35% Carden Cap Landing Characteristics !?!?
Tower Hobbies
Logged in as Guest
  Printable Version
C-130 Hercules 108" span Gas or Electric! - Kit
Seller:  penceaviation
Details:   $245.00   |  8/4/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> 35% Carden Cap Landing Characteristics !?!?
Page: [1] 2   next >   >>
Login
35% Carden Cap Landing Characteristics !?!? - 7/14/2003 9:03:44 AM
alcohol burner
Status: offline
I have an older Carden kit that has the old style plug-in wings.
The plane weighs just less than 28lbs......I have a DA 100 on it....
The rudder servos and the elevator servos are all mounted in the back of the fuse next to the tail. I have "C.G." set to where it is just a tad nose heavy....Meaning it just starts to fall forward on "CG" machine....Balanced almost perfect.....My problem is this:
When coming in for a landing the approach looks fabulous. Slows down nice and easy. When it comes in nice and flat and when it just starts toget ready and touch down i feed a little up in it and it will balloon up....Then its in a complete stall....I power up and then land it that way....Usually not a good landing...bounces pretty hard.....My air speed appears to be fine....Also when coming i try slowing even farther down then it looks agin real good...then when it is about 3 ft off the ground it just falls out of the sky....Ive tried fast landings and slow....The "window" of opportunity is very small and it sucks....I was just wondering if this is just a typical cap ???? Some of my friends are saying that it is.....We also noticed at the Joe NAll fly-in that noone landed a cap in a 3 point landing...Tail first....Basically a complete stall....They wer all landing fairly fast....Is this the reason !??!??
I am totally confused on this airplane....I hate to get rid of this plane, but i will before I screw up big time....It flies fabulous.....3D's nice......flies inverted great....Nice knife edge loops....nice waterfalls......It just "SUCKS" landing the damn thing.....Any info will/is much appreciated...
THANKS
TIM ADAMS..
       Post #: 1
35% Carden Cap Landing Characteristics !?!? - 7/14/2003 9:20:17 AM
CAPtain232
Status: offline
Are you using any expo on the elevator? It kinda sounds to me like there is too much elevator travel even with a small amount od stick. Can you fly slow at say 10 feet and give a small amount of elevator without ballooning? (simulate a landing at 10 feet)
_____________________________
CUSTOM GIANT SCALE BUILDER
PROTOTYPE MODEL BUILDING for full scale aircraft
current project can be seen at http://www.geversaircraft.com
(in reply to alcohol burner)
       Post #: 2
35% Carden Cap Landing Characteristics !?!? - 7/14/2003 9:27:04 AM
alcohol burner
Status: offline
I AM RUNNING ALMOST 80% OF EXPONENTIAL....AND ON LOW RATES.....LOW RATE IS ABOUT 12-15 DEGREE ANGLES....HIGH RATE IS UP TO 30 DEGREES.....I USE LOW RATE ELEVATOR AND HIGH ON AIRLERONS....WHICH NEVER HAVE TO HARDLY USE AIRLERONS....IT COMES IN FLAT AS A BOARD......
THANKS...
TIM
       Post #: 3
35% Carden Cap Landing Characteristics !?!? - 7/14/2003 5:35:38 PM
SMALLFLY-
Status: offline
Try adding a little bit of spoileron on landing. The constant down pressure of the ailerons may well make it stick down
       Post #: 4
35% Carden Cap Landing Characteristics !?!? - 7/14/2003 5:58:54 PM
Flyfalcons
Status: offline
Try a lot less expo. It sounds like when you add just that little extra up elevator, the expo is kicking in and the elevator deflects too far up. 30% expo would make the plane much easier to fly.
Ryan Winslow
Cub flying - the new EXTREME SPORT!!! (evarrr)
       Post #: 5
CAP landing technique - 7/14/2003 6:36:07 PM
WarpedWing
Status: offline
this sounds a lot like my Lanier Cap (28% scale). Elevator authority with this plane is huge (elevators are very big--bigger than an edge or extra) and its common to see final landing approaches get ruined by "ballooning" at the very end. I'd suggest the following:
1. I found that controlling descent on final with small "blips" of throttle was much more effective than using elevator. I got the same "ballooning" effect with my plane using just elevator inputs. If you have a triple rate capability on your transmitter, you might want to set up a smaller elevator throw just for landings.
2. you might want to experiment with expo----80% sounds like a lot to me. Most folks I know are using 20 to 30%. With the expo you're using, it might "mask" the initial inputs too much and deceive you into using more input than you really intended to use (and cause the ballooning).
3. I like the spoileron idea. Didn't try it on mine, wish I had (no longer have the plane).
4. might want to check your engine incidences. Don't know about the Carden recommendations, but most Cap pilots I know have got 1-2% downthrust in their set ups.
