VectorFlight 300s, anygood?
Tower Hobbies
Logged in as Guest
  Printable Version
EASYTIGER'S Mirage IIIC VERY HIGH PERFORMANCE ONLY $129!
Seller:  EASYTIGER
Details:   $129.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> VectorFlight 300s, anygood?
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
VectorFlight 300s, anygood? - 7/10/2003 9:17:11 PM
Lean540
Status: offline
I have ordered one of these and I am wondering if there is anyone with some experience out there that could help with construction tips, engine recommendation etc.
Any input would be greatly appreciated.
Thanx in advance.
Lean540
       Post #: 1
VectorFlight 300s, anygood? - 7/10/2003 10:17:36 PM
David_Moen
Status: offline
Do a search for "Vector" there are lots of recent conversations.
I've got a 66" Extra on order, hopr to have it in a week or so. I will be doing a thorough review.
_____________________________
David Moen
www.mvvs-canada.com
(in reply to Lean540)
       Post #: 2
VectorFlight 300s, anygood? - 7/10/2003 10:37:56 PM
SunShyne
Status: offline
Yes they are excellent planes. I have an older Extra 300 and plan on getting the 66" one soon.
http://www.SendTextMessage.net
Revver Bro #86
       Post #: 3
VectorFlight 300s, anygood? - 7/11/2003 1:39:30 AM
cootertwo
Status: offline
I have one of their 58" 300's Wing comes in one piece. I got mine when they were still "Epic". It is a great plane. I have a Magnum 91 four stroke on it.
Click to see fullsize image.
Click for fullsize
       Post #: 4
VectorFlight 300s, anygood? - 7/11/2003 2:40:48 AM
SunShyne
Status: offline
I got the exact same one cooter has Got a Saito 80 on mine
Revver Bro #86
       Post #: 5
VectorFlight 300s, anygood? - 7/15/2003 5:01:01 AM
Geistware
Status: offline
I have the 58 inch version (HAD) and did a report on it. It is a great flying plane and the performance on a 2 stroke engine is excellent.
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 6
VectorFlight 300s, anygood? - 7/21/2003 1:35:44 AM
sydwys
Status: offline
I have built the 66" version with a Magnum .91 XLS on it. Unfortunately, I can not provide much input since the engine decided to quit after 4 days of breaking-in, flying, testing different props and mixture settings. I sent it back to Global Hobby for repairs. I can, definitely, say that the plane is very responsive and wonderfully stable at any speed and the Magnum .91 XLS seemed like a good match for it. As far as building tips: Ask all of your questions to Vectorflight customer service. They were remarkable throughout my build. All of my questions were answered within a couple of hours, some even on weekends.
       Post #: 7
VectorFlight 300s, anygood? - 7/21/2003 10:27:19 AM
David_Moen
Status: offline
I'm waiting for my 66" Extra, was hoping to get my hands on a Magnum .91 XLS as well. Sorry to hear yours packed it in on you! What went wrong?
David Moen
www.mvvs-canada.com
       Post #: 8
VectorFlight 300s, anygood? - 7/21/2003 2:03:05 PM
sydwys
Status: offline
It started by leaking compression in the back where the head meets the engine block. From there, it progressed to an overheating condition and eventually caused damage to the cylinder head. When I pulled the head to see what might have gone wrong, I noticed at least three of the head screws were loose and the others were just finger tight. Once I pulled the head, I found no head gasket (no remnants of a gasket that might have once been there either). My guess is whoever put it together on the assembly line at the factory had drifted off into lala land while my engine was passing through his hands.
       Post #: 9
VectorFlight 300s, anygood? - 7/21/2003 6:59:16 PM
David_Moen
Status: offline
Sorry to hear that! After all the (reasonably) good reviews on the Magnums, I'm suprised to hear of your experience. I've heard great things about Global Hobby's support though.
David Moen
www.mvvs-canada.com
       Post #: 10
VectorFlight 300s, anygood? - 7/21/2003 11:12:23 PM
sydwys
Status: offline
The reason why I choose it over the OS .91 FX was in fact what I have read here as well. I sent the engine in last Wednesday. Let's see if Global Hobby customer service will live up to its reputation.
       Post #: 11
VectorFlight 300s, anygood? - 7/31/2003 12:51:06 AM
SNIGGEMANN
Status: offline
I have been working on my 300S 58" for the last three nights and it is going really well thus far. Vectorflight customer service is incredible so if you have any little question don't hesitate to e-mail them. I have had a fair amount of correspondence with them thus far and they have been great. I had some trouble figuring out the belly pan installation but if you go to the supplemental instructions for the 66" 300S it shows you how its done. I also went a step further with the belly pan where I used small nylon bolts and brass threaded inserts instead of wood screws to attach the pan as indicated. This way I can attach and remove the wing at the field. I'll probably be installing the engine and cowling this evening and if it goes fast enough maybe the radio too. Another note, I would recommend getting the filler tube set-up from Dubro, it fit perfectly in the precut hole.
       Post #: 12
VectorFlight 300s, anygood? - 7/31/2003 1:04:44 AM
sydwys
Status: offline
Just an update for those who are considering using the Magnum .91XLS: Yesterday, I received a brand new engine in its box from Global Hobby. Made sure the gasket was there and the head bolts were tight. It will go back in probably tonight. I am hoping to break it in and hopefully get in a few flights by this weekend.
       Post #: 13
VectorFlight 300s, anygood? - 7/31/2003 1:12:02 AM
SunShyne
Status: offline
thanks for the heads up sydwys.
I flew mine this past week the MDS 68 and it was fine. Not a power monger like I expeceted but ill try diff props and see what happens. I got mine used and it came with a new belly pan. Does anyone mind posting or emailing a copy of the instructions on how to install it? I have the 58" version.
thanks
matt
Revver Bro #86
       Post #: 14
VectorFlight 300s, anygood? - 7/31/2003 1:17:44 AM
sydwys
Status: offline
Here are the instructions for the 66" version. I assume 58" would be the same: http://www.vectorflight.com/Extra300S66Instructions.html
       Post #: 15
VectorFlight 300s, anygood? - 7/31/2003 1:47:06 AM
SunShyne
Status: offline
the page is not displaying
Revver Bro #86
       Post #: 16
VectorFlight 300s, anygood? - 7/31/2003 1:58:26 AM
