(in reply to edp)
       Post #: 3
RE: Deception Build - 1/14/2010 11:32 PM
edp
Score: 100
Status: offline
I'm going to try to follow this scheme from my old Tiporare. It is Red, White and Blue of course.
Click for fullsize
Hide Signatures
(in reply to KLXMASTER14)
       Post #: 4
RE: Deception Build - 1/14/2010 11:53 PM
Bill P
Score: 100
Last Login: 6/21/2012
Status: offline
I FOUND IT.   BP Jr.
Hide Signatures
(in reply to edp)
       Post #: 5
RE: Deception Build - 1/15/2010 1:24 AM
doxilia
Score: 136
Last Login: 6/20/2013
Status: offline
Hey Ed,
nice thread start. Look forward to following. You must have got my PM...
I wonder what was forbidden in that previous Tipo/Deception thread?
David.
Hide Signatures
(in reply to Bill P)
       Post #: 6
RE: Deception Build - 1/15/2010 2:12 AM
edp
Score: 100
Status: offline
I don't know. Maybe because I started a build thread or said the "E" word. Anyhow, the skins are done and on the cores in the husks for overnight cure. I used 30 minute finishing resin w/ milled fibers. I fixed the gaps on the rudder and fin and are also setting overnight.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to doxilia)
       Post #: 7
RE: Deception Build - 1/15/2010 2:59 AM
doxilia
Score: 136
Status: offline
Cool.
Do you do all the retract, aileron servo stuff after applying the skins? Everyone has their unique methods which makes the CPF just great!
David.
Hide Signatures
(in reply to edp)
       Post #: 8
RE: Deception Build - 1/15/2010 3:52 AM
edp
Score: 100
Status: offline
Yes, I'll put both aileron servos in the center section and use the torque tubes. I have done this on all my pattern birds. To me it just looks nice and neat. I'll also post on how I do my retract plate install.
Hide Signatures
       Post #: 9
RE: Deception Build - 1/15/2010 4:13 AM
doxilia
Score: 136
Status: offline
I did that on a little electric Tipo and the setup worked nicely. Especially good if the gear gets held up!
What was the problem with the fin/rudder. I'll have to watch for that in my kit.
Nice birds all the Bridi kits but not the best in QC or wood stock.
David.
Hide Signatures
(in reply to edp)
       Post #: 10
RE: Deception Build - 1/15/2010 4:22 AM
edp
Score: 100
Status: offline
Zoom in on the rudder/fin assy. I added 1/16 to the rudder to bring the front half to even. I add a piece of 1/16 and 3/32 to the fin to fill that gap. Will be shaping it in the morning. Also they are not the same thickness some fat 1/2".
Hide Signatures
       Post #: 11
RE: Deception Build - 1/15/2010 4:59 AM
doxilia
Score: 136
Status: offline
See better what you mean. Hadn't realized you had things lined up per plan.
Hide Signatures
(in reply to edp)
       Post #: 12
RE: Deception Build - 1/16/2010 1:17 AM
edp
Score: 100
Status: offline
Here is an update. The fin and rudder are shaped and ready for hinging. Not sure if I'm going w/ live hinge, Klett lg. hinges or Robart hinge points. The wings and stab are sheeted, dihedral has been sanded in the wings. I will cap the wing tonight and the stab left as is for now per plan. You use the stab core as a layout for the opening in the fuse.. And yes, I have three workbenches to build on. The two against the walls are attached to the wall and are very firm, flat and straight.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Deception Build - 1/16/2010 2:06 AM
doxilia
Score: 136
Status: offline
Nice work.
I never did understand Jim's note on the stab for the fuse side cutout. I mean, the stab is symmetric about the root - zero dihedral except for taper on either side. The cutout needs to be slightly smaller than the size of the capped stab but not much. Certainly not the dimensions of the sheeted core without the LE/TE's attached. In any case, there is also the FG cloth to take into account if so desired. I can't recall if Jim suggests something for that joint. I used glass cloth to the fuse sides on the stab and to the fairings on the wing.
I guess a cut is a cut.
Ed, your B&D's must be pneumatic, right? If not, I need to see how you do this.
David.
Hide Signatures
(in reply to edp)
       Post #: 14
RE: Deception Build - 1/16/2010 2:33 AM
edp
Score: 100
Status: offline
Dave
You glass the center section w/ 3 oz. glass. I will glass the whole stab w/ .6 oz. before it put it in. This way all I have to do is make a fillet. The B&D's are air driven. I'll put in Robart air restrictors to keep them from slapping up and down.
Hide Signatures
       Post #: 15
RE: Deception Build - 1/16/2010 3:15 AM
doxilia
Score: 136
Status: offline
Right,
I was trying to address the delayed stab finishing recommendation. I saw no need for it nor did it make much sense in my build.
Sounds like we'll have a fully painted Deception - great!
David.
Hide Signatures
(in reply to edp)
       Post #: 16
RE: Deception Build - 1/16/2010 6:54 AM
pitstop000
Score: 105
Last Login: 6/16/2013
Status: offline
Nice to see another DECEPTION being built.
What a great plane, Flew my 2 with Black head SE Rossi’s back in the day.
You will definitely enjoy this plane, I did. Will be following your build.
