RE: ESM LA-7 From VQ Warbirds    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: ESM LA-7 From VQ Warbirds
Page: <<   < prev  21 22 [23] 24 25 26 27 28 29 30   next >   >>
Login
RE: ESM LA-7 From VQ Warbirds - 9/12/2012 5:14 AM
Orvis
Score: 100
Last Login: 12/13/2012
Status: offline
Also, I see a few who installed the false radial engine inserts in their La-7, but has anyone attempted the engine coolingl fan as found in the real La-7?
Cheers,
Peter
Hide Signatures
(in reply to Orvis)
       Post #: 551
RE: ESM LA-7 From VQ Warbirds - 9/12/2012 4:28 PM
Joespeeder
Score: 105
Last Login: 5/24/2013
Status: offline
Hey Peter,
The LA-5/7 did not have a cooling fan.... I' thought it did and you can find lots of statements about the "fan" from people mentioning it but when you really look at it and dig you'll find it what looks like a fan is actually a sliding vent that opens when needed.
This video is the best example I can find of the bit you're talking about. Look at 5:30 - 6:00 in this video.
That Gene Barton Spinner fills the nose up pretty good. I don't think I'll need a fan/vent/dummy motor as much as I like the look of those things. The look will be correct and not leave a huge hole like you might think.
Hope that helps.
Joe
< Message edited by Joespeeder -- 9/12/2012 5:16 PM >
Hide Signatures
(in reply to Orvis)
       Post #: 552
RE: ESM LA-7 From VQ Warbirds - 9/12/2012 5:11 PM
glazier808
Score: 291
Status: online
Correct Joe,
They were more of a shutter, that could be opened or closed as needed. Looks like a fan when it's in it's open position though I guess.
Casey
_____________________________
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to Joespeeder)
       Post #: 553
RE: ESM LA-7 From VQ Warbirds - 9/12/2012 6:53 PM
Orvis
Score: 100
Status: offline
Huh, imagine that. I always thought it was a fan like the FW-190; even the "blades" looked like they have pitch on them.
Thanks for the correction guys.
Now that you all have stated so, I see in a couple of Google pictures where the vents are fully closed. I should have clued in because it was only in August when I was a local airshow and there were 2 Nangchang CJ-6s on display which have the same cowl vents.
Good to know that Gene's spinner will cover in most of the cowl.
Cheers,
Peter
Hide Signatures
(in reply to glazier808)
       Post #: 554
RE: ESM LA-7 From VQ Warbirds - 9/13/2012 11:52 PM
aminklein
Score: 100
Last Login: 5/9/2013
Status: offline
Regarding installation of the engine on the LA-7, the instructions state to install the engine right on the center of the firewall (i.e. with the propeller/crank shaft directly over the center hole in the firewall).  I plan on using a DLE 35RA engine.  Should I install this engine slightly above the center of the firewall to counteract the tendancy to climb?  Or should I just follow the instructions and put it right on center?  If anyone has had any experience, please let me know.  Thanks   Art M
Hide Signatures
(in reply to Orvis)
       Post #: 555
RE: ESM LA-7 From VQ Warbirds - 9/17/2012 6:21 PM
Orvis
Score: 100
Status: offline
Folks,
I am thinking of purchasing the electric retracts for the LA-7  from LikesLine Retracts. does anyone have experience with these? Qaulity and reliabiliy?
http://www.thelikesline.com/
Cheers,
Peter
Hide Signatures
(in reply to aminklein)
       Post #: 556
RE: ESM LA-7 From VQ Warbirds - 10/19/2012 10:03 PM
stuka
Score: 100
Last Login: 5/20/2013
Status: offline
So whats the consensus on motor choice. Should I go with a DLE 35 or a 55? I am thinking about getting one and would like to see what you guys think. Thanks
Hide Signatures
(in reply to Orvis)
       Post #: 557
RE: ESM LA-7 From VQ Warbirds - 10/20/2012 2:01 AM
rcfan450
Score: 100
Last Login: 4/17/2013
Status: offline
I went with the XYZ 53cc twin mostly for smoothness. If I wasn't worried about smoothness, I'd go with the 55. It says right in the instructions and on TBM's website that the model is inherently tail heavy and needs a little weight up front. Might as well be weight that gives you something vs dead weight in my opinion.
