davidfee
Joined: 6/21/2003 From: San Diego, CA, USA Status: offline
WM, As you know, Wakefield rules have evolved over the years. The methods of measurement have also changed, as mentioned by Mike. Here is a nice history of the Wakefield Cup, from 1911 to the present. http://www.btinternet.com/~kaynes/Wakebook/wkbkhome.htm Interesting highlights: "Prior to the end of the 1933 flying season the SMAE did some serious fiddling with the Wakefield Cup Rules. First they deleted the "Any Type of Power Rule", restricting power to "Rubber Power Only", then they restricted the wing area to be between "190 & 200 sq. inches", then they placed a limit on total weight including rubber motors to be "4 Ounces Minimum", and finally they made the flight time to be the "Average of Three Flights". So much for the threat of petrol powered, and outdoor-indoor aeromodels!" "1956... This contest marked the end of the "Traditional Wakefield Era", long live the "Modern Era"! At last "they" had done away with that (quoting Bill Dean) "....stupid obsolete rule..." This was the last contest that required the "Rise Off Ground" (ROG) launch. Now Comrades: "you may never go home again!" " Anyway, if you are building replica models and people want to know what area they have, simply ask them to specify a set of measurement criteria. have fun, -David
