what is everyones take on starting fluid?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> what is everyones take on starting fluid?
Page: [1]
Login
what is everyones take on starting fluid? - 4/3/2002 1:53 PM
JohnVH
Score: 160
Last Login: 5/19/2013
Status: offline
kinda wondering what you guys think, my engine, a G62 WONT START, is it a good or bad idea??????
_____________________________
[quote]ORIGINAL: jefflangton
Time to bend over and let your head pop out!!!![/quote]
Hide Signatures
       Post #: 1
what is everyones take on starting fluid? - 4/3/2002 8:16 PM
Geoffbob
Score: 100
Last Login: 2/22/2013
Status: offline
How 'bout an answer kind of in the middle? I'm a snowmobile/ watercraft tech by trade; we use starting fluid occasionally, but we always feel guilty afterwards. The problem with it is that it washes the lubricants off the cylinder walls and bottom end bearings, not a good thing. If your engine is not drawing fuel sufficiently while choked, I'd look for problems with pump diaghrams, dirt in the carb, or small leaks in the lines. So I'll waffle a bit and say occasional use is probably okay, every time is not.
Geoff Leicester
Nederland, CO
Hide Signatures
(in reply to JohnVH)
       Post #: 2
Starting fluid - 4/3/2002 9:59 PM
Hobbsy
Score: 650
Last Login: 5/21/2013
Status: offline
You don't have to put enough in it to start a Farmall tractor. A split second shot with the piston at BDC will do it. Only fumes go into the lower end, if anything at all.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 3
what is everyones take on starting fluid? - 4/3/2002 10:03 PM
JohnVH
Score: 160
Status: offline
OK, if you look in my other post on the G62 youll see Im getting plenty of fuel, just cant get it to fire
Hide Signatures
       Post #: 4
G62 - 4/5/2002 12:21 AM
Phil Heller
Score: 100
Last Login: 7/5/2011
Status: offline
JohnVH
I am new to gassers and had much trouble getting my US41 to start at first. If your engine is brand new you will need an arm like Joe Montana to hand start it without a jumpstart or spring starter! Mine wouldn't even start with the spring at first. Needle settings are very critical, 1/16 or 1/8 turns are all that is needed. Set the needles at the manufacturers suggestion and beg or borrow a big starter to get it going and loosened up. After a few runs, spring starts and good strong hand slaps (with a glove!) will be possible. Starter fluid will only succeed in rapping your knuckles harder. Good Luck!
Phil
AMA8065 since 1945
Real Airplanes have four round engines and a tail gunner!
Hide Signatures
       Post #: 5
what is everyones take on starting fluid? - 4/5/2002 8:45 AM
Diablo-RCU
Score: 110
Last Login: 5/1/2013
Status: offline
I have been known to use WD-40 as a starting fluid in both glow and gas engines, but don't tell anyone. I figure it's got a little lubricating quality to it too.
Hide Signatures
       Post #: 6
what is everyones take on starting fluid? - 4/5/2002 9:00 AM
Taildrager-inactive
Score: 100
Last Login: 7/25/2008
Status: offline
I would think you have checked to make sure you are getting the correct amount of spark to the plug at the right time.Spark, fuel, & air in the right amounts at the correct time is all it takes, very basic I would think. You have checked the mag for correct working?
Hide Signatures
       Post #: 7
what is everyones take on starting fluid? - 4/5/2002 9:03 AM
Rosedale Flyer
Score: 100
Last Login: 2/18/2013
Status: offline
I agree with diablo, WD-40 is the way to go. Use it in
chain saws, lawn mowers, any gas engine. It will not
wash down the cylinder wall, and as far as I can see
it works just as good as starting fluid.
Hide Signatures
       Post #: 8
what is everyones take on starting fluid? - 4/5/2002 11:30 AM
JohnVH
Score: 160
Status: offline
HEHE, OK!! wish I could gonna give my arm a couple more days to recover
Hide Signatures
       Post #: 9
what is everyones take on starting fluid? - 4/5/2002 12:38 PM
Divesplat
Score: 100
Last Login: 12/30/2008
Status: offline
John, if the G62 has a magneto( I am only familiar with 3W and Da) a local flier found out he had to "Slap" the prop to generate enough speed to get a spark.
He always wore a glove, positioned the prop just behind the firing point, then slapped the prop. Don't have to do this with engines with ignitions.
Might give that a try.
Ed
Pattern or IMAC, loops should be round, lines should be straight, and either props can send you to the hospital!:)
Hide Signatures
       Post #: 10
what is everyones take on starting fluid? - 4/6/2002 9:56 PM
dmac
Score: 100
Last Login: 1/27/2013
Status: offline
JohnVh, Don,t worry about using starting flud in your G-62. Almost all the starting fluids on the market now have lubrication in them. Never use starting fluid on a hot engine though. dmac
Hide Signatures
       Post #: 11
Helped friend - 4/6/2002 11:12 PM
ricfly52
Score: 100
Last Login: 1/31/2010
Status: offline
I helped a friend break in a G62 on a Giant Aeromaster. It was a bit cranky(pun intended) on the first two or three starts. We finally found that choking the thing real wet, would make it fire on the first or second flip. However there seems to be that fine line that you can cross, and flood the engine. When that happens let her set and dry out awhile. When you continue to flip a flooded engine all you accomplish is building arms like Arnold Shwartznegger. Seems like this is a great running engine, once it is broke in though.
Hide Signatures
       Post #: 12
what is everyones take on starting fluid? - 4/6/2002 11:52 PM
JohnVH
Score: 160
Status: offline
I actually got it started finally, without starting fluid, a couple times even!! check out my help with g62 thread, the CDI? was too far away from the crank to get good spark!!! it starts good now!
Hide Signatures
       Post #: 13
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> what is everyones take on starting fluid?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