BUT... I'm just unpackaging mine and starting the build - so what do I know....
Mine will be heavy. Air retracts, 53cc, smoke system, cockpit. We'll see how it goes I guess.
Hide Signatures
(in reply to stuka)
       Post #: 558
RE: ESM LA-7 From VQ Warbirds - 10/20/2012 8:07 AM
Kiwi Bandit
Score: 100
Last Login: 4/23/2013
Status: offline
RCFAN450 is correct. If you have to add weight - make it do something. No model that I know of has ever crashed due to TOO MUCH POWER javascript:void(AddText(' ','_image/s4.gif'))
I have the Saito 325 radial in mine which is quite heavy. I did not require any additional weight to get the c.o.g. correct. I was able to use my flight power packs to fine tune the balance over a few flights to get the bird flying with the feel I preferred. my A.U.W is close to 24pounds. It`s no lite weight but it flies nice and with plenty of speed.
Hide Signatures
(in reply to rcfan450)
       Post #: 559
RE: ESM LA-7 From VQ Warbirds - 10/20/2012 9:53 AM
Prekin
Score: 101
Status: offline
My La-7 flew with the ROTO 35V and now I flying with ROTO 35Vi. I saw it with the XYZ 26, but it hasn´t power reserve. In my opinion if you want to have realistic fly, you should use engine between 30-45ccm. With bigger engine it will be acrobatic special.
Hide Signatures
(in reply to Kiwi Bandit)
       Post #: 560
RE: ESM LA-7 From VQ Warbirds - 10/21/2012 1:57 AM
stuka
Score: 100
Status: offline
I hear the spinners are no longer available. What are you guys doing about that. Thanks
Hide Signatures
(in reply to Prekin)
       Post #: 561
RE: ESM LA-7 From VQ Warbirds - 10/21/2012 6:30 AM
smullis
Score: 100
Last Login: 5/16/2013
Status: offline
stuka, I just bought a MPI 5" 3 Blade spinner. Perfect fit. I then painted the spinner flat red with Testors spray enamel. Part#1250 also a perfect match for the plane. S Mullis
Hide Signatures
(in reply to stuka)
       Post #: 562
RE: ESM LA-7 From VQ Warbirds - 10/21/2012 12:29 PM
stuka
Score: 100
Status: offline
smullis
Excellent Thanks for the idea.
Hide Signatures
(in reply to smullis)
       Post #: 563
RE: ESM LA-7 From VQ Warbirds - 10/24/2012 5:37 PM
rcfan450
Score: 100
Status: offline
Hey guys, I'm finally building my La-7.
I don't want to use control horns that protrude through the other side of the aileron and have simply screwed the horns into the aileron and flaps on one side (hardened the holes with CA, CA'd the screws in even after that). What have you guys done?
For electric I wouldn't worry at all, but mine is gas and I'm kinda wondering if I shouldn't just stick the dumb rod all the way through the wing and go that route instead. It just doesn't look scale. Thoughts?
Hide Signatures
(in reply to stuka)
       Post #: 564
RE: ESM LA-7 From VQ Warbirds - 10/24/2012 6:10 PM
rcfan450
Score: 100
Status: offline
Here's what I'm talking about. Nevermind, the picture thing wouldn't work, getting some sort of error.
I've pulled really hard (harder than I should have probably) on the horns and they all seem really strong so I'm going to fly it this way. Mostly just curious if anyone else here has done the same. I would be less comfortable if the ailerons were bigger but I have 40 sized planes with bigger ailerons than this thing secured the same way.
Hide Signatures
       Post #: 565
RE: ESM LA-7 From VQ Warbirds - 10/24/2012 6:36 PM
AZThud
Score: 100
Status: offline
That is what I did with mine, I used the 3 point Hanger 9 control horns and drilled and hardened the holes, then cut away the covering and glued and screwed them in.   I have done this on other planes and the only problem I have had is removing them :-)     Who knew that the glue actually works!
