Great surface for mixing epoxy
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Great surface for mixing epoxy
Page: <<   < prev  1 [2]
Login
Great surface for mixing epoxy - 7/16/2003 5:31:46 PM
daniel_cox
Status: offline
I built a very useful tool for mixing epoxy from a piece of plywood (about 3 by 6 inches) with a couple of supports on one end to hold a spool of calculator paper on a dowel. The paper passes under a piece of hacksaw blade on thin plywood standoffs and held at the other end by a rubber band. Mix the epoxy and tear off the paper against the hacksaw blade after the expoxy cures. Not my original idea - I swiped it from one of the RC magazines years ago.
(in reply to jchumley)
       Post #: 26
Great surface for mixing epoxy - 7/18/2003 12:01:13 PM
ChiefThief
Status: offline
I have found disposable plastic knives to be good for both mixing and spreading epoxy. The serrated edge acts like the trowels used to tile floors, leaving an even amount of epoxy in lines as the epoxy slips between the teeth. There are several different sizes of teeth available, depending on which restaurant you liberate the knife from.
Also, since they are plastic you can flex them to pop the epoxy off after it cures.
_____________________________
ChiefThief
       Post #: 27
Great surface for mixing epoxy - 7/27/2003 11:06:09 PM
runover1
Status: offline
I use the backing of FedEx slips. I have a whole stack that I kept when the company changed the address. I use it once or twice, then throw it away.
       Post #: 28
Great surface for mixing epoxy - 7/28/2003 3:44:37 AM
GIFLYRC
Status: offline
I USE OLD PLAYING CARDS--A DECK WILL LAST NEARLY A YEAR!!
JUST MIX ,USE AND PITCH--
ROGER aka GIFLYRC
INDEPENDITLY POOR
       Post #: 29
Great surface for mixing epoxy - 7/28/2003 5:31:46 AM
jettstarblue
Status: offline
Magazines, great for mixing, shims, and oh yeah, reading.
Jetts
       Post #: 30
Great surface for mixing epoxy - 7/28/2003 6:12:39 AM
Combat Addict
Status: offline
Back to my topic on foam cutting, has anyone tried to cut foam with the mixing boards? I haven't yet
I can do that, Watch!
BVRC-Member
       Post #: 31
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU5
