Will my receivers work?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Will my receivers work?
Page: [1]
Login
Will my receivers work? - 7/11/2003 8:46:56 AM
awnichy
Status: offline
Hi, I was reading through the forum because I'm fixing to buy another radio. I'm an old rc'er and never really thought about these new computer radios. I have read about the 9cap and I like everything about it but I have a question, first, what is pcm and why would I prefer it over the other kind and second, I have about 6 receivers that I have been using with my Futaba 6 and more recently I bought a Super 7uaf and they all work with it. Somebody told me that they wouldn't work with the 7uap and I was wondering if they would work with the 9cap. Any help would be much appreciated.
_____________________________
Al Nichy
AMA768670
       Post #: 1
Will my receivers work? - 7/11/2003 8:59:33 AM
Lynx
Status: offline
I personally don't see a real advantage with PCM but some people do. It's digital as opposed to analog way for the xmitter to send data to the receiver. It allows some error checking so instead of the glitches you see with regular PPM it filters it rejects signals it things are 'bad' So instead of the glitches you get 'null' spots in where you don't have fluid control of the plane. The big downfall of PCM is you don't notice it glitching before it goes completly wacko, so where with PPM you may notice you're getting interference because your servo's are twitching with PCM you won't and you might not notice it at all untill you relize you have no control over the plane at all. It also allows for setting the servo's at some preset spot in case you do lose control. untill you regain it.
-Curiosity may have killed the cat
-But that's why they have nine lives
(in reply to awnichy)
       Post #: 2
Will my receivers work? - 7/11/2003 12:41:25 PM
Steve Lewin
Status: offline
Your receivers will work with the 9C Tx which can be swiched into PPM mode.
As for PCM vs PPM I'm not getting into that. It has already been debated to death many times. Try a search.
Steve
       Post #: 3
Will my receivers work? - 7/12/2003 12:45:44 AM
transmission_dr
Status: offline
Hi,
If your receivers are FM, they should work fine withe the 9cap as long as you select PPM modulation.
As has been mentioned the PCM/PPM discussion is an endless one.
If you have a question as to which is better, just look at what all
the big guys are using (the Chip Hydes, etc). As far as I know ALL of them use PCM.
Nuff said,
Jerry
Jerry Martire
       Post #: 4
Will my receivers work? - 7/12/2003 12:53:07 AM
SMALLFLY-
Status: offline
the big guys are GIVEN there pcm rx's by there sponsors.
If you list the model #'s of what rx's you have you could make sure.
But like above as long as they are non pcm futaba or hitec rx's you should be fine
       Post #: 5
Will my receivers work? - 7/12/2003 10:09:09 PM
MO_Radio_Tech
Status: offline
The contest flyers fly PCM by choice, as do most of contest Helicopter folks and Jet flying folks.
       Post #: 6
Will my receivers work? - 7/12/2003 11:12:17 PM
strato911
Status: offline
[QUOTE]Originally posted by transmission_dr
... just look at what all the big guys are using (the Chip Hydes, etc). As far as I know ALL of them use PCM.
Originally posted by MO_Radio_Tech
The contest flyers fly PCM by choice ... [/QUOTE]Excuse my ignorance for not knowing who Tom Hunt and Bob Aberle are, but according to Lewis Polk (from Polk's Hobbies), they use the Tracker II exclusively. This is a PPM only radio.
Al - As long as none of your receivers are PCM, they should all work with the 9C in PPM mode.
I try to learn from other people's mistakes...
I won't live long enough to make them all myself.
       Post #: 7
HUNT/ABERELE - 7/13/2003 5:22:08 AM
cassidy
Status: offline
Tom Hunt is an engineer for Gruman and is one of the leading experts on electric flight. He was just inducted into the AMA hall of fame.
Bob Eberle is another of the Electric experts and he writes articles for various US magazines on electric flight and radio equipment.
Also Tom Hunt is the man behind the annual NEAT EXPO that occurs in NY State in September each year.
       Post #: 8
Will my receivers work? - 7/13/2003 6:55:43 AM
strato911
Status: offline
Thanks for the explanation.
I knew they were BIG names in the US... I just didn't know the details (notice I am from Canada). Further research also showed Bob Eberle was an integral part of the AMA getting the frequency band expanded years ago, and Tom Hunt designs RC aircraft much larger than just for electrics...
       Post #: 9
Will my receivers work? - 7/13/2003 9:08:23 AM
crashed2
Status: offline
[QUOTE]Originally posted by Lynx
instead of the glitches you see with regular PPM it filters it rejects signals it things are 'bad' So instead of the glitches you get 'null' spots in where you don't have fluid control of the plane. The big downfall of PCM is you don't notice it glitching before it goes completly wacko, so where with PPM you may notice you're getting interference because your servo's are twitching with PCM you won't and you might not notice it at all untill you relize you have no control over the plane at all. It also allows for setting the servo's at some preset spot in case you do lose control. untill you regain it. [/QUOTE]
This is somewhat true. What happens is, when the receiver picks up a so called glitch, the rx will sense this bad command and instead of signaling the servo with this bad command, the rx keeps the last known good command until it picks up the Tx signal again. this usually happens in an instant, but if you do set the presets, you can set it for the throttle to go down close to idol without killing the engine, so if the receiver lost the Tx signal the engine would kind of hicup, which will tell you something is wrong.
Also, most of the big guys, (larger planes, ie; 30% and larger) at least the ones I know, do fly PCM, but they also fly with two receivers, which kind of splits the controls in half, one for the left side of the plane, & one for the right side of the plane, so if something was to fail, they have more of a chance of bringing the plane safetly back to the ground.
Jim Noppe, AMA744914
It's all for Fun Baby! "In GOD I Trust"
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.703RCU5
