Desertlakesflying
Score: 120 Joined: 7/7/2005 Last Login: 5/20/2013 From: Sun Valley, NV, USA Status: offline
I guess I just prefer planes that fly off the water and don't have to be forced because the step is in the wrong place, which is the case on 99% of the planes that have to be forced off the water. Having the floats level to the horizontal stab will produce the needed incidence in most of the airplanes out there, unless of course they are kits built with 0 wing incidence which I can't understand why anyone would build a plane which could be put on floats that way. Most prop planes have incidence, maybe not the jets. My plane sits perfectly level on the water, and I'm exactly even with the step and the CG. The cub I recently helped get set up is the same way and reacts the same. No extreme angles, no bigger motors, just the right setup the first time. Cublover post from other thread to add context: "Scale, just so you know, those floats are NOT wrong. How do I know? I've been putting on floats for over 18 years, other than being a tad bit to tall, and there is a reason for that, "prop is big" I have flown Cowboys Husky several times and its flawless. People who put floats on planes do everything wrong, and some just "get it right" and think there an expert on it. I KNOW your gonna tell me I'm wrong, and thats OK. But the fact is, is that this plane fly's perfect EVERY TIME, with no bad habits. The reason you have to tap the elevator is because like all good RC pilots, we fly with just a tad bit of "down" in it. Every plane I have EVER done, including this one, have flown real well with the float set up that was put on it. and there is a reason for that as well. Just like EDO and all float manufactures will have in there install manuals. it is set up that way Step,,,,,,,,,,,,,,,,,,,, just ahead of the CG 1/8 to a 1/4 inch and deck of float,,,,,,,,,,,,,,,,,, level to horizontal stab If you keep with this formula you WILL have a great fly'n plane, no matter if you put floats on a 330L or a Stearman. hahaha Have a good day...Rod"
_____________________________
Back Roads Outlaws Revver #165
Hide Signatures
