Use A Ruler to Evaluate The Definition of FPV and The Resolution of MMC-1105
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Aerial Photography and Video >> Use A Ruler to Evaluate The Definition of FPV and The Resolution of MMC-1105
Page: [1]
Login
Use A Ruler to Evaluate The Definition of FPV and The R... - 1/18/2010 12:11 PM
edimaeg
Score: 100
Last Login: 1/30/2010
Status: offline
1. Prepare a 50cm plastic ruler, place it vertically, and use your FPV close to the ruler then photograph it (note: the bottom of the camera screen should be above on the 0mm of the ruler). You should check if the picture can show clearly the millimeter marks on the ruler. If it cannot, you can try to take your camera more close to the ruler and adjust its focus to gain best result; otherwise you should put your camera a little farther from the ruler. If the picture can show clearly the millimeter marks, the maximum length (use millimeter to measure it) of the ruler shown clearly on the picture will be the real definition (term: vertical resolution) of your FPV. Certainly, you also can check its horizontal resolution by this method.
(1) The equipments with definition less then 300mm are low end or "Three NOs"(product without production date, certification or manufacturer name on it), so please check again the license on your product. These products are only use for security gate, MSN video or just a toy. We found many FPV players use this kind of products, which are cheap but its definition less than 200 TV lines.
(2) The common CCD video cameras generally employ PLA or NTSC analog TV standard, the theoretical highest definition of which is 576 TV lines or 480 TV lines. PLA or NTSC analog TV is just a standard; it has no relation to the production technology and product quality. That is, even the best equipments of this standard can not be clear as 570mm.
(3) There are different kinds of products in the market. Most of the wireless video cameras are made in China. And most of European hobbyists’ OSD equipments are made in China and Taiwan. Some are high-end and good quality. Some are low-end and bad quality. Some are flattered by their resellers as 400 TV lines, or even 600 or 800 TV lines. When you meet these profiteers sell these products, you should lodge a complaint to local consumer protection authority.
(4) There are also some equipments with analog lens, which are semi-digital and take digital circuit as its RF transmission circuit, like COFDM equipments. This kind of products is fairly high-end among common FPV equipments. They are very expensive and only used by some big agencies, seldom used by individuals. COFDM equipment can solve problems rise in transmission (for example, anti-jamming) and ensure quality signals transmission. But it has no contribution to the definition of picture. If I have not mentioned here, there are still many people haven’t known this kind of products.
2. The resolution of the digital video camera often applies index like 1280×1024, 640×480 or similar kind. You can check it from your MSN live chat video, it is maybe digital but with low resolution. The word of TV line is only used for analog CCD or COFDM equipments. For more convenient conversion, there are also some analog equipments adopt digital equipments’ method to identify their definition, for example, 720×576 (the theoretical highest definition of PLA equipments) is equal to 400,000 pixels of digital video camera.
The operator can feel free to change the definition of real-time video of MMC-1105. It can be 1280×1024 (1.3 Mega Pixels, equal to 1280mm for the ruler) as the highest definition as HDTV. It also can be 1024×768 as the standard definition of HDTV. And it is also can be set as 640×480, which is equal to the theoretical highest definition of CCD video camera.
Many people take equipments with 640*480 or DVD as High Definition equipments. It is totally wrong.
The above is only for reference. There is a famous Chinese saying, “Is it a donkey or horsejust come out and show us for a walk around”.
Anyway, welcome your comments.
Hope UAV companies, technical professionals and FPV fans to share with us more similar products. edimaeg at gmail dot com
http://www.edimaeg.com/camera.htm
Edimaeg Wireless Communication Co. Ltd
Hide Signatures
       Post #: 1
RE: Use A Ruler to Evaluate The Definition of FPV and T... - 1/30/2010 1:13 AM
edimaeg
Score: 100
Status: offline
Mini Size!
High Definition as HDTV!
Real-time Live Video Wireless Transmission!
Perfect for Aerial Photography, Law Enforcement and Military use!
MMC-1105 Micro High Definition wireless Camera must be the only one in the world which is micro in size but with super high resolution as HDTV.
For real time wireless monitor use, its resolution can be HDTV 1280×1024; its definition is 3-10 times as the equipments of former microwaves and COFDM. If use it for low altitude aerial photography, you can see clearly the brand name of the cigarette box on the ground don't need change the lens focus. For book photographing or evidence taking, at one time it can photograph clearly all the letters on 2-3 A4-sized papers. The above-mentioned performance of MMC-1105 is beyond the normal PAL/NTSC videography equipment can do, including some of the equipments for broadcast use.
Taking advantage of the most update 2.4GHz BroadRange RF blind-area compensable technology, in outside high mountains area or among congested urban buildings, the signal transmission of MM-1105 is much better than the equipments of microwaves and COFDM. Such as for aerial photography, the distance can be more than 10KM.
In fact, MMC-1105 is a Digital HDTV Wireless Camera. It is very different from common wireless cameras. All the performance indexes of MMC-1105 are beyond the common wireless cameras can reach. edimaeg at gmail dot com
The main advantage of MMC-1105 is that, it can attain super high resolution of video image, which is 3-10 times more than previous micro wireless cameras. MMC-1105 can allow the user to see the very details in the picture screen.
MMC-1105 has great value in military & civil use. If it is used to replace the airborne camera on TUAV ASN-15, its real-time video resolution can greatly surpass USA Raven and UK Desert Hawk, the video resolution indexes of the two latter ones will behind the TUAV with MMC-1105 more than one grade.
If used for police for real-time monitoring, the high definition picture of real-time video and later-recall video will greatly help the police to attain importance evidences and to solve the cases successfully.
Hide Signatures
(in reply to edimaeg)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