Paul Pappas, AMA 42520
www.NECPO.org
Hide Signatures
(in reply to edp)
       Post #: 17
RE: Deception Build - 1/16/2010 8:05 AM
edp
Score: 100
Status: offline
Thanks Paul
I have the LE and TE capped. I like the GP glue I'm using. I spread a light coat on both the caps and wing. I had to move one a little and it didn't want to pull apart after 2 minutes. I also included a few shots of my Bob Smith T2A I'm finishing up. I lost intrest in it a while ago as I was in the rubbing out phase. It will have a Enya .60 Chrome Mk IV AAC w/ the 10mm carb in the nose.
Ed
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to pitstop000)
       Post #: 18
RE: Deception Build - 1/17/2010 3:28 AM
edp
Score: 100
Status: offline
Back to it. Wings are capped and tips glued in place.
Dave, this is how I mount my gear in foam wings. I will cap the plate with 3/32" balsa to keep the gear flush w/ the bottom of the wing. The wing is sheeted with 1/16" balsa. It was actually some pretty light stuff. but the tips and fuse. top block is another story. May have to get out the 40 grit.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to edp)
       Post #: 19
RE: Deception Build - 1/17/2010 4:55 AM
pitstop000
Score: 105
Status: offline
Ed,
Moving along nicely, I must say.
All you guys that take the time to do a build thread need to be commended.
I can’t fathom doing a build with the picture taking and commentary that you guys do.
Maybee someday if my computer skills get better I’ll give it a shot.
I have to comment on the T2A, just superb. Nice Job.
www.NECPO.org
Hide Signatures
(in reply to edp)
       Post #: 20
RE: Deception Build - 1/17/2010 5:44 AM
doxilia
Score: 136
Status: offline
quote:
ORIGINAL: edp
Dave, this is how I mount my gear in foam wings. I will cap the plate with 3/32'' balsa to keep the gear flush w/ the bottom of the wing. The wing is sheeted with 1/16'' balsa. It was actually some pretty light stuff. but the tips and fuse. top block is another story. May have to get out the 40 grit.
Ed,
nice and classic. I was going to say, just by looking at the wings, you can see that the wood is pretty good. A quick browse of my kit revealed some pretty scary pieces of wood! I'll probably make use of them as lead weights for builds...
Both of my Tipo kits had some rock hard ailerons (3 of 4) also heavy as lead. In one of them, the left aileron weighed twice as much as the right! I plan to drill them out so I used them anyway and at least they should be less warp prone.
At first I thought you had mechanical B&D's and I was really curious to see how you would get those into a skinned wing - still doable but a lot harder. Do you use balsa for the wells or ply? I saw someone use those bendable straws for kids as a conduit for the lines - it was pretty cool actually. Tiny hole entering the well. But I guess running the lines parallel and above the wells might be even more elegant.
Maybe you can make some canoes out of the tips once they are carved to shape. Or drill them out from the bottom - good way to add tip weight when balancing.
I guess I'm seeing my Deception being built vacariosly through your thread! Sorry.
Keep up the nice work.
David.
Hide Signatures
(in reply to edp)
       Post #: 21
RE: Deception Build - 1/21/2010 11:32 PM
edp
Score: 100
Status: offline
Well, I got that pesky work week out of the way. The tips are on and rough shaped until I fit the ailerons. They didn't weigh that much after I pre trimed them. This is how I make ply LG mounts for foam wings. The dowels fit into pockets and the plate is epoxied in. I will cover it over w/ 3/32" to make the gear flush with the skins. I have been thinking af putting anhedral in the stab after reading the "Superception Thread". I know the Tipo liked it for knife edge. I can add the 1/4" per side with larger fillets for the fin.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 22
RE: Deception Build - 1/22/2010 12:15 AM
doxilia
Score: 136
Status: offline
Ed,
Superception mods would be very interesting. My first reaction to the thought of an anhedral stab (aside from Jim saying "don't do it!" in his original article - he must have later...), was the tolerance for up elevator if keeping the rudder/elevator relationship per plans. With anhedral, the inner elevators would likely interfere with the rudder unless they were opened up in typical pattern fashion (cut at an angle).
Of course, a full height rudder would also be an option (again, despite Jim saying not a "good idea") along with the fuse faired fin LE. It seems to me that a simple built up "Tipo like" fin (3/32" or 1/8" angled sides) would be easier and cleaner than building up with heavy fillets on a slab fin but both are viable I suppose.
I guess the issue with anhedral stabs is cross-wind.
Great work!
David.
Hide Signatures
(in reply to edp)
       Post #: 23
RE: Deception Build - 1/22/2010 12:30 AM
edp
Score: 100
Status: offline
The easier mod would be the stab and elevators. I can clip the inside edge like the Tipo. and leave the fin alone. Plus a anhedral stab does have a "look at me" effect at the field. I almost took the anhedral OUT of my third Tipo to see what the effects would be. As for cross winds, we have them a lot at our field and are well versed on how to correct for them. Winds East or West are rare for us. They always seem to be a quartering type. We fly from a full scale airport so we can adjust our position in or out a little.
Hide Signatures
       Post #: 24
RE: Deception Build - 1/22/2010 1:56 AM
doxilia
Score: 136
Status: offline
I look forward to seeing the changes.
David.
Hide Signatures
(in reply to edp)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.547RCU1
