RE: ESM LA-7 From VQ Warbirds    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: ESM LA-7 From VQ Warbirds
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: ESM LA-7 From VQ Warbirds - 3/15/2010 10:38 PM
jmohn
Score: 114
Last Login: 2/26/2012
Status: offline
Kirt,
I used a special battery box that mounted on the firewall and the motor mounted to that. This got the CG too far forward and I had to add weight to the tail even with a servo in the tail for the retractable tail wheel. It's still a nice setup and allows you to change the batteries without removal of the wing. If you don't mind that a standard electric motor mount like from Hyperion or Hanger 9 would work fine with the batteries just inside the firewall inside the plane should put the CG about perfect.
Jeff
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Courage is what it takes to stand up and speak; courage is also what it takes to sit down and listen.
Hide Signatures
(in reply to k_sonn)
       Post #: 126
RE: ESM LA-7 From VQ Warbirds - 3/15/2010 11:31 PM
carlosemiliov
Score: 105
Last Login: 10/23/2012
Status: offline
hey jmohn which tailwheel retract did you us on it
thanks
Just fly and relax,,,,
Honduras, Central America
Hide Signatures
(in reply to jmohn)
       Post #: 127
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 12:58 AM
jmohn
Score: 114
Status: offline
I think it was a Dubro mechanical retract with an HS 225 servo for the retract part. Works great and adds some weight in the back where I needed it anyway. I couldn't fit a Robart air retract in the space so this was my second choice.
Jeff
Hide Signatures
(in reply to carlosemiliov)
       Post #: 128
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 7:53 AM
k_sonn
Score: 123
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: jmohn
Kirt,
Jeff
Hi Jeff,
Thanks for the info and photos.  I'll be using Thunder Power 40C 6500 mAh packs.  The 10S packs weigh 4 pouds and the 12S packs weigh 4.75 pounds.  I get 5 minute flights using these packs on my high-powered EDF jets that draw 125 amps.  I suspect I will get at least 8 minute flight times with the low amp draw of the E-Flite 160 or the AXI 5345.
Kirk
Schubeler USA Demo Team
"Schubeler - The Future Of Electric Jets"
Hide Signatures
(in reply to jmohn)
       Post #: 129
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 9:31 AM
karl hibbs
Score: 100
Last Login: 5/22/2013
Status: offline
hi kirk, if you don't mind who did you buy it from?....karl
Hide Signatures
       Post #: 130
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 6:30 PM
jmohn
Score: 114
Status: offline
Kirt,
That's what I was planning to, but don't have the larger packs yet. If you are going that route I would suggest sticking the batteries behind the firewall so you don't have to add too much weight to the tail. If you stick them out front like me you will have to add about 1 lb. of weight in the tail
Just stick it where the fuel tank was going and you may have to add a little in the nose, but probably much less than you would otherwise. Get the ESC, receiver pack in front of the firewall and you may be fine with no weight. Let us know how it goes. I may have to change my setup when I get the larger packs
Jeff
Hide Signatures
(in reply to karl hibbs)
       Post #: 131
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 7:12 PM
k_sonn
Score: 123
Status: offline
quote:
ORIGINAL: karl hibbs
Hi Karl,
It's the one you had.  I had to beg him to sell it to me.  I needed an IMAA legal plane to fly at Monroe and wasn't interested in an aerobat airframe.
Kirk
Hide Signatures
       Post #: 132
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 7:15 PM
k_sonn
Score: 123
Status: offline
quote:
ORIGINAL: jmohn
Kirt,
Jeff
Hi Jeff,
Thanks for the info.  Looking forward to seeing a flight report on yours.
Kirk
Hide Signatures
(in reply to jmohn)
       Post #: 133
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 9:15 PM
jmohn
Score: 114
Status: offline
I hope to do the maiden again this Sunday. Cross your fingers
Jeff
Hide Signatures
       Post #: 134
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 9:18 PM
carlosemiliov
Score: 105
Status: offline
we will be waiting for ur reports
have fun
Hide Signatures
(in reply to jmohn)
       Post #: 135
RE: ESM LA-7 From VQ Warbirds - 3/16/2010 11:48 PM
karl hibbs
Score: 100
Status: offline
Kirk, i talked to John smith and he is ready to fly his with an evolution....karl
Hide Signatures
       Post #: 136
RE: ESM LA-7 From VQ Warbirds - 3/24/2010 6:12 PM
carlosemiliov
Score: 105
Status: offline
quote:
ORIGINAL: carlosemiliov
have fun
hey guys i got my bird and the engine
here are some pictures any advise on the build would be appreciate
thnaks
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 137
RE: ESM LA-7 From VQ Warbirds - 3/24/2010 11:08 PM
LA7flier
Score: 100
Last Login: 5/20/2013
Status: offline
have fun
thnaks
Nearly ready for the maiden of my LA 7. I have the E-Flight 160 installed on 3 inch aluminum pylons and cut a hole in the firewall so the 10S pack can fit behind the firewall and still is flush with the firewall face. Since I am running A123 batteries, I plan to charge them in the plane so I will cut a relatively small hatch in the bottom of the cowl for access to the power leads and balancing tap. One thing I did find; the elevator cables did not crimp down securely. I found that despite using a crimping tool, the brass sleeves are too brittle and cracked. I have replaced them with copper (softer) and will put a dab of solder on for good measure.
I would like to hear from John about his second flight. I am surprised about his report of needing full down elevator to fly. That sounds like the horizontal stabilizer incidence may be wrong. If so, that is a major design/manufacturing mistake and would require major surgery to correct. Let's hope this is not the case!!
