RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle)
Page: <<   < prev  1 2 3 [4]
Login
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/25/2010 12:14 AM
Paul1981
Score: 100
Last Login: 3/28/2013
Status: offline
Gorgeous looking truck Brice.  Make sure you hire an armed guard for this one though; I for one don't want to see any more of your projects vanishing...!
Hide Signatures
(in reply to tonystott)
       Post #: 76
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/26/2010 8:58 AM
brice_arnold
Score: 120
Last Login: 12/30/2012
Status: offline
So I never got around to posting gearbox pics. The gearbox is made up of 15 gears and four clutches. Each track can independently be shifted proportionally from forward to neutral to reverse. What this means is that the shifting is done with clutch plates and by design is a soft gradual shift. It's not on or off. This show allow for smooth controls.
Here is a video of the gear box in action from forward to reverse.
http://www.youtube.com/watch?v=OVRBeCuj4PY
Here are all the parts in the gearbox
This is the input gear/gearbox cover
These are the shifter mechanisms. Basically the shifter is an acme screw that is coupled to a shifting gear. The gear has clutch plates and moves between a forward powered gear and a reverse powered gear.
This is the powered reverse gear assembly
This is the differential assemble that generates forward and reverse gear motion from the input gear.
Here are the output and forward powered gears installed in the case halves
Here is the gearbox almost ready to get bolted together
The shifter assembly installed onto the gearbox
The complete gearbox
_____________________________
Owner and Operator of Baja Skunkworks
Hide Signatures
(in reply to Paul1981)
       Post #: 77
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/26/2010 9:21 AM
brice_arnold
Score: 120
Status: offline
Just did a weigh in today and it came in at 76 lbs. This is what I expected. So I think it's safe to say that this is the worlds heaviest baja if you can still call it a baja.
To offset it I also just finished building what I believe to be the worlds lightest baja at 11lbs-14.5oz
Hide Signatures
(in reply to brice_arnold)
       Post #: 78
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/26/2010 9:22 AM
snoking16
Score: 100
Last Login: 8/27/2011
Status: offline
OMG
My Beer Team has a Racing Problem
Hide Signatures
       Post #: 79
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/28/2010 5:56 AM
Monsterman--HBF
Score: 100
Last Login: 6/13/2013
Status: offline
Brice
You never stop amazing me man! Your ideas and builds are by far the baddest and the sickest out there! You are for sure a Mad Scientist :lol:
Chris
I Always Fly Inverted
Hide Signatures
(in reply to snoking16)
       Post #: 80
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/28/2010 7:47 AM
brice_arnold
Score: 120
Status: offline
Thanks for the kind words guys. I got some footage today. We will try and get a teaser video up in the next day.
Hide Signatures
(in reply to Monsterman--HBF)
       Post #: 81
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/28/2010 10:00 AM
savtraxx
Score: 100
Last Login: 6/10/2011
Status: offline
can i ask you a serious question?
when you arent playing with toys are you a rocket scientist?
amazing..
Hide Signatures
       Post #: 82
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/28/2010 10:50 PM
brice_arnold
Score: 120
Status: offline
Ok guys here is a teaser video. First run proved to be promising. There are a couple of bugs that I still need to work out.
1. The receiver I used is a cheapie FM receiver. It was very susceptible to RF noise coming from the ending. This caused the servos to go crazy and made it very difficult to control. I will be upgrading the receiver to a DSM 2.4 Ghz system.
2. I didn't use loctite on the track bearings so I started to lose screws and bearing towards the end of the trial run.
Enjoy.
http://www.youtube.com/watch?v=rANs8Ll0hf4
Hide Signatures
(in reply to savtraxx)
       Post #: 83
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/28/2010 11:13 PM
DarkFire989
Score: 235
Last Login: 6/19/2013
Status: online
Looks good brice. It did seem kinda wacky in the vid.
Clod Buster | Sludge Hammer | Blue Streak | Revo | Baja | CR-01 | FG MT
Hide Signatures
       Post #: 84
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/28/2010 11:32 PM
brice_arnold
Score: 120
Status: offline
Yep, the servos literally had a mind of their own moving back and forth non-stop.
Hide Signatures
(in reply to DarkFire989)
       Post #: 85
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/28/2010 11:52 PM
DarkFire989
Score: 235
Status: online
Hows the engine doing? Does it struggle at all?
Hide Signatures
       Post #: 86
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 3/29/2010 4:27 AM
brice_arnold
Score: 120
Status: offline
Nope the engine is a powerhouse and it's geared perfectly. When the servos randomly engaged the clutches the tank would rear up on it's end. Lot's of torque. It reminded me of the ripsaw videos.
You figure these motors have been used on go-peds to get a 200 lb person up to 60 mph so it shouldn't have any problems with my little tank.
Hide Signatures
       Post #: 87
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 4/12/2011 4:08 AM
lithiumx152
Score: 111
Last Login: 5/8/2013
Status: offline
my brain hurts
Hide Signatures
(in reply to da mad maori)
       Post #: 88
RE: Home Built Baja 5T-PTV (Personal Tracked Vehicle) - 4/13/2011 5:01 PM
Nitro Fumes
Score: 100
Last Login: 6/18/2013
Status: offline
That's a fantastic project! You sure have done a lot of work. But how are you going to make it steer? Are putting a differential brake system with a brake on each rear "wheel"?
If it hasn't got 4 wheels, makes a damn hell lot of noise, it's of no concern to me.
Hide Signatures
       Post #: 89
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
