RE: Jetlegend Mig 29 Fulcrum    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Jetlegend Mig 29 Fulcrum
Page: <<   < prev  16 17 18 19 [20] 21 22 23 24 25   next >   >>
Login
RE: Jetlegend Mig 29 Fulcrum - 3/12/2011 10:08 PM
i3dm
Score: 100
Last Login: 5/22/2013
Status: offline
so one thing im still not sure about is once the system is all mounted up and working, and i fill up the reservoir for the first time, all the lines are full with air. once the pump starts flowing oil, it will go into tubes full of air, and on the other side of the tube is a sealed cylinder - where will all this air go ?
_____________________________
www.liorzahavi.com
www.youtube.com/i3dm
Hide Signatures
(in reply to johnls)
       Post #: 476
RE: Jetlegend Mig 29 Fulcrum - 3/12/2011 10:18 PM
tp777fo
Score: 103
Status: offline
Rob (F15driver) had the same problem. Running the system moves the bubbles towards the oil tank. To help it alone remove the lines and hold them straight up as much as you can. This will allow the fluid to collect at the bottom. Fill the tank totally full and run the system several times. You will see the bubble at the tank get larger. This is the air in the lines collecting in the tank. Fill the tank again and keep doing this. We got all the air out of Rob's system in a couple of tries.
Tom Perry
In Dog beers, I only had one!
Hide Signatures
(in reply to i3dm)
       Post #: 477
RE: Jetlegend Mig 29 Fulcrum - 3/12/2011 10:22 PM
i3dm
Score: 100
Status: offline
quote:
ORIGINAL: tp777fo
Remove which lines and hold them straight up ?
BTW - i guess the unit doesnt have any servo travel programming - do you set the valve travel mechanically by changing the length of the servo horn ?
I hope to test mine for the first time tommorow !
www.liorzahavi.com
Hide Signatures
(in reply to tp777fo)
       Post #: 478
RE: Jetlegend Mig 29 Fulcrum - 3/13/2011 12:35 AM
tp777fo
Score: 103
Status: offline
Robs lines had been cut to the correct length but not tied down in the fuselage, we could pull them up and out of the fuselage to allow the air to escape.
Tom Perry
Hide Signatures
(in reply to i3dm)
       Post #: 479
RE: Jetlegend Mig 29 Fulcrum - 3/13/2011 4:28 AM
ianober
Score: 100
Status: online
Just cycle the gear 3-4 times then refill the oil tank. Cycle again 3-4 times and then the system should be air free. Its a self bleeding system basically.
Not sure what your getting at about the servo travel. The valve is controlled by a servo so you should be able to program the travel of the servo to use the valve like any other manual valve.
Hide Signatures
       Post #: 480
RE: Jetlegend Mig 29 Fulcrum - 3/13/2011 2:10 PM
i3dm
Score: 100
Status: offline
quote:
ORIGINAL: ianober
But if you change the end poitn of the gear channel does the electronic controller still work well ?
www.liorzahavi.com
Hide Signatures
(in reply to ianober)
       Post #: 481
RE: Jetlegend Mig 29 Fulcrum - 3/13/2011 11:42 PM
Aussie Bart
Score: 100
Last Login: 5/19/2013
Status: offline
Yep, just needs to see a change in signal
Bart
Hide Signatures
(in reply to i3dm)
       Post #: 482
RE: Jetlegend Mig 29 Fulcrum - 3/14/2011 12:03 AM
i3dm
Score: 100
Status: offline
My Eurokit hydraulic gear works perfect since the start ! test video:
It did take one pump of oil, a few cycles tilting the fuse in different directions, and then another pump of oil into the tank, to bleed most of the air out. but the gear works awesome after this short break in !
Im a happy camper ! seems like Eurokit did a really nice job with this hydraulic convserion. unlike other units, it worked from the get go !
