Volcano epx pro brushless issue...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Volcano epx pro brushless issue...
Page: [1]
Login
Volcano epx pro brushless issue... - 2/4/2010 9:10 PM
lor35228
Score: 100
Last Login: 3/23/2010
Status: offline
For some reason my volcano epx pro can no longer go a distance of more 80ft. If my RC truck go beyound 80ft it will start to do weird things by itself without me doing anything. For example, the truck will just throttle foward by itself for like a few seconds, it will repeat that process for a while........Not sure what part is defected, help...thanks!
Hide Signatures
       Post #: 1
RE: Volcano epx pro brushless issue... - 2/5/2010 6:31 AM
Triscuit
Score: 100
Last Login: 2/23/2013
Status: offline
What kind of battery are you using? the included stock one or a lipo? We had an issue like this and now it just stutters all the time and is having and issue even operating and all redcat told me to do was try a lipo and good luck basically. IMO they need to either include a lipo and charger in the box as a stock part or change the crappy ESC design by using an external low voltage cutoff instead of one you CANNOT disable that is built in and have a replacement program for it
_____________________________
"resurrection is for those who didn''t get it right the first time" -Otep
Hide Signatures
(in reply to lor35228)
       Post #: 2
RE: Volcano epx pro brushless issue... - 2/8/2010 4:29 AM
landow
Score: 100
Last Login: 12/19/2010
Status: offline
sounds like you having a range problem with your transmitter how are the batteries in the transmitter?
Hide Signatures
(in reply to Triscuit)
       Post #: 3
RE: Volcano epx pro brushless issue... - 2/8/2010 5:31 AM
rcguy1411
Score: 105
Last Login: 5/19/2013
Status: offline
could also be a broken rx antena wire
Hide Signatures
(in reply to landow)
       Post #: 4
RE: Volcano epx pro brushless issue... - 2/11/2010 4:10 AM
billymare
Score: 105
Last Login: 5/16/2013
Status: offline
Mine was doing the same thing....stupid 6.0 volt cut off   it stutter's with a crappy nimh battery, but flips on its roof with a 2s lipo!!
Redcat''s a-plenty,savage XS,2 Savages,1brushless XL
Sprint2, Blitz, Terra Crusher,ast. planes, helicopters and a LOT m
Hide Signatures
(in reply to rcguy1411)
       Post #: 5
RE: Volcano epx pro brushless issue... - 2/12/2010 11:21 PM
lor35228
Score: 100
Status: offline
I'm starting to think that it could be the ESC because I can still turn the wheels when I'm far away and I can still pull the trigger to make the rc go but it just very shaking and stutters ALOT! I already try different battery for the transmitter gun and receiver. I also try different reciver and transmitter. I also tried different 8.4 nimh battery, still doing the same thing. So my guess is the ESC or either the Motor, but i'm leaning towards te ESC, what ya think?
Hide Signatures
(in reply to billymare)
       Post #: 6
RE: Volcano epx pro brushless issue... - 2/17/2010 7:36 AM
TCA999
Score: 101
Last Login: 5/3/2013
Status: offline
Brand new to hobby grade RC's. I had a couple of questions.
I have just received my Volcano EPX PRO, took the battery out, charged it for 9.5hrs like the "manual" says to do. Well, I understand the high pitched squeel when you hit the  accelerater but the motor or drive shaft sounds horrible. Almost sounds as if something is loose or broken. I couldn't imagine that I would receive a bad truck straight out of the box but is this normal?
How do I properly break in the brushless motor?
Also, since I don't think that this truck is waterproof how would I go about driving in the snow?
Any help/advise given is greatly appreciated.
Thank  you!
If you think today was bad, talk to the person who lost their spouse, son, daughter or parent. That''s a bad day.