Hide Signatures
       Post #: 138
RE: ESM LA-7 From VQ Warbirds - 3/25/2010 1:09 AM
jmohn
Score: 114
Status: offline
Here's a couple photos of the plane on the ground before take off. Trying to get some in the air, but my photographer says they don't look good. I am hoping that they are good enough to see that attitude of the plane to see if it's a stab issue.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to LA7flier)
       Post #: 139
RE: ESM LA-7 From VQ Warbirds - 3/25/2010 1:34 AM
carlosemiliov
Score: 105
Status: offline
hey jmohn what engine did you place on your plane nice pics
Hide Signatures
(in reply to jmohn)
       Post #: 140
RE: ESM LA-7 From VQ Warbirds - 3/25/2010 9:07 PM
jmohn
Score: 114
Status: offline
I have an Eflite Power 160 motor in the plane with a dummy radial engine photograph that I mounted to some 8 mm foam and hot glued it inside the cowl. It looks pretty real from a distance.
Jeff
Hide Signatures
       Post #: 141
RE: ESM LA-7 From VQ Warbirds - 4/5/2010 2:59 AM
SU-31 flyer
Score: 100
Status: offline
quote:
Jeff mentioned it on bottom of page 2 . He used a Dubro retractable tail wheel..You may want to try this one its all self conatined and all you have to do is run airlines back to it. Its pretty lightweight and i have used it on planes up to 46 lbs...
Its one from B&D. Its the same one Yellow A/C uses. It has a small cylinder built into the retract...
http://bdretracts.com/products.htm#pneumatic_retracts
B&D0013 Nose Gear Forward Nose Only $39.95
Ty
FOCKEWULF37
Why did you say to use the nose gear B&D0013 and not the tail gear B&D0007 or B&D0008 at $30.95 or $35.95.
Hide Signatures
       Post #: 142
RE: ESM LA-7 From VQ Warbirds - 4/12/2010 10:57 PM
fw190
Score: 100
Status: online
Well, spring break was last week and so I managed to put my LA-7, together. I am using a RCGF 62 motor and the overall weight of 18lbs. The only mod I did was use two elevator servos and of course it needed a larger fuel tank 32oz, so I added another servo plate just behind the existing tray. Looking for a spinner for it but I might just use whatever is on my spare box. Hope to maiden it this week.
Happy Flying!
Hide Signatures
(in reply to SU-31 flyer)
       Post #: 143
RE: ESM LA-7 From VQ Warbirds - 4/13/2010 2:24 AM
jmohn
Score: 114
Status: offline
No updates for my LA7 as the weather is not cooporating out here
I hope to get a bunch of flights in on Friday and Saturday this week. I added some down trust in the motor as I suspect that was most of the problem with the plane wanting to climb while adding power. I checked horizontal stab and wing incidence and they were good.
Can't wait love this plane!
Jeff
Hide Signatures
(in reply to fw190)
       Post #: 144
RE: ESM LA-7 From VQ Warbirds - 4/17/2010 5:43 AM
davidbarth
Score: 100
Last Login: 4/17/2011
Status: offline
Hey Ty
got one of your cockpit kits for my LA-7.
Very nice work. It painted up very realistically and the videos were GREAT
Whats the status on the scale SPINNERS and will the be available in RED?
also any plans for a 3 blade prop and spinner option.
Hide Signatures
(in reply to fockewulf37)
       Post #: 145
RE: ESM LA-7 From VQ Warbirds - 4/17/2010 7:04 AM
fockewulf37
Score: 111
Last Login: 5/9/2013
Status: offline
David,
Thanks for the comments on the cockpit.
The spinners went out to Tomas on wednesday and he should have them the first of the week. They turned out really nice.
ty
Click for fullsize
Click for fullsize
Click for fullsize
tysplanes.com
food for thought:''''If the enemy is in range, so are you..''''''Tracers work both ways.''''
Hide Signatures
(in reply to davidbarth)
       Post #: 146
RE: ESM LA-7 From VQ Warbirds - 4/17/2010 9:34 AM
fw190
Score: 100
Status: online
Spinner looks great, will have to order mine if maiden goes well this Saturday. Thanks for getting them made Ty.
Any ideas on how well the CG placement is? I am about .25" forward of what is called for on the manual.
Happy Flying!
Hide Signatures
       Post #: 147
RE: ESM LA-7 From VQ Warbirds - 4/17/2010 6:30 PM
LA7flier
Score: 100
Status: offline
quote:
ORIGINAL: LA7flier
have fun
thnaks
I just bench ran my power setup on my LA 7. I ran WOT to get an idea of how much time I have. I got 3 minutes but only about 1000 watts. I may have to move up to Lipo's to get 2000 watts which is what I planned the power system to supply. Plan on ordering a new Progressive RC 1010 charger to handle 10 cell charges unless someone uses something better (which I would love to hear about)
Hide Signatures
       Post #: 148
RE: ESM LA-7 From VQ Warbirds - 4/17/2010 6:33 PM
jugman2
Score: 100
Last Login: 4/17/2010
Status: offline
Is ESM the same as KMP?
Will this plane fit a G62 in the cowl without sticking out?  Looks great...
Hide Signatures
       Post #: 149
RE: ESM LA-7 From VQ Warbirds - 4/18/2010 4:58 AM
LA7flier
Score: 100
Status: offline
quote:
ORIGINAL: jugman2
No ESM is also Troy Built Models...I think KMP is bit bigger....doubt very much that a G62 will fit in the cowl without cutting it up. Many are struggling to get a decent sized engine into the cowl without cutting anything. That is one reason I went electric
Hide Signatures
(in reply to jugman2)
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.281RCU1
