ESM LA-7 From VQ Warbirds    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ReDUCED Balsa USA Fokker DR-1 Triplane - 1/3 Scale - Kit
Seller:  JSZ
Details:   $1,500.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> ESM LA-7 From VQ Warbirds
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
ESM LA-7 From VQ Warbirds - 1/15/2010 9:48 PM
fockewulf37
Score: 111
Last Login: 5/9/2013
Status: offline
UPS ran early today. They just dropped off the New ESM LA-7. I was excited to open the box the see how it looked.. There was no damage to the outside box and everything looed good inside. I put it together right quick to get a look at it. I plan on making this one electric with an Efllight 160. It should make it really go...
The first thing I will do is make nthe cockpit kit then finish the plane.....
Ty
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
tysplanes.com
food for thought:''''If the enemy is in range, so are you..''''''Tracers work both ways.''''
Hide Signatures
       Post #: 1
RE: ESM LA-7 From VQ Warbirds - 1/15/2010 10:17 PM
jmohn
Score: 114
Last Login: 2/26/2012
Status: offline
Nice! Mine is in the mail too, but coming farther west so maybe tomorrow or Monday.
Can you get me the cowl diameter and depth so I can see if my engine will fit? Otherwise I may go electric too.
What are you planning on doing for gear? Sierra is working on some scale gear for it which I was planning on purchasing.
Jeff
Courage is what it takes to stand up and speak; courage is also what it takes to sit down and listen.
Hide Signatures
(in reply to fockewulf37)
       Post #: 2
RE: ESM LA-7 From VQ Warbirds - 1/15/2010 10:49 PM
fockewulf37
Score: 111
Status: offline
Yes I have talked to Darrell about the Gear. I'll get a set when they are ready,
The cowl ius 9.25" in daimeter. The depth appears to abe about 6.25 from the firewall to the front. The instruction are not really clear..
There is no spinner ready available.
Is there anyone interested in a scale spinner? I currently have spinners made for the CMP ME 109 and I can have scale spinners forn the LA-7 in about 4-5 weeks..The spinner is 4.5" in diameter.
Ty
Click for fullsize
tysplanes.com
Hide Signatures
(in reply to jmohn)
       Post #: 3
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 12:03 AM
Evil_Merlin
Score: 132
Last Login: 9/29/2011
Status: offline
Ty, sometimes I hate you... OH crap I still owe you cash too... *sigh* I shouldn't have even responded!
Hide Signatures
       Post #: 4
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 12:19 AM
jmohn
Score: 114
Status: offline
Ty,
Great....Thanks for the dimensions! Looks like I will need to move the firewall back to fit the Saito 36 in
Oh well, at lease it won't stick out of the cowl. Let me know when the cockpit kits are ready
How is the rudder and tail wheel setup on this one?
Jeff
Hide Signatures
(in reply to Evil_Merlin)
       Post #: 5
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 12:23 AM
fockewulf37
Score: 111
Status: offline
Rudder is perdrilled but you have to drill the trailing edge of the vertical for the hinge. I would most likely change to the larger robart hinge myself especially if i were using a gas motor. The cowl slips over the fuse and it is a little adjustable if you want. So you may be able just to move the cowl a little forward....
Ty
tysplanes.com
Hide Signatures
(in reply to jmohn)
       Post #: 6
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 12:31 AM
jmohn
Score: 114
Status: offline
Ty,
Sounds great! Get those cockpits kits going so I can get one from Thomas
Jeff
Hide Signatures
       Post #: 7
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 12:32 AM
fockewulf37
Score: 111
Status: offline
I did not say earlier but the boxes are backed very neatly. I only think you would see dama if the carrier would have sometype of crush of the box. Everything is in nice small bags...
Ty
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
tysplanes.com
Hide Signatures
       Post #: 8
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 12:43 AM
jmohn
Score: 114
Status: offline
Where do the flap servos go? It looks like there is no hatch on the bottom of the wing so they go on top inside the fuze?
That's nice if they do
Jeff
Hide Signatures
       Post #: 9
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 12:44 AM
fockewulf37
Score: 111
Status: offline
The instructions say there is another hatch on the bottom . I just have not looked at it closely enough yet...
tysplanes.com
Hide Signatures
(in reply to jmohn)
       Post #: 10
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 1:26 AM
jmohn
Score: 114
Status: offline
Too bad I would have liked is clean, but as long as it's a hatch that will work. It looks like this plane will be similar to a Bearcat or FW-190 in flying characteristics. I had one of the Alpha model LA7s, but that's not a good comparison as those are soooo light.
Looks great! It's going to turn some heads at the field for sure! What motor are you going with if you don't go electric? I may also go electric if I can't fit the Saito in the cowl. Does it look like it will need a lot of weight up front like the Bearcat?
I know too many questions, but I don't have mine yet
Jeff
Hide Signatures
       Post #: 11
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 1:36 AM
fockewulf37
Score: 111
Status: offline
I only do electric now days. Tired of the gas smell and loud noises.. Yes I am getting old...I will most likely fabricate a hatch on the bottm of the cowl to make battery changes easy...I have not had enough time to see about tail heavy yet. My first impressions its prety light...
Ty
tysplanes.com
Hide Signatures
(in reply to jmohn)
       Post #: 12
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 2:03 AM
jmohn
Score: 114
Status: offline
I hear you on the mess...I won't do glow anymore, but do like gas for the fact that I can get 15-20 minute flight times on planes. I am getting only about 6-7 minutes on electric and I like to fly more than that sometimes
Still electric is very easy and setup is simple too. Now with the new prices on batteries I may stay electric only in the future too. The batteries was what was holding my back from doing more electrics.