Hide Signatures
       Post #: 7
RE: Volcano epx pro brushless issue... - 2/17/2010 2:27 PM
jeztur2003
Score: 106
Last Login: 3/16/2010
Status: offline
quote:
ORIGINAL: TCA999
I have just received my Volcano EPX PRO, took the battery out, charged it for 9.5hrs like the ''manual'' says to do. Well, I understand the high pitched squeel when you hit the  accelerater but the motor or drive shaft sounds horrible. Almost sounds as if something is loose or broken. I couldn't imagine that I would receive a bad truck straight out of the box but is this normal?
Thank  you!
The crappy sound is normal for brushless vehicles. It sounds as if metal is rattlling.
Authorized Redcat Racing Dealer
Hide Signatures
(in reply to TCA999)
       Post #: 8
RE: Volcano epx pro brushless issue... - 2/17/2010 3:57 PM
billymare
Score: 105
Status: offline
What I find when mine does that, I slowly feed it throtle and it will get to top speed.  it is almost lke it has to learn.  cause then it's fine.
Hide Signatures
       Post #: 9
RE: Volcano epx pro brushless issue... - 2/17/2010 5:00 PM
TCA999
Score: 101
Status: offline
Thank you so much. I feel much better. Yeah, I've picked it up so no wheels are touching ground and slowly throttled it(wants to rip out of my hand) and then the sounds go away pretty much at high speeds...Bad little truck though.
Any thoughts on running in the snow? I'm in Iowa so it's only about 20F here...I'm not rough with it at all in the cold since I don't want to break any parts. Oh, any tips on to break in the motor? or is that only for nitro/gas engines?
Thanks you guys. Really appreciate it.
Hide Signatures
       Post #: 10
RE: Volcano epx pro brushless issue... - 2/24/2010 9:08 PM
chevyderek72
Score: 100
Last Login: 11/8/2010
Status: offline
Break in is really only required for nitro motors, you can break in a brushed motor, but brushless doesnt require a break in, since there is nothing touching the rotor.
If its only glitching at 80+ feet, it just sounds like a frequency issue, maybe a crystal or maybe you are just getting some interference.
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
       Post #: 11
RE: Volcano epx pro brushless issue... - 2/25/2010 12:37 AM
TCA999
Score: 101
Status: offline
After running my Volcano EPX Pro a couple of times it now runs great! The thing just moves around like a bat out of haitis...I was running in about 25 degree weather and rolled it end over end a few times but then...my luck ran out. I snapped my back right tire clean off. Ordered new parts and is all good to go now...I would like to say that the EPX PRO is a very good truck. RedCat adds new upgrades to their line often.  I would like to know a good 2s lipo battery and charger setup for it though...Any thoughts with out going way expensive?
Hide Signatures
(in reply to chevyderek72)
       Post #: 12
RE: Volcano epx pro brushless issue... - 2/25/2010 8:51 AM
UrcHobby
Score: 100
Last Login: 3/30/2013
Status: offline
The stock packs that come with the Redcat 8E's work well. BILLYMARE has the Vortex Pro and when he stops by my shop he uses my 8E's pack. It is a Hard case 2c 3200 mAh lipo. With the 1 pack it becomes a Monster and pulls the front wheels No Problem. The only thing is you will have to get raised mounts for the battery strap to hold the hard case lipo. It is no big deal and is very easy to do. The Lighting body mounts should work to raise the strap height so it will hold the lipo pack.
Urc Hobby Redcat Racing, HPI, Traxxas, XTM Racing, Venom, RC4WD, Integy, DDM Racing & PRP Dealer LI New York
Hide Signatures
       Post #: 13
RE: Volcano epx pro brushless issue... - 4/21/2010 5:02 PM
TCA999
Score: 101
Status: offline
Awesome thank you. Yesterday I bought two 7.4v 5000mah LIPO's and a LIPO smart charger. They should arrive in a couple days. Do you think I will be okay without a balancer for just about a week or two? I can't wait to test them out. I also just put on the shock shims(black plastic 3/4 of a circle looking things) and it helps the suspension significantly.
Anyways, just let me know if I'm okay with no balancer for a week or two.
Thanks.
Hide Signatures
(in reply to UrcHobby)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
