Need Help! Strange T12FGH problem!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Futaba Radios Direct support forum >> Need Help! Strange T12FGH problem!
Page: [1]
Login
Need Help! Strange T12FGH problem! - 2/9/2010 3:17 AM
no23op57
Score: 100
Last Login: 3/10/2010
Status: offline
I brought my T12FGH 10 monthes ago and the problem happened twice: 3 monthes ago and yestoday.
The problem is that once I moved the aileron stick, the throttle servo was moved together(aileron left throttle up, and aileron right throttle down).
And the throttle cut did not work when I moved the throttle stick to the bottom, seemed that the throttle position did not reach the cut-off point ... the throttle cut will only work after I move the throttle stick to the bottom and the aileron stick to the right (moving the aileron stick to the right side caused the throttle position down a bit) ...
After I turned OFF/ON the transmitter for serveral times, the problem went away and everything seemed to be OK.
Somebody told me this is a voltage regulator problem, which is common to 12FG. have you guys met this problem before? what the problem is and how can I resolve it?
Hide Signatures
       Post #: 1
RE: Need Help! Strange T12FGH problem! - 2/11/2010 4:52 PM
Krysta
Score: 100
Last Login: 3/18/2010
Status: offline
Without seeing the transmitter we cannot be sure, but from what you are describing, we can only recommend that you send this to your nearest Futaba Service Center.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
service@futaba-rc.com
Hide Signatures
(in reply to no23op57)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.156RCU1
