unit53
Score: 105 Joined: 8/18/2009 Last Login: 10/18/2012 From: mojave desert,
CA, USA Status: offline
Today i found time to tinker,, when i discovered the bent crank ,i had to decide whether i wanted to see if a crank was available,,what i decided to do was seperate the front and back case flanges on the prototype case ,,which leaked like a sieve and i had given up on,,coated all mating surfaces with rtv and let set ,,i also filled in this weird spot that tommy had filled with a silicone piece with jb weld and shaped to look like it was made into the engine,,,instead of using the studs and nuts tommy suggested,,i found socket head allen bolts and had to grind the heads to allow clearance against the cylinders,and found lock washers to fit,,i carefully assembled using used gaskets and sealer on the cylinders ,,made a reed block gasket and used blue locktite on all bolts ,,cleaned up the plugs installed and the same with the sensor for timing ,i found this setup nice and smooth and not draggy ,,so i mounted the thing and to my surprise ,it didnt run too bad considering i still need to final set the timing and and carb which may have stiff parts due to additive type fuel and sitting up,,i used my rcexl tach and saw 7.6 k this is with a vess 22a open exhaust setup,,i will be using a 23 to 24 prop once in satisfied ,,,,i think i know how the crank got bent ,,,this is my best guess ,,,the previous owner got so frustrated ,,he unbolted the junk from his test bench and threw it in the corner.......i bet if he reads this post hes grinning and saying thats exactly what happened...so far no case leaks runs reasonably good ,,, not draggy ,,compression seens reasonable ,, rings need to set,,,even the one plug i pulled had a nice tan look,,will be using safety wire over the plug caps ,,one popped off and the engine continued to run on one plug,,we all know what that would have done to my radio,in the air.maybe i will see if anyone else has a 70 they have given up on,,i dont know if my concience would allow me to fix then and sell on ebay ,,but they will be ok for personal use.
Hide Signatures
