RE: MT70CC TWIN    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: MT70CC TWIN
Page: <<   < prev  47 48 49 50 51 52 53 54 55 [56]
Login
RE: MT70CC TWIN - 10/24/2012 3:05 PM
mausolfh
Score: 100
Last Login: 5/21/2013
Status: offline
Brian, I have tried to get gaskets for the MT70, but none are available so I made my own. As for the bearings I would try BOCA bearings. I have had good luck with him finding rare sizes for me. The cir-clips may be available at a good auto parts store, not the chain stores but older independent ones. Some independent small engine shops that work on leaf blowers, weed wackers, etc may be able to help you out. I just re-ringed both of my MT70s with Bowman rings and had some gasket issues, but found material and made all I needed. Haven't run them in yet, but the static compression is way better than before, so hopefully they will improve.
Hide Signatures
(in reply to capitalB)
       Post #: 1376
RE: MT70CC TWIN - 10/24/2012 4:11 PM
BR1
Score: 100
Last Login: 5/22/2013
Status: offline
Brian
Circle clips are easy just find a dowel the same size as your wrist-pin, slit the end of the dowel with a saw blade. Then bend a right angle bend in some music wire (.020 or .025) slip it into the dowel and make one tight wrap and you have just made yourself a circle clip, its that easy. I hope this helps. I have done this on three or four engines now and refer to these clips as 400mph clips as that is how fast they can disappear.
Hide Signatures
(in reply to mausolfh)
       Post #: 1377
RE: MT70CC TWIN - 10/24/2012 4:46 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: capitalB
I have always laughed inside at the 40yr old CEO can't tune a engine with 3 moving parts. He looks down at the 22yr old auto-tech, who deals with more technology on a daily basis, then the Space-Shuttle techs (Trust me I know some of them) Not to mention the 22 tr old British Kid, who, under the Blitz, can keep a Rolls-Royce V-16 running happily..
Thats because he can,t count....add 2 more moving parts (most important ones)  the 2 fuel mix adjusting parts!
_____________________________
I never met a engine I did not like !
Hide Signatures
       Post #: 1378
RE: MT70CC TWIN - 10/24/2012 5:57 PM
alburman
Score: 100
Last Login: 10/27/2012
Status: offline
Here we go again. Read all the replies on page 29, and make your decision. My less then $500 MT70 engine cost me well in excess of that when I figured in the cost of all the mailing back to MT Engines trying to get it repaired. After the lat break down I finally sold it for parts. By the way, except for the mail back and forth to Florida, that engine never did get in the air. Good Luck!!!!
Al Burman
Hide Signatures
(in reply to 3DDino)
       Post #: 1379
RE: MT70CC TWIN - 10/25/2012 10:23 PM
capitalB
Score: 106
Last Login: 4/29/2013
Status: offline
I am only going thru this engine for maintenance and hopes of a bit more rpm. I was able to save the gaskets and cir-clips, but I still want to replace the bearings and rings.It would help alot if you had the part#s for the rings and bearings. Let me know if you have them, Thanks, Brian
The wind was so calm today,it was blowing backwards...Saito club member #703, F22 Driver
Hide Signatures
       Post #: 1380
RE: MT70CC TWIN - 10/26/2012 10:15 PM
mausolfh
Score: 100
Status: offline
Brian,
I don't have the part numbers for each, but Frank Bowman (ringmaster46@msn.com) has the MT70 rings in stock. They are not real expensive and he takes PayPal so the transaction is easy. As for the bearings I don't have a part number for those but you look on the bearings and give BOCA the numbers stamped on them and they can find them. You can go to the web site (bocabearings.com) for more information.
Hank
Hide Signatures
       Post #: 1381
RE: MT70CC TWIN - 1/7/2013 3:44 PM
mausolfh
Score: 100
Status: offline
Finally got around to putting new rings in the pair of MT70s I have. Initally after about a tank through them they turn around 7000 rpm each on the XOAR 22X10s and feel strong through transition. I haven't touched the reed blocks yet and may not have to. Hopefully they will continue to get better as the new rings break in.
Hide Signatures
       Post #: 1382
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: MT70CC TWIN
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
