RE: VectorFlight 300s, anygood?
Tower Hobbies
Logged in as Guest
  Printable Version
30%EXTRA330L & DL50 combo - ARF
Seller:  peakmodel
Details:   $879.00   |  10/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: VectorFlight 300s, anygood?
Page: <<   < prev  20 21 22 23 24 25 26 27 [28] 29   next >   >>
Login
RE: VectorFlight 300s, anygood? - 7/8/2004 2:49:03 AM
IronCross
Status: offline
That's what I was hopeing for...
What size props are you using on the .91's ?...
15 percent fuel ?
Roger
(in reply to trroscoe)
       Post #: 676
RE: VectorFlight 300s, anygood? - 7/8/2004 9:12:55 AM
Dauntae
Status: offline
quote:
ORIGINAL: evfast
Has anybody flown the sukhoi yet? Thinking about getting one.
I have the Sukhoi with a Magnum 91 4-stroke in it and the Sukhoi flies great, It's like it's on rails but you need to keep the speed up a little on landings or it will drop a wing. I laterally ballenced it before flying so it's not bad at all but does need to keep the speed up. It's my most flown plane.
IronCross, I started with a 15x4 to get good climb and it worked great as a break to slow it down for landing until I got used to it and now I've been using a 14x6 and still has good vert.
Dauntae
< Message edited by Dauntae -- 7/8/2004 4:18:15 AM >
_____________________________
I used to think that the world was crazy and I was sane. I now realize I am crazy and the world is sane. Ah They will adjust
(in reply to evfast)
       Post #: 677
RE: VectorFlight 300s, anygood? - 7/8/2004 11:27:41 AM
evfast
Status: offline
D
I just order one last night, will keep you posted with the build.
thanks for the info
(in reply to Dauntae)
       Post #: 678
RE: VectorFlight 300s, anygood? - 7/10/2004 2:10:41 PM
IronCross
Status: offline
WOW
Doorbell rang and I found this big box on my front step.. My new 66 inch Extra was here.. What a beauty... I have been flying the 58 inch Extra and having a blast with it.. It has become my main plane.. Looks like the 66 inch Extra may replace it though.. Can't get over these great flying planes at these prices.. And fantastic customer service to go with the deal... I don't think CW ever sleeps..
       Post #: 679
RE: VectorFlight 300s, anygood? - 7/18/2004 1:56:19 AM
slow flyer
Status: offline
is saito 100 enough power for vectorflight 300
(in reply to Lean540)
       Post #: 680
RE: VectorFlight 300s, anygood? - 7/18/2004 2:20:47 AM
evfast
Status: offline
I will be putting in a saito 100 on my VF sukhoi, should be plenty of power.
(in reply to slow flyer)
       Post #: 681
RE: VectorFlight 300s, anygood? - 7/30/2004 4:20:26 PM
Matt 22
Status: offline
This thread is long and sorry if it's already been answered. I have an OS 61 FX and seriously looking to buy the 58". Wondering if I use this engine, will be under powered? If so, does anyone have any recommendations?
       Post #: 682
RE: VectorFlight 300s, anygood? - 8/14/2004 3:28:58 AM
TOFAST4U2C
Status: offline
I love my VF 66" Extra. But anyone find that if they fly to slow the extra tip stalls and wants to nose over??? Slow speed is ok at stright and level but dont use the ailerons. All throws are to instructions.
Born to CRUISE, Forced to Work!
(in reply to Matt 22)
       Post #: 683
RE: VectorFlight 300s, anygood? - 8/14/2004 4:19:21 AM
Miloh
Status: offline
My extra never had a problem with tip stall at any speed, How is yours balanced? Mine flew like a fast trainer.
Miloh.
"My life has a superb cast but I can't figure out the plot."
(in reply to TOFAST4U2C)
       Post #: 684
RE: VectorFlight 300s, anygood? - 8/14/2004 4:59:39 AM
David Cutler
Status: offline
If it always tip stalls in the same direction it might be laterally out of balance.
Try checking that.
Good luck!
-David C.
       Post #: 685
RE: VectorFlight 300s, anygood? - 8/15/2004 10:13:24 AM
SNIGGEMANN
Status: offline
Matt 22,
I have an OS 60 FP on my 58" Extra and it is no way under powered. So your 60 FX should be just fine.
Scott
(in reply to David Cutler)
       Post #: 686
RE: VectorFlight 300s, anygood? - 8/17/2004 4:04:04 PM
Matt 22
Status: offline
Scott, Thanks for the info. Just received it yesterday and I have say I'm impressed. It's certainly one of the better constructed ARFs I've seen. Instructions are weak....and would be hard for a first/second timer. Looking forward to getting this bird up.
Matt
(in reply to SNIGGEMANN)
       Post #: 687
RE: VectorFlight 300s, anygood? - 8/17/2004 8:41:07 PM
CHassan
Status: offline
ARRRGGGHHHHH where is mine?!!!!!!!!!!!
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy--
       Post #: 688
RE: VectorFlight 300s, anygood? - 11/12/2004 3:22:04 PM
Jetstud
Status: offline
How does the VF 58" Extra 300 perform with the Saito FA 80? Been looking for a long time for an A/C to mount the 80 on. Worried it might be a bit underpowered. I'd appreciate your opinion. Thanks!
Kurt
KNeils@calalpa.org
(in reply to SunShyne)
       Post #: 689
RE: VectorFlight 300s, anygood? - 11/12/2004 6:08:35 PM
Scar
Status: offline
A Magnum .80 hauled mine around just fine. Not underpowered at all. Your Saito probably has as much or more power, but you may need another ounce or two in the nose.
Best wishes,
Dave Olson
quote:
ORIGINAL: Jetstud
Kurt
KNeils@calalpa.org
(in reply to Jetstud)
       Post #: 690
RE: VectorFlight 300s, anygood? - 2/1/2005 3:18:36 AM
will1836
Status: offline
Matt 22,
I was looking at the same set up as you. Could you please keep me posted on how it works for you?
Bill
       Post #: 691
RE: VectorFlight 300s, anygood? - 4/16/2005 1:07:13 AM
ckangaroo70
