Computer tuning    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Off Topic Forum - Cars, Trucks, Buggies and more >> Computer tuning Page: [1]
Login
Computer tuning - 2/3/2010 6:09 AM
JB COMP
Score: 108
Last Login: 11/16/2011
Status: offline
My brother just got a computer that had some sort of computer tuning software, that supposedly makes it run faster. What exactly does software like that do, and is there any good free ones?
Lately my computer has been slowing down, and I want to get it back up to speed. (I'm running 1gb ram, but uses only use 600mb of it)
Hide Signatures
       Post #: 1
RE: Computer tuning - 2/3/2010 6:53 AM
DarkFire989
Score: 235
Last Login: 6/18/2013
Status: offline
You could possibly Overclock your RAM and CPU, but you would probably have no idea what you were doing and fry everything. Starting cleaning up the files on your computer.
_____________________________
Clod Buster | Sludge Hammer | Blue Streak | Revo | Baja | CR-01 | FG MT
Hide Signatures
(in reply to JB COMP)
       Post #: 2
RE: Computer tuning - 2/3/2010 6:58 AM
sheograth
Score: 325
Last Login: 5/13/2013
Status: offline
Software programs that claim to speed things up (unless they're actually overclocking something) don't work, simple as that. Clean up files, make sure the PC is free of malware, etc - those are the things you can do to make it run optimally. Frankly, those "speed up" programs basically ARE malware, most of the time they just bloat things, or worse act as spyware.
RCUniverse.com | Wattflyer.com | RCUvideos.com
Hide Signatures
(in reply to DarkFire989)
       Post #: 3
RE: Computer tuning - 2/3/2010 6:20 PM
JB COMP
Score: 108
Status: offline
Alright. Thanks.
Hide Signatures
(in reply to sheograth)
       Post #: 4
RE: Computer tuning - 2/3/2010 6:29 PM
Ttam Says Blarg
Score: 186
Status: offline
Allways good to have a decent anti virus! As everyone else said its prob. spyware..... If you dont have a good one get the free one AVG offers.
Aint nothin but a thang
Slash 1/16 - DB-01 - TT-01 - RC18B and a Super Cub!
Hide Signatures
       Post #: 5
RE: Computer tuning - 2/3/2010 6:33 PM
Eman77
Score: 380
Status: offline
I suggest you defrag your hard drive on a regular basis. Windows comes with its own defrag program, just use that every now and then (I check it once a month). Right click on your hard drive (C: or D:, whatever), choose Properties.
In the Properties window, go to the Tools tab. Click "Defragment Now" - this brings up the Defrag window. There you can choose a physical drive (C, D, etc) and Analyze. Windows will suggest a defrag if it's necessary. It can take quite a long time, so run it overnight, or whenever you won't use it for a while.
Note: above steps are for XP. For Vista, they vary slightly, but these steps will get you there.
Otherwise, for basic maintenance/speed, I suggest running the occasional anti-malware software updates and scans on a regular basis (MalwareBytes, Spybot Search & Destroy, etc) to help clean stuff up.
Also make sure you still have adequate free space on the HD - once that puppy gets near full, HD performance starts to go down the crapper.
DT02-MS | Durga | Stadium Thunder | TT Frog | VS Tanks | TRF 801XT | CR-01 | F-150 | CRT.5 | T-Egg
Hide Signatures
       Post #: 6
RE: Computer tuning - 2/3/2010 7:03 PM
JB COMP
Score: 108
Status: offline
I try to defrag every month or so, and run a registry cleaner.
Also I run AVG 9 (free) malwarebytes, and spybot. My drive is only half full.
Hide Signatures
(in reply to Eman77)
       Post #: 7
RE: Computer tuning - 2/3/2010 7:17 PM
Eman77
Score: 380
Status: offline
In that case, I'm not sure why your computer would be slowing down. More stuff installed that runs in the task manager, I assume? Meaning, more services/active things running?
