templates?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> templates? Page: [1]
Login
templates? - 4/4/2002 8:14:32 AM
highflyer353535
Status: offline
i was just wondering what is a good template making material thanks
       Post #: 1
template's - 4/4/2002 8:21:33 AM
jdwiflyrc
Status: offline
Any relatively hard material such as plastic, aircraft plywood, formica and even thin metals.
Hope this is the answer you were looking for.
Enjoy fly'in, John
_____________________________
All my landings are successful-They all reach the earth
I'm 64 & don't know everything yet
(in reply to highflyer353535)
       Post #: 2
templates? - 4/4/2002 10:22:45 AM
Someone11-RCU
Status: offline
What is formica? I head about formica being used for foam wing core template making. Don't carpenters use this stuff?
Thanks - Brian
Thanks for the forums!
       Post #: 3
Formica - 4/4/2002 5:26:24 PM
jdwiflyrc
Status: offline
Hi Brian, formica is the material that is used to make counter tops with, such as in the kitchen and bathrooms. It is a veneer sheet that is glued to the wood.
Available in sheets which is cut to size. contact a cabnet maker in your area and you may be able to get scrapes for little or no cost.
Good luck and keep fly'in, John
       Post #: 4
Template material - 4/18/2002 12:55:45 AM
Eaglewatch
Status: offline
A really good material to work with is called "See Temp".
I have used it for many years, and it is easy to make templates with it. All you have to do is place it over the part to be traced, follow the outline with a pen or pencil, and score the line with a razor knife. Then simply flex the See Temp at the score, and it snaps clean.
It's available in sheets about 22" x 51" for around $ 5.00, with discounts on larger quantities.
A tip: Store it flat at all times, or it can curl, or assume the shape it is stored in.
See-Temp website: http://www.seetemp.com
Regards,
Al Parry
[email]amp@intercom.net[/email]
Owner - Instructor
Aeroglass R/C Flight Academy
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU5