Added some pics of the installation as it was done by craftsman builder Mr. Peter Nir.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
www.liorzahavi.com
Hide Signatures
(in reply to Aussie Bart)
       Post #: 483
RE: Jetlegend Mig 29 Fulcrum - 3/14/2011 3:22 AM
Kmarks
Score: 100
Last Login: 5/5/2013
Status: offline
Looks really good Lior,
what did you need to do to the stock gear air cylinders so the oil would work and not leak. This may be the new way to work gear for many jets.
Kevin
Hide Signatures
(in reply to i3dm)
       Post #: 484
RE: Jetlegend Mig 29 Fulcrum - 3/14/2011 3:15 PM
i3dm
Score: 100
Status: offline
quote:
ORIGINAL: Kmarks
Kevin
NOTHING - thats the best part.
All stock !
www.liorzahavi.com
Hide Signatures
(in reply to Kmarks)
       Post #: 485
RE: Jetlegend Mig 29 Fulcrum - 3/14/2011 6:59 PM
Edgar Perez
Score: 100
Status: online
quote:
ORIGINAL: i3dm
quote:
ORIGINAL: Kmarks
Kevin
All stock !
Ok. Im' confused here. This thread indicates the need to use hysol to plug some hole or make new shuttle internals to avoid the oil blowback in the cylinders. Are you indicating that is no longer needed or i'm reading it wrong?
If no longer needed, is that due to the new gear design (versus the original used by Bart and other in this thread)?
Edgar Perez
Puerto Rico
Hide Signatures
(in reply to i3dm)
       Post #: 486
RE: Jetlegend Mig 29 Fulcrum - 3/14/2011 7:03 PM
i3dm
Score: 100
Status: offline
quote:
ORIGINAL: Edgar Perez
Thats exactly right. the new gear design has solid shuttles so no mods required.
www.liorzahavi.com
Hide Signatures
(in reply to Edgar Perez)
       Post #: 487
RE: Jetlegend Mig 29 Fulcrum - 3/19/2011 5:36 PM
i3dm
Score: 100
Status: offline
Guys,
Whats the recommended CG for the JL Mig-29 ?
www.liorzahavi.com
Hide Signatures
(in reply to i3dm)
       Post #: 488
RE: Jetlegend Mig 29 Fulcrum - 3/21/2011 9:05 AM
johnls
Score: 100
Status: offline
If you read back in this thread there is information relating to the CG position. I found that the CG, that Jet Legend give is too far forward. I am flying mine with the CG at the back of the first wooden cross brace, in the engine compartment. (there is a photo of the position somewhere in this thread). A few pictures of mine flying at the weekend. http://www.rcuniverse.com:80/forum/m_5943833/mpage_9/tm.htm
John
FLY HARD!!
Hide Signatures
(in reply to i3dm)
       Post #: 489
RE: Jetlegend Mig 29 Fulcrum - 3/21/2011 1:32 PM
i3dm
Score: 100
Status: offline
quote:
ORIGINAL: johnls
John
Do you mean the front most wing spar ?
Did anybody have any trouble with the gear doors ? my main door on the right side doesnt close all the way up... it stops a little shy from the fuse.
www.liorzahavi.com
Hide Signatures
       Post #: 490
RE: Jetlegend Mig 29 Fulcrum - 3/21/2011 1:39 PM
johnls
Score: 100
Status: offline
Not the wing spar. The ply cross brace that goes over the engine and is held in by two bolts. I am pointing to it with the end of a screw driver. My doors shut OK but sometimes move when flying, with G load.
John
Click for fullsize
Click for fullsize
FLY HARD!!
Hide Signatures
(in reply to i3dm)
       Post #: 491
RE: Jetlegend Mig 29 Fulcrum - 3/21/2011 1:50 PM
jeff sewell
Score: 100
Status: offline
Well, I finally flew mine yesterday... I used John's CG position too.
Anyway, the MIG was very nice, felt very solid and easy to handle. The landings are a non-event - just so easy.
Hope to have a couple of pictures uploaded soon...
