AirRayInc
Joined: 12/30/2001 From: San Pedro, CA, USA Status: offline
...my last $1.25, 1. Evo is right. Here is another explanation. When you drill and insert your Robart hinge points, the hinge will stick out say 1/4" from the sub trailing edge of the wing. When you drill the hole for the aileron leading edge, go back and with a dremel or small smooth rat tail file, clear away the material that blocks the aieron from travel. 2. You can follow the building instructions that Yellow give you, and do nothing but make sure you step up the servo strength and you will have no problems, provided everything else is glued in nice and solid. 3. The easiest way to get around the potential flutter concern, is to do like most echoed and just rebuild it from balsa, me, I say why, damn things look sweet. I would take the time that it takes to build up my own, and put it into making sure that the Yellow ones are installed soundly, end of story. Testament to this fact, I have a Jug flying that I built for a customer that is flying with a Brisson 4.2, (my guess is that all of you with flutter problems havent even thought of flying with an engine this size) dont think that puts alot of stress on an aileron? To quote," flys straight and true, with no problems". If you are in Jackson TN, be on the look out for it. The final word hopefully is this, yes when you build the Yellow Aircraft Jug, take notice that you MUST address the fact that the ailerons will take you a bit longer to rebuild/install, reinforce and rig. Of planes types and flying qualities, if all I ever had to worry about was the Ailerons, I would be truly a happy camper. The Jug is a great flying plane, ask Vic, I want to take his simply cause he doesnt fly it "right". Do ya Vic? Ray
< Message edited by AirRayInc.Com -- Apr 6 2002 2:36AM >
_____________________________
My Blog http://www.rcgroups.com/forums/member.php?u=9311 http://airrayinc.com
