Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
TF contender kit bash to tri moter
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 01-24-2010, 12:29 AM
aerofly0610
aerofly0610's Avatar
Default TF contender kit bash to tri moter
Take two contender kits and put them together. Add a pod in the center wing. I have 3 40las laying around that I could use. Wings will join at flap edges. Will be a taildragger with possible mains retractable.
Thoughts?
Old 01-24-2010, 12:59 AM
Brad330l
Brad330l's Avatar
Default RE: TF contender kit bash to tri moter
Make sure you start the center engine first.
Cheers,
Brad
Old 01-24-2010, 04:58 AM
aerofly0610
haha I will remember that.
Some thoughts on design. I'm thinking running engines side ways with pitts mufflers. What about removing the inside flaps and mount an engine backwards with a pusher prop? I can have dual tail wheels or a single one off the center of the horizontal stab. Would it hurt to include the outboard sides of the horizontal stabs?
Old 01-24-2010, 08:45 AM
Lifer
Lifer's Avatar
It will fly just fine. I built my first profile, two-fuselage twin about 15 years ago. It is called the Pinwheel Twin and was kitted by Morris Hobbies. Excellent single-engine performance. I think it is on it's second set of engines. Just use over-sized, spruce spars on the center section and it will be fine.
Old 01-24-2010, 12:55 PM
Tall Paul
Push-pulls fly fine.. I start the rear motor first.
ID:	1363262   Click image for larger version
ID:	1363263   Click image for larger version
ID:	1363264   Click image for larger version
Old 01-24-2010, 01:18 PM
aerofly0610
sweet! thanks for the info. I hope to order my kits after taxes are done.
Old 01-26-2010, 02:28 AM
aerofly0610
Ok I think ive finalized my design.... 2 engines in front and one pusher in the rear and will be a tail dragger if I can get clearance on the rear prop