Jeff
Hide Signatures
       Post #: 13
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 2:13 AM
alanc
Score: 105
Last Login: 6/17/2013
Status: offline
All the kits come with the openings for the servos covered over, you cut away the covering, and fit the servos to the pre-painted ply covers-got to give you something to do!!! just feel for the hatches, i have just done this with the stuka, no problems,
Hide Signatures
(in reply to jmohn)
       Post #: 14
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 2:15 AM
fockewulf37
Score: 111
Status: offline
Well hobby city is comming out with some 6000 and 8000 mah packs this year. The 5800 mah 30c packs are only $89 right now. That will increase your flight times...
Ty
tysplanes.com
Hide Signatures
(in reply to jmohn)
       Post #: 15
RE: ESM LA-7 From VQ Warbirds - 1/16/2010 2:20 AM
jmohn
Score: 114
Status: offline
Yeah, I saw that! That would really make things nice! It may just make sense to sell all my gas stuff and go electric then I am currently using 2x 5000 mah 6S packs on my Power 160 motors which gives me 6-8 minutes depending on how I fly. That's just too short for me now and I am thinking of going with a Saito 36 on the LA7 because of this. If it won't fit in the cowl I will definately go electric. I hate having motors hang out of the cowl.
Jeff
Hide Signatures
       Post #: 16
RE: ESM LA-7 From VQ Warbirds - 1/18/2010 12:08 AM
Ram-bro
Score: 156
Last Login: 6/18/2013
Status: offline
what are the dimensions of the kit?
Hide Signatures
(in reply to jmohn)
       Post #: 17
RE: ESM LA-7 From VQ Warbirds - 1/21/2010 8:10 PM
fockewulf37
Score: 111
Status: offline
Specifications:
Wing Span: Approx 80" IMAA LEGAL !!!
Lenght: Approx 65" Flying Weight: Approx 16.5 lbs
Radio: 6 chnl. 8 Servos
Engine: 1.50 - 1.80 4-cycle Or equivalent 2-cycle
Gas Engine: 30cc-40cc
tysplanes.com
Hide Signatures
(in reply to Ram-bro)
       Post #: 18
RE: ESM LA-7 From VQ Warbirds - 1/21/2010 8:15 PM
fockewulf37
Score: 111
Status: offline
Well I just got back from a weekend out of tonw. The first thing I plan to do is install the cockpit. I had a really hard time trying to find something on the net about the cockpit and all along I have a book on the LA-7 in my Archives hidden away..It had a great drawing of the cockpit and even the instrument panel...
and even a layouit of the cockpit...
Ty
Click for fullsize
Click for fullsize
tysplanes.com
Hide Signatures
       Post #: 19
RE: ESM LA-7 From VQ Warbirds - 1/21/2010 8:31 PM
fockewulf37
Score: 111
Status: offline
The ESM LA-7 Is great for a cockpit. Plenty of room You only have to remove just a small portion of one former. I Had really been thinking about how to work with the area behind the cockpit. Radio compartment. There are several differt interuptation of that area . I decides to make an insert for that area and add a couple reaio boxes. I made a mold of the cuverature and then used that to make my mold of that area. I leave a 1/4" lip around the whole rear area and the compartment drops right in and matched the curvature perfectly. I then moved to the front cockpit. I make a basic mold of the area to test the fit. I pull the test one out of .020 ABS. I usually have several before i find what fits. This help me decide what needs to be added and get the size right...
Ty
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
tysplanes.com
Hide Signatures
       Post #: 20
RE: ESM LA-7 From VQ Warbirds - 1/21/2010 10:08 PM
lightning 759
Score: 100
Status: offline
hi ty
looking good i like the work on the cockpit.
was getting one of these but ordered retracts for the 109 i got off you.
haveing got one of your spinner,s for the 109 i know the ones you will get for this will be
first class so anybody thinking of getting one i think you will have to go a long way
to better ty,s
andy
Hide Signatures
       Post #: 21
RE: ESM LA-7 From VQ Warbirds - 1/22/2010 12:42 AM
jmohn
Score: 114
Status: offline
Let us know when you get the cockpits done so we can get one too
Jeff
Hide Signatures
(in reply to lightning 759)
       Post #: 22
RE: ESM LA-7 From VQ Warbirds - 1/22/2010 1:36 AM
matoran629
Score: 100
Last Login: 10/10/2012
Status: offline
Focke Wulf. Can you make a spinner for the ESM FW 190?
"I''d rather be on the ground, wishing I was in the air, than in the air wishing I was on the ground"
Hide Signatures
(in reply to jmohn)
       Post #: 23
RE: ESM LA-7 From VQ Warbirds - 1/22/2010 1:59 AM
jmohn
Score: 114
Status: offline
What diameter is the spinner? I used the ones from the Parkzone 109 on my Me-110 and it's perfect. Not sure if they will be the right size for the KMP 109. I think they are 3.5 inches diameter.
Jeff
Hide Signatures
(in reply to matoran629)
       Post #: 24
RE: ESM LA-7 From VQ Warbirds - 1/22/2010 2:02 AM
fockewulf37
Score: 111
Status: offline
What size is it???Diameter??
ty
tysplanes.com
Hide Signatures
(in reply to jmohn)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
