JimCasey
TN, USA Status: offline
I believe the floats are too far forward. My reference tells me the the effective step is the WIDEST point of the step when the floats have a tapered step like the GeeBee floats. Also, the floats look to be larger than the traditional guideline of 75%-80% of the length from the prop to the rudder hinge. The only thing this really hurts is that the floats are heavier than they should be. Your floats look to be nearly the full fuselage length. You also need to add some incidence to get the nose up. With the way your floats are mounted, make a 1" long mending plate from aluminum strip and add it to the front float mount. one hole in 1/4" from the end will bolt to the float, and one hole 1/2" higher will bolt to the existing hole in the struts. SPray deflectors, as described earlier, help. Initially, start your takeoff with full up elevator. This gets the nose up and helps the prop clear the spray. After a second or 2 the plane will pop up on the step. Relax elevator and let it accelerate. Then gently give it 1/4" back stick and it will lift off. Personally I continue not to be a fan of GeeBee floats, and suggest that you get a good set of foam floats from one of the vendors listed in the FLFLFL website (below). OR from Plane Fun FLoats who participates in this forum as "seaplane". I keep promising myself I will post his link in the website, but still have not done it.
< Message edited by JimCasey -- Jul 15 2003 2:07AM >
_____________________________
Jim Casey/Seaplane Nerd http://www.smilesandwags.com/Floats.html