Cheers
Hide Signatures
       Post #: 566
RE: ESM LA-7 From VQ Warbirds - 10/24/2012 6:46 PM
rcfan450
Score: 100
Status: offline
I didn't remove the covering and glue it, but I could easily. Just one more step to make sure I'll never get it off ... or it won't vibrate off. Thanks for the reply AZThud.
Hide Signatures
(in reply to AZThud)
       Post #: 567
RE: ESM LA-7 From VQ Warbirds - 10/26/2012 3:51 PM
rcfan450
Score: 100
Status: offline
Well I got the cockpit done. I probably could have built the plane with the same amount of time I spent on the cockpit, it was fun though.
I'll be surprised if half these parts still exist after the first few flights with a gas motor.
I'll also be surprised if the gunner sight survives past me building building the plane. I'm pretty sure I'm going to forget it's there and set the plane on it while working on something else.
Now I need a russian to pilot this thing!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 568
RE: ESM LA-7 From VQ Warbirds - 10/26/2012 7:59 PM
LA7flier
Score: 100
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: rcfan450
I wouldn't worry too much how they look on the ground. You can't see them in the air. The wing is "stretched" for lighter wing loading and easier flying so it is not truly scale anyway.
The plane is a great flier but check both wing and stab incidence and get them as close to zero as possible. Out of the mold, the plane will climb.
Hide Signatures
       Post #: 569
RE: ESM LA-7 From VQ Warbirds - 10/26/2012 8:01 PM
LA7flier
Score: 100
Status: offline
quote:
ORIGINAL: smullis
stuka, I just bought a MPI 5'' 3 Blade spinner. Perfect fit. I then painted the spinner flat red with Testors spray enamel. Part#1250 also a perfect match for the plane. S Mullis
Hopefully, your spinner was more true than the MPI 5" spinner I bought.
Hide Signatures
       Post #: 570
RE: ESM LA-7 From VQ Warbirds - 10/26/2012 8:27 PM
rcfan450
Score: 100
Status: offline
quote:
ORIGINAL: LA7flier
quote:
ORIGINAL: smullis
Hopefully, your spinner was more true than the MPI 5'' spinner I bought.
Speaking of spinners, TBM has some. Just ordered a red one.
Hide Signatures
(in reply to LA7flier)
       Post #: 571
RE: ESM LA-7 From VQ Warbirds - 10/26/2012 8:28 PM
pilotorc4
Score: 100
Status: offline
If you want a full body pilot you will have to do what I did.
check out my posts on pg. 11
all the parts I used were found on e-bay and I have a list of the accesories I purchased on one of those posts, there are also pictures of WWII Rusian pilots I used to try to duplicate the pilot.
I failed to take pictures of the finished pilot once I had found the right accesories for it but these pictures show what it looked like before I changed the parachute and the head gear.
also on e-bay there is a guy that sells the RUsian pilot uniform insignias in 1/6 scale.
your cockpit looks great by the way.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 572
RE: ESM LA-7 From VQ Warbirds - 10/26/2012 8:38 PM
rcfan450
Score: 100
Status: offline
Thanks pilot, I'll keep my eyes out on ebay. I went there once and saw one I really like, but it was $120. So... still looking. I don't mind piecing it together if I have to, would be nice if there was a good authentic russian out there but they don't seem to be too popular.
Hide Signatures
(in reply to pilotorc4)
       Post #: 573
RE: ESM LA-7 From VQ Warbirds - 10/26/2012 9:03 PM
pilotorc4
Score: 100
Status: offline
check this items out on e-bay.
item # 290789385654 chinese pilot, this has most everything you will need and even the flight helmet could be used.
item# 251162012656 gogles
item# 170656607072 insignias
I cant find the parachute right now nor the leather flight cap
you will need the parachute form one of the U.S.navy 1/6 scale and the flight cap from either the 1/6 IJN pilot or the Crazy Dummies 1/6 german pilot, they come up for sale every now and then. you'll have to keep an eye out for them.
Hide Signatures
       Post #: 574
RE: ESM LA-7 From VQ Warbirds - 10/26/2012 9:27 PM
rcfan450
Score: 100
Status: offline
Thanks for the tips!
Hide Signatures
       Post #: 575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.578RCU1
