Tower Hobbies Uproar ARF not right ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Uproar 40 -ARF
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> ARF or RTF >> Tower Hobbies Uproar ARF not right ?
    Page: [1]
    Login
    Tower Hobbies Uproar ARF not right ? - 2/1/2010 7:59 PM
    outlander
    Score: 100
    Last Login: 5/7/2013
    Status: offline
    I am 80 percent trough the assembly of my Uproar . I am attempting to mount the throttle rudder and elevator servos , but the servo
    tray is only 1/2 inch above the wing . Was there supposed to be a cut out in the wing top , where the fuselage is glued on , to accommodate the standard Futaba servos ? Hobbyco wants me to send the wing back , but it is glued to the fuselage and would be
    very expensive . Any one else have this problem with an Uproar ?
    Hide Signatures
           Post #: 1
    RE: Tower Hobbies Uproar ARF not right ? - 2/1/2010 8:12 PM
    opjose
    Score: 280
    Last Login: 5/20/2013
    Status: online
    I don't have that plane so bear this in mind...
    Couldn't you glue a pair of small hardwood blocks to lift the servos when mounted so they fit?
    Is the problem that there is no hole for the servos, or that they don't seat properly?
    _____________________________
    Don''t worry, be happy and fly something!
    Hide Signatures
    (in reply to outlander)
           Post #: 2
    RE: Tower Hobbies Uproar ARF not right ? - 2/1/2010 9:50 PM
    gmeyer-RCU
    Score: 100
    Last Login: 5/17/2013
    Status: offline
    I built this plane as a kit and am currently covering the 60 size. If you look on page 15 of the instructions you will see a isometric drawing which seems to show the servos going through the top of the wing. Greg
    Hide Signatures
           Post #: 3
    RE: Tower Hobbies Uproar ARF not right ? - 2/1/2010 11:48 PM
    krproton
    Score: 116
    Last Login: 5/2/2013
    Status: offline
    The servo tray is actually in the wing. After the wing is glued into the fuselage, the servos are mounted upside-down, in the servo tray. The tops of the servos/servo arms should clear the radio hatch that is screwed onto the bottom of the fuselage and the bottoms of the servos should clear the top of the fuselage. I don't understand why your servos won't fit. Can you post a photo?
    Tim Lampe
    Hobbico R&D
    Hide Signatures
    (in reply to gmeyer-RCU)
           Post #: 4
    RE: Tower Hobbies Uproar ARF not right ? - 2/14/2010 1:34 AM
    outlander
    Score: 100
    Status: offline
    Tower has issued a technical notice to go in the kits . The notice instructs you to cut the balsa sheeting that covers the wing ,
    before you glue the wing to the fuselage . This will give you the clearance for the servos to be mounted in the servo tray . I
    guess the kit makers are not doing this cut any more . Tower was very helpful in finding a solution to this problem
    Thanks for all the comments from forum members . Now I have to reinstall my battery , near the tail , to get the plane
    to balance with an OS 46ax .
    Hide Signatures
           Post #: 5
    Page:   [1]
    Page: [1]
    Uproar 40 -ARF
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.734RCU1
