ProBoat PT 109 Leaks    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> ProBoat PT 109 Leaks
Page: [1]
Login
ProBoat PT 109 Leaks - 1/22/2010 11:23 PM
BP5589
Score: 100
Last Login: 1/15/2013
Status: offline
Hello,
I've had this boat for over a year now and recently got it on the water only to find that it leaks badly from the rear. I can't see where the leak is coming from and am hoping someone with more experience would have some ideas.
Bill
Hide Signatures
       Post #: 1
RE: ProBoat PT 109 Leaks - 1/23/2010 1:21 AM
Umi_Ryuzuki
Score: 105
Last Login: 4/2/2013
Status: offline
Probably water coming up the shaft tubes when the boat is running.
Pull the propeller shafts and put a little grease(white lithium grease) into the
stuffing tubes, and the put the shafts back in(and out, to work the grease around) and
see if that helps.
_____________________________
Nyow!
=^o^=
Hide Signatures
(in reply to BP5589)
       Post #: 2
RE: ProBoat PT 109 Leaks - 1/23/2010 3:29 AM
BP5589
Score: 100
Status: offline
Thanks UMI, I'll try that.
Bill
Hide Signatures
(in reply to Umi_Ryuzuki)
       Post #: 3
RE: ProBoat PT 109 Leaks - 2/18/2010 3:24 AM
ARMOR RABBIT
Score: 100
Last Login: 4/28/2013
Status: offline
HI i had the same problem i found the water was comeing up through the 3 rudder post . i pulled the rudders out and gressed them . it stop the water from comeing in .
Hide Signatures
       Post #: 4
RE: ProBoat PT 109 Leaks - 2/18/2010 5:43 AM
BP5589
Score: 100
Status: offline
Thank you, Armor, I will try that.
Bill
Hide Signatures
(in reply to ARMOR RABBIT)
       Post #: 5
RE: ProBoat PT 109 Leaks - 2/19/2010 6:37 AM
deckape
Score: 100
Last Login: 4/30/2013
Status: offline
ARMOR RABBIT IS RIGHT A GOOD FRIEND OF MINE HAD A LINDBERG PT 109 NOT AS GOOD QUALITY AS YOU BOAT WE TOOK IT TO THE GRAVEL PIT. OUT HERE IN OHIO THERE ARE A LOT OF PONDS MOST OF THEM ARE PRIVATELY OWNED AND DONT TAKE TO KINDLY FOR MODEL BOATERS. MOSTLY WE HAVE A LOT OF GRAVEL PITTS THESE PITS ARE MAN MADE AND GO AS DEEP AS 100 TO 200 FEET, WE TOOK HIS PT BOAT OUT FOR SEA TRIALS IT RAN QUITE WELL WHEN IT GOT OUT ABOUT 100 FEET OR SO THERE WAS NO RESPONCE TO RECIEVER THE BOAT TOOK ON WATER AND SUNK, THE STUFFING BOX,S AND RUDDER POST WERN,T SEALED CORRECTLY THIS MAYBE THE PROBLEM ON YOUR BOAT CHECK YOUR RUDDER POST AND GREASE WELL YOUR STUFFING TUBES AND YOU WILL BE GOOD TO GO AND TAKE ON THE POND.
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