Hide Signatures
       Post #: 8
RE: Computer tuning - 2/3/2010 11:44 PM
JB COMP
Score: 108
Status: offline
quote:
ORIGINAL: Eman77
I'm running 39 processes with FF, Outlook express, Windows media player and the task manager open. (when I got the computer it had 96) I might see if I can't get that numbers lower.
Another thing is my computer slows down when I'm only using about 60-70% of my memory.
Hide Signatures
       Post #: 9
RE: Computer tuning - 2/3/2010 11:59 PM
HJJFFFAA
Score: 299
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: JB COMP
quote:
ORIGINAL: Eman77
That's a fair amount of memory use.
Hide Signatures
       Post #: 10
RE: Computer tuning - 2/4/2010 12:26 AM
JB COMP
Score: 108
Status: offline
quote:
ORIGINAL: HJJFFFAA
quote:
ORIGINAL: JB COMP
quote:
ORIGINAL: Eman77
Only have 1gb so I'm usually using 600mb - 700mb. FF and system are my biggest processes. FF usually 130-160K (depending on whether or not I have a chat/IM open) and system 83K. Other than that there's three or four that are in the 30k - 34k range (two of them being outlook express and media player) then the rest are <10K
Hide Signatures
(in reply to HJJFFFAA)
       Post #: 11
RE: Computer tuning - 2/4/2010 12:41 AM
Eman77
Score: 380
Status: offline
That there's yer problem sonny - you have only 1 gb instead of 1 GB. That's not very much.
...get it? bits vs. Bytes? Anyone?
*crickets chirp*
Hide Signatures
       Post #: 12
RE: Computer tuning - 2/4/2010 4:08 AM
samguan
Score: 136
Last Login: 5/16/2013
Status: offline
Most tuning applications do not do anything. Scan to make sure your computer does not have spywares as these spywares can slow your computer down alot!. Check the task manager to make sure you don't have any memory hogging processes running.
Disable Windows startup for applications that you do not need, it will speed up your startup time.
Get more RAM if it is not enough. 2GB or more. You will see improvements.
Savage XL Roller, Savage Flux, HPI Blitz Brushless, Venom Creeper, Mini Summit, Walkera 4#6S.
Hide Signatures
       Post #: 13
RE: Computer tuning - 2/4/2010 5:42 AM
dudecat
Score: 106
Last Login: 7/26/2011
Status: offline
The only tuning software that tunes right are the ones designed for videocards example rivatuner. All they do i let you ramp your clock on the videocard for extra performance but come at a cost though. With out proper cooling your gonna cook something and end up costing you a card.
Tamiya Mighty Bull!!!!
Losi Aftershock!!!
Hide Signatures
(in reply to samguan)
       Post #: 14
RE: Computer tuning - 2/4/2010 6:37 AM
The_Shark
Score: 494
Last Login: 6/11/2013
Status: offline
i found many running problems are caused by over heating. crack open your case, clean all the electronics and if you can, upgrade the fans.
Signature
(Max. 125 chars. 2 lines max)
Hide Signatures
(in reply to dudecat)
       Post #: 15
RE: Computer tuning - 2/4/2010 6:45 AM
JB COMP
Score: 108
Status: offline
quote:
ORIGINAL: The_Shark
Running a laptop. I may pop it open and clean it.
Hide Signatures
(in reply to The_Shark)
       Post #: 16
RE: Computer tuning - 2/5/2010 6:51 AM
Nik.
Score: 106
Last Login: 7/27/2012
Status: offline
get ccleaner, get defraggler, quit all the things you don't need, uninstall all the things you dont need, dump avg and get microsoft security essentials.
best served with new install
Team Smiley
Just remember, if the world didn''''''''t suck, we''''''''d all fall off.
Hide Signatures
       Post #: 17
RE: Computer tuning - 2/5/2010 5:24 PM
Eman77
Score: 380
Status: offline
Does a defraggler get rid of all the fraggles?
http://en.wikipedia.org/wiki/Fraggle_Rock
Hide Signatures
(in reply to Nik.)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
