Did a number on my aftershock tonight!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> Did a number on my aftershock tonight!!
Page: [1]
Login
Did a number on my aftershock tonight!! - 2/12/2010 6:01 AM
dudecat
Score: 106
Last Login: 7/26/2011
Status: offline
Yep damn battery went dead in reciever and bam took off across the road and hit something solid and broke the control arms on the right side. So now i need a new airfilter/control arms/servo. Yep it is done till spring when i can get some money saved up and able to buy the parts to it says the boss. Will post pics soon.
_____________________________
Tamiya Mighty Bull!!!!
Losi Aftershock!!!
Hide Signatures
       Post #: 1
RE: Did a number on my aftershock tonight!! - 2/12/2010 6:09 AM
dudecat
Score: 106
Status: offline
Losi Aftershock!!!
Hide Signatures
(in reply to dudecat)
       Post #: 2
RE: Did a number on my aftershock tonight!! - 2/12/2010 7:06 AM
600rwhp
Score: 100
Last Login: 4/6/2010
Status: offline
I did the same to mine,but I also broke the motor mount,bent the main chassis plate,and both frame rails,lol.
Hide Signatures
       Post #: 3
RE: Did a number on my aftershock tonight!! - 2/12/2010 10:33 PM  1 votes
dudecat
Score: 106
Status: offline
Yeah i am going to try and super glue it back together and see what happens. Super glue is extremely tuff and very hard to break when you let it set overnight.
Losi Aftershock!!!
Hide Signatures
(in reply to 600rwhp)
       Post #: 4
RE: Did a number on my aftershock tonight!! - 2/12/2010 11:36 PM
HPI_Savage_RC
Score: 128
Last Login: 5/19/2013
Status: offline
I don't think super glue will work; Cyanoacrylate adhesives have very little shear strength. You would probably have better luck with an epoxy resin that has a lot of plasticizers added to increase the fracture toughness. PC Super Epoxy comes to mind. Reinforce the area with several plastic strips, and it might hold.
"Politicians and diapers are both full of crap and should be changed regularly"
Hide Signatures
       Post #: 5
RE: Did a number on my aftershock tonight!! - 2/13/2010 2:53 AM
dudecat
Score: 106
Status: offline
Well i got it to hold with some metal brackets but striped the low gear again. So this truck is now going to set idle for awhile till i get some money and fix it right again. Now i am looking at around $100 to fix it up right. Grrrr.....
Losi Aftershock!!!
Hide Signatures
(in reply to HPI_Savage_RC)
       Post #: 6
RE: Did a number on my aftershock tonight!! - 2/13/2010 4:04 AM
Argess
Score: 151
Last Login: 5/24/2013
Status: online
Get one of these (or one of the many equivalents):
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJDF8&P=ML
Hide Signatures
       Post #: 7
RE: Did a number on my aftershock tonight!! - 2/13/2010 6:04 AM
HPI_Savage_RC
Score: 128
Status: offline
quote:
ORIGINAL: Argess
Or better yet, one of these:
Built in failsafe, and no channel conflicts.
Hide Signatures
(in reply to Argess)
       Post #: 8
RE: Did a number on my aftershock tonight!! - 2/13/2010 6:30 AM
dudecat
Score: 106
Status: offline
Ok guys where do i get one of these:
It is suppost to have the little balls in it and as you can see they are gone. This is why my spurs gears got stripped. So any idea's where to get it or atleast a losi part number for it?
Losi Aftershock!!!
Hide Signatures
       Post #: 9
RE: Did a number on my aftershock tonight!! - 2/13/2010 6:42 AM
dudecat
Score: 106
Status: offline
Okay two different stores with same part number. One has this plastic bearing and other doesn't. Why is that?
http://myatomic.com/catalog/viewsku?sku=LOSB3455&q=losb3455 - doesn't show it
http://www.amainhobbies.com/product_info.php/products_id/5923/n/Team-Losi-2-Spd-Slipper-Thrust-BearingLST - shows it
Losi Aftershock!!!
Hide Signatures
       Post #: 10
RE: Did a number on my aftershock tonight!! - 2/13/2010 7:18 AM
ImpalaPolicePack
Score: 116
Last Login: 2/24/2013
Status: offline
i cant help you with your bearing but i just want to say something on the fail safe people told you to buy.( <- they are right but just wanna clarify something for you)
i run a failsafe and i recommend it to you but they wont prevent a crash like the one you had, the will aply brakes or go in neutral if your Transmitter loose signal or if batteries die.
when your Receiver batteries get to low or unplug like what happened to you, only a trottle return spring will pull your carb into neutral position, and only if its strong enough to pull back the servo arm.
i also run a trottle return spring with a traxxas waterproof servo.
that way if i turn off my Tx the truck apply brakes, and if i ask someone to hold the trottle wide open(engine off) and unplug my Rx the TRS bring my carb to idle.
never had a runaway since i run these.
i hope this helps...
