RE: MVVS 40 Diesel    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> RE: MVVS 40 Diesel Page: <<   < prev  1 2 3 [4]
Login
RE: MVVS 40 Diesel - 5/24/2012 9:51 AM
fiery
Score: 100
Last Login: 5/21/2013
Status: offline
This bronze head MVVs 40 recently made it's way to me.
I suspect it is one of the (up until now for me, mythical) factory MVVS 40 diesels.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to bogbeagle)
       Post #: 76
RE: MVVS 40 Diesel - 5/24/2012 1:39 PM
Hobbsy
Score: 650
Status: offline
That is exactly the way my MVVS .61 Diesel head was constructed but it lacked that purty paint job.
_____________________________
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to fiery)
       Post #: 77
RE: MVVS 40 Diesel - 5/24/2012 1:50 PM
AMB
Score: 110
Status: offline
my MVVS 40 and 61 are Davis diesel heads, typical davis construction no bronze inserts martin
Hide Signatures
(in reply to Hobbsy)
       Post #: 78
RE: MVVS 40 Diesel - 5/24/2012 2:24 PM
AMB
Score: 110
Status: offline
quote:
ORIGINAL: AMB
Post note I sold off all the Irvine 40 diesel heads and the MVVS factory 61 head to offset the cost the the Davis heads have never had any problem with any Davis head
Hide Signatures
(in reply to AMB)
       Post #: 79
RE: MVVS 40 Diesel - 6/12/2012 10:50 PM
ddd
Score: 100
Last Login: 5/17/2013
Status: offline
WE HAVE ONE mvvs 6.5 HEAD LEFT IN STOCK.
Bob Davis, Owner - Davis Diesel Development
Hide Signatures
(in reply to Recycled Flyer)
       Post #: 80
RE: MVVS 40 Diesel - 6/20/2012 3:47 AM
Recycled Flyer
Score: 101
Status: offline
And another one!
http://www.ebay.co.uk/itm/Vintage-model-engine-diesel-6-5-MVVS-made-in-Czechoslovakia-/270999187012?pt=Radio_Control_Parts_Accessories&hash=item3f18cf6e44
Standard issue MVVS?
Click for fullsize
Hide Signatures
(in reply to ddd)
       Post #: 81
RE: MVVS 40 Diesel - 6/20/2012 4:35 AM
AMB
Score: 110
Status: offline
My MVVS 40 * which now has a davis head) the factory head did not have the dome that the compression screw fits in , just flat no tommy bar, that must be an early one. the 61 is gone, bore and stroke increased to a 77 , do not think a diesel head for it , (Pe Rievers site) martin
the 15 is history
< Message edited by AMB -- 6/20/2012 12:25 PM >
Hide Signatures
       Post #: 82
RE: MVVS 40 Diesel - 6/20/2012 7:43 AM
ddd
Score: 100
Status: offline
I have one left if you would like it let me know.
Hide Signatures
       Post #: 83
RE: MVVS 40 Diesel - 6/20/2012 11:53 AM
AMB
Score: 110
Status: offline
Bob Davis which one 40, 61 or both ??? (MVVS) martin
Hide Signatures
(in reply to ddd)
       Post #: 84
RE: MVVS 40 Diesel - 8/27/2012 2:18 AM
fiery
Score: 100
Status: offline
MVVS "bronze head" .40 (6.5 cc) diesel on the bench.
Non OEM carb did not throttle particularly well. It will be replaced with an MVVS carb for the next running session.
http://www.youtube.com/watch?v=MfJFcPa-spQ&feature=channel&list=UL
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to AMB)
       Post #: 85
RE: MVVS 40 Diesel - 12/9/2012 5:59 AM
fiery
Score: 100
Status: offline
Re-ran the above MVVS .40 engine with a current specification MVVS R/C throttle carburettor. 11.3 x 8.2 prop fitted.
It did not perform any better.
It did not sound happy.
Even with the contra-piston adjusted as far out as possible, and a rich setting, the engine ran over-compressed. Very dark exhaust goop with black soot spots, no matter what I tried.
Disappointment. I removed the head. One standard aluminium head shim had been fitted. Contra-piston noted as being 2 mm up from flush.
Time for plan "B".
Earlier in this thread Bob Davis offered an old stock MVVS .40 diesel conversion head to anyone who wanted it. Back then I contacted Bob, and we concluded business. Head duly delivered and put in box with engine.
With engine still in the stand, DDD head was taken out of its packet, and installed in a trice.
Re-start.
Result - complete success. Easy adjustment, light honey coloured exhaust oil. DDD allen head compression adjusting screw setting non critical; but linear and positive to adjustment. Screw ultimately set about 1 mm above bottoming out. Hand starting a breeze.
Remedy for factory head? Rubbish bin? No. Will we will sort it? Yes. Too much fun to be had not to! Also, too easy.
