BykrDan
[QUOTE]Originally posted by zhanx ...just need to finish the wings and cover them both.., only problem is the only real covering i got is a thicker food wrap we can get from the chow hall, which should work fine.. gonna do a test on a test frame with a heat gun and different glues (only got super glue, white wood glue and epoxy) and see how it works.. or should i use paper got lots of basic white paper. got a some polyurethane think i should seal the plane with before covering? [/QUOTE] I've heard of people using Saran wrap to cover planes before, mostly on micro and indoor models (so you know it's light!) No need to heat-shrink even, I don't think. Only problem is getting it to stick. Not sure how that problem was overcome. Paper sounds durable, should have no problem sticking, but it may add more weight than you want to an already heavy plane, particularly if you choose to varnish it. Can you get newspaper? It's lighter, I think, and I believe I've heard of good results using varnished newsprint. I'd certainly put some kind of paint on if I did that! Hang in there - I heard of a guy in the reserves who made a functional hot air balloon out of dry-cleaner garment bags, popsicle sticks, and birthday candles! Dan.