Cheers
Jeff
Exclusive UK JetLegend Dealer
Wren Turbines Dealer
Hide Signatures
       Post #: 492
RE: Jetlegend Mig 29 Fulcrum - 3/21/2011 2:03 PM
johnls
Score: 100
Status: offline
Congratulations on the flight Jeff. It almost lands it self, doesn't it!!
John
FLY HARD!!
Hide Signatures
(in reply to jeff sewell)
       Post #: 493
RE: Jetlegend Mig 29 Fulcrum - 3/21/2011 2:07 PM
martin.lees1
Score: 100
Last Login: 1/5/2013
Status: offline
Yes Jeff flights & landings looked very good.
Well done
Rgds Martin.
Hide Signatures
       Post #: 494
RE: Jetlegend Mig 29 Fulcrum - 3/22/2011 9:32 PM
jeff sewell
Score: 100
Status: offline
Thanks guys...
Looking forward to the next ones.
Jeff
Hide Signatures
(in reply to martin.lees1)
       Post #: 495
RE: Jetlegend Mig 29 Fulcrum - 3/24/2011 6:48 PM
jeff sewell
Score: 100
Status: offline
Some pictures - thanks to John Mac...
Jeff
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 496
RE: Jetlegend Mig 29 Fulcrum - 3/27/2011 10:48 PM
dionysusbacchus
Score: 120
Last Login: 5/2/2013
Status: offline
< Message edited by dionysusbacchus -- 3/29/2011 12:41 PM >
Hide Signatures
       Post #: 497
RE: Jetlegend Mig 29 Fulcrum - 3/27/2011 11:24 PM
i3dm
Score: 100
Status: offline
What the heck happend to that line ? and where is the video ?
www.liorzahavi.com
Hide Signatures
(in reply to dionysusbacchus)
       Post #: 498
RE: Jetlegend Mig 29 Fulcrum - 3/27/2011 11:58 PM
F15driver
Score: 100
Last Login: 5/21/2013
Status: offline
If you look closely at the bad hydraulic line you'll notice the main Red, Black and Blue electric lines that go into the side of the Jet Central Rhino. I'm 99% certain this electric line which powers the Kero Start on the turbine was laying on top of the hydraulic line. I hadn't run the turbine for awhile and it took 2 starts to get it going. I think the high current draw required to start these turbines warms the electric lines and because I had to go through the start routine twice, I think the electric lines were warm enough to soften the hydraulic line. When I hit the gear down switch, I think the pump hydraulic pressure burst the line and caused only one gear to go down before all the sewing machine oil blew into the engine bay area.
With the right main hanging down and the other two stuck in their up position, my choice was to land on the paved runway and skin the entire bottom or try to ease it into the grass in a nose high attitude. I chose the latter option and it was the right one. The right main gear base plate was separated from the strut which will need repair and two of the gear door hinges were broken. Two gear doors also were cracked in a couple of places and the right wing had a small indentation which is easily repairable.
The puff of smoke you see in the one frame is when the hydraulic oil was pumped into the engine area and some actually went through the turbine. Aside from a lot of grass on the inside of the airplane and the inlets having a bunch of grass, the FOD screen kept it all out of the turbine.
So, the lesson here is to pay particular attention to where your battery cables and engine power electric lines are run. Do not have them next to hydraulic or pneumatic lines. All in all, I was lucky that the right main being down did not cause the plane to cartwheel when it landed. The nose high landing with the turbine shut down saved the airframe. Lesson learned.
Rob Puetz
F15driver
Don''''t look back, they may be gaining on you!
Hide Signatures
(in reply to i3dm)
       Post #: 499
RE: Jetlegend Mig 29 Fulcrum - 3/28/2011 7:45 AM
JohnMac
Score: 100
Status: offline
Hi Rob, Are you sure that these power lines get noticabley warmer during start? If they get hot enough to do that to the hydraulic pipe then the insulation must be degrading. This would mean thes cables are way undersize. What current draw are we talking about on a Kero strtengine any way?
Hide Signatures
(in reply to F15driver)
       Post #: 500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.016RCU1