Impala
My worst nightmare is that after I die, my wife sells all my RC stuff for what I told her I paid for it.
Hide Signatures
       Post #: 11
RE: Did a number on my aftershock tonight!! - 2/13/2010 7:35 AM
Argess
Score: 151
Status: online
quote:
ORIGINAL: impalapolicepack
We don't know what exactly happened to him, but when Rx batteries go low, the failsafe kicks in and there's still enough power left to bring the throttle servo back to neutral (or with brakes).
How it might come unplugged, except due to an accident, I don't know. I can't see an accident that bad where the vehicle is still on 4 wheels and manages to run away.
But "yes". a throttle return spring is a good idea, however to have enough power to bring the servo back, the spring fights the servo all the time. This results in decreased run time with respect to your Rx batteries. So.....get the Failsafe anyway, wether you use a return spring or not.
Hide Signatures
(in reply to ImpalaPolicePack)
       Post #: 12
RE: Did a number on my aftershock tonight!! - 2/13/2010 7:41 AM
ImpalaPolicePack
Score: 116
Status: offline
in all respect to you , my ofna micro failsafes wont work if my Rx batt get too low, when i loose a lot of steering force i stop running so maybe it never when low enough to activate.
Hide Signatures
       Post #: 13
RE: Did a number on my aftershock tonight!! - 2/13/2010 8:53 AM
dapro
Score: 100
Last Login: 12/23/2011
Status: offline
make sure you didn't bend the cvd.
Also what is that blue box on the front?
Unless your post is tried, tested, and true personally, don''''''''t post your "Well this guy told me" crap.
Hide Signatures
       Post #: 14
RE: Did a number on my aftershock tonight!! - 2/13/2010 11:58 AM
dudecat
Score: 106
Status: offline
blue box is battery holder lol... i will defently look into the fail safe.
Losi Aftershock!!!
Hide Signatures
(in reply to dapro)
       Post #: 15
RE: Did a number on my aftershock tonight!! - 2/13/2010 6:05 PM
Argess
Score: 151
Status: online
That's interesting. I count on mine to work when the batteries go low all the time, and it does. Perhaps you have the voltage set wrong, or using different batteries?
Although, sort of opposite your trouble, here's a copy-and-paste from a post I did a long time ago which shows the choice of batteries can affect the fail-safe:
"Added a Futaba FSU2 to the throttle servo. I think it is identical to the OFNA unit, just a different name-brand. Unit works as advertised for returning the throttle in the event of loss of transmitter signal, but there was a problem with the low battery detection circuit. I didn't know these units wern't designed for alkaline receiver batteries, but were designed to operate with nicads at either 6 volts or 4.8 volts. Well......following the instructions set the unit up for 6 volts with my Duracells I had the trouble they describe......voltage drop from alkalines triggered the threshold at 5 volts and the throttle servo returned to idle. (Interestingly, it did not come back in 1 second like it says in the manual, but stayed there until I turned the reciever off and then back on). Too much servo load caused this voltage drop with new batteries. So after a few voltage checks, it appeared that the voltage bottomed about 4.4 volts under full servo load. So, I decided to set the Fail-Safe up for the 4.8 volt setting. This unit automatically detects the voltage when you turn on the receiver while holding the "SET" button on the fail-safe. So, I took out one of the AAs and shorted the void with a jumper wire. This temporarily gave me 4.5 volts and the Fail-Safe responded thinking I had a 4.8 volt nicad pack. Then I put the AA back in and everyting is fine. The fail-safe shouldn't shut anything down now until the batteries are truly on their last legs."
Since then, I switched to 4 cell NiMh AAs and left the FailSafe in the 4.8 Volt mode. It still works aas it should, returning the throttle to idle when the batteries beme low.
Hide Signatures
       Post #: 16
RE: Did a number on my aftershock tonight!! - 2/13/2010 7:19 PM
NORCALLUMP
Score: 100
Last Login: 5/1/2013
Status: offline
EBAY those parts!!!!
Hide Signatures
       Post #: 17
RE: Did a number on my aftershock tonight!! - 6/12/2010 6:00 AM
dudecat
Score: 106
Status: offline
Well ordered the parts with the failsafe. Cost just over $100 and should be here this coming week. Taking to a hobby shop that i know and they will tune the truck in properly and make sure the clutches are set right. So the beast will be up and running again.
Losi Aftershock!!!
Hide Signatures
(in reply to NORCALLUMP)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