I will skim the factory head chamber a small increment (using my friends lathe). However, firstly, I will just buy more shims; or make a thicker one or two, just for fun, from the skin of a can of my favourite summer drinking pilsner, in order to raise the deck by small known measures.
Then, skim factory head button once value is known.
Video of run with DDD head installed:
http://www.youtube.com/watch?v=v1cAeFnhgcQ&feature=youtu.be
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by fiery -- 12/9/2012 8:24 PM >
Hide Signatures
(in reply to fiery)
       Post #: 86
RE: MVVS 40 Diesel - 12/9/2012 4:02 PM
AMB
Score: 110
Status: offline
No surprise on the preformance of the Davis head over the MVVS both my MVVS 40 and 61 wear them the 61 came with the stock MVVS head and was replaced with the Davis
Ditto on all my Irvine 40 diesels, all replaced with Davis , much easier to adjust and more power than the stock ones
If you are considering a non-classic diesel it might be wise to pick and buy one * that Davis makes a head for Fox ,OS etc check the list of available heads on his site martin
* Glow that he has heads for
Hide Signatures
(in reply to fiery)
       Post #: 87
RE: MVVS 40 Diesel - 12/10/2012 1:20 AM
Recycled Flyer
Score: 101
Status: offline
quote:
ORIGINAL: fiery
Derek, you are running more than 11" diameter and more than 8" of pitch and wondering why it sounds overcompressed?
Take it back to an 11x6, rinse and repeat mate. You should be getting about 12000 rpm with this prop.
Hide Signatures
(in reply to fiery)
       Post #: 88
RE: MVVS 40 Diesel - 12/10/2012 1:59 AM
fiery
Score: 100
Status: offline
Might just do that with an APC, RAM, Master Scimitar, or other light load prop.
That old Thunder Tiger prop really is a club. My four strokes liked it back in the day.
It is interesting that there is no squish band or combustion bowl in the MVVS head. Bottom of button insert and contra are dead flat.
< Message edited by fiery -- 12/10/2012 5:06 AM >
Hide Signatures
       Post #: 89
RE: MVVS 40 Diesel - 12/10/2012 2:19 AM
AMB
Score: 110
Status: offline
Fiery Pinnocks review on the MVVs 40 9600 Davis head APC 11x6 if you go on the davis site reviews MVVS by Pinnock all listed 21 and up
martin
yes Davis did make a head for the 21 also
Hide Signatures
(in reply to fiery)
       Post #: 90
RE: MVVS 40 Diesel - 12/10/2012 3:27 AM
steve111
Score: 100
Status: offline
quote:
ORIGINAL: AMB
I'd have thought 9600 for a diesel .40 was pretty reasonable (PAW .35TBR does about 9000 from memory). In Fiery's video it's doing about 8500, which again seems ok for an 11.3x8.2.
Hide Signatures
(in reply to AMB)
       Post #: 91
RE: MVVS 40 Diesel - 12/10/2012 5:04 AM
fiery
Score: 100
Status: offline
My tach batteries went flat as I left them on after my last bench test session. One of those "Hmmm" moments as I fronted the blades and switched on [>:] .
I will replace them and re-run the MVVS using a lower load fan to get some figures.
Will post further to update findings.
Hide Signatures
(in reply to steve111)
       Post #: 92
RE: MVVS 40 Diesel - 12/10/2012 6:30 AM
steve111
Score: 100
Status: offline
Hi Derek, I've got an audio tacho app on my phone, so can get readings from YouTube vids etc. Quite handy. (Your Irvine 20 was doing about 10600 btw).
Hide Signatures
(in reply to fiery)
       Post #: 93
RE: MVVS 40 Diesel - 12/10/2012 9:20 PM
AMB
Score: 110
Status: offline
OK all had a little time so pulled the MVVS 40 Davis head off the shelf and did a re-run today . fuel DAVIS ABC
Wood zinger 12x6 8700
wood XOAR 12x5 9900 Did not believe this shut down restart still 9800-9900
wood XOAR 12x8 8100-8200
compression very good had to set about 2 turns open to get rid of the overcompressed rattle then it hummed
main needle about 2 1/2 open did not mess with low speed needle running about 2800 idle instant pick up to WOT
I know should run apc plastic and revs will be better Davis tells me this all the time martin
oil out the pipe, not much but almost black, smoke not that much clean runner
next trip to LHS will pick up an 11x6 should get around 10K about the same as the 12x5
< Message edited by AMB -- 12/10/2012 9:46 PM >
Hide Signatures
       Post #: 94
RE: MVVS 40 Diesel - 12/10/2012 9:50 PM
AMB
Score: 110
Status: offline
deleted dup post
Hide Signatures
(in reply to AMB)
       Post #: 95
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
