badazzbusa
Joined: 12/12/2004 From: Mechanicsville, VA, USA Status: offline
Tony, I don't have this plane so can't answer all your questions. In regard to the firewall, it's angled for right thrust. Don't mount your engine (on all planes) to the center of the firewall. The prop shaft needs to come out the center of the cowl. With the engine mount angled to the right, the engine is mounted left of center on the firewall, with the engine left of center and the firewall angled to the right, it allows the prop shaft to be in the center of the airplane. Without the proper right thrust, the torque of the engine and prop will not allow the plane to fly perfectly straight. To check this, pull vertical and see if the plane climbs true. If the tail is left or right of center then your right thrust is off. Generally, you can epoxy a small piece of ply in the wheel pant above the axle, cut a slot in the pant to slide over the axle, between the wheel and the gear. Drill a hole thru the gear and ply plate you epoxied. Remove the pant and install a blind nut in the ply. Install the pant back on th |