My observation is that this plane just lands faster than an Extra or Edge. I haven't seen anybody bring theirs in at a crawl pace--everybody seems to bring theirs in fairly quick. I really like the looks of the CAP in the air---and love the way it performs at cruise speeds. I've found landings are an adventure---no 2 seem to be alike.
       Post #: 6
35% Carden Cap Landing Characteristics !?!? - 7/14/2003 7:47:02 PM
Jason 3-Danhakl
Status: offline
Its a Cap. They all drop there rear when you get real slow. This is why they 3-D so well. I've flown several different kinds and they all do it. If you have them tail heavy they are worse. You might want to try more nose weight. You don't have to have a tail heavy airplane to 3-d well. The Carden flys very well but it is hard to land. A down elevator mix with low throttle will help your problem also. I tried the flaperion trick and didn't like it. The down elevator mix will help your down lines from pulling out by them selfs also. A little Imac trick that has two purposes with the Cap. Hope this helps. Jason Danhakl
Team Futaba
       Post #: 7
35% Carden Cap Landing Characteristics !?!? - 7/15/2003 4:40:43 AM
DENNIS C
Status: offline
Interesting...
"Opinions are like Buttholes EveryBody has one "
       Post #: 8
35% Carden Cap Landing Characteristics !?!? - 7/15/2003 8:04:12 AM
EJB
Status: offline
Jason hit the nail on the head.Ballooning is very common for most Caps.Most likely it's a little tail heavy.The best way would be to take the rudder servos out from the tail & switch to a pull-pull.That should do it.A quik way to find out -just simply add some lead temporarily in front & see what happens.
       Post #: 9
35% Carden Cap Landing Characteristics !?!? - 7/15/2003 8:08:49 AM
Diablo-RCU
Status: offline
Now that everyone has placed their guesses, I can tell you the real answer. This particular plane is TAIL HEAVY. My buddy HT owned it and had the same problem. Had a DA-100 in the nose. Ballooned like crazy on landing. Added 3 lbs of steel to the nose. Plane then flew and landed great. If you don't like adding weight, put the rudder servos on pull-pull. But, you'll still need at least a pound of nose weight even with the servos moved forward.
Hey Ed, you beat me to the post. This was HT's Teal Cap.
       Post #: 10
35% Carden Cap Landing Characteristics !?!? - 7/15/2003 6:31:57 PM
Johng
Status: offline
Make sure you only have the minimum elevator travel you need to just barely stall/snap the plane on low rates. If you aren't using half stick just to turn around the end of the field you probably want to reduce travel.
This is a "feature" of CAPs as far as I can tell. When I first flew mine (80" Lanier) it was tailheavy. It flew fine and did 3-d great - but I actually had to hold forward stick on final and flared by releasing elevator back to center. wierd!
After that, I added a pound of lead over the engine and it then behaved like yours is - it would come down the chute to landing and then if just the tiniest bit too agressive on elevator it would balloon down the runway. If not agressinve enough it would plow in - Splat!.
I was still getting used to setting up for a short landing, then letting it "float" to where it would touch down on the runway when the engine died 20 feet high on a touch 'n go. Shorty after that, the plane died too.
John
       Post #: 11
35% Carden Cap Landing Characteristics !?!? - 7/15/2003 7:15:41 PM
EJB
Status: offline
Yikes!....small world.
If I remember corectly,I think the batteries can be moved up further up front-that should help.
Hey Tim,get a DIE HARD & stick in in there.
       Post #: 12
35% Carden Cap Landing Characteristics !?!? - 7/15/2003 11:11:28 PM
alcohol burner
Status: offline
Diablo....Who is HT?
just curious......i thought about adding weight......
didnt want to take time and convert to pull-pull.....because i am having a 35% edge being built now....i just went and got this plane to get use to flying larger scale before flying my new one.....
so far it has been bad experience......hate to even think the edge would behave like this....i will have almost 4,000.00 in my new edge......
EJB.....DIe Hard.....HUH.......I think the DA100 has enough power to pull it....ha.h.a.hahaha.......
If it wasnt for this engine i would have destroyed plane long before now.....It pulls it out of any situation....(so far anyways !!!).......
thanks for input guys.......I will add weight to it this week just to see if it helps......all my batteries are right behind the fire wall now.......i will throw some bb's in one of those wraps you use to wrap quartes in......then ill tie them to the fire wall.....dont want to use real quarters......no need any more money in plane hitting ground....
       Post #: 13
35% Carden Cap Landing Characteristics !?!? - 7/16/2003 5:24:08 AM
Diablo-RCU
Status: offline
HT is Hyper Tom, our local excitable boy (talks a mile a minute). EJB has built quite a few planes for HT over the last few years, but didn't build this Cap.
If you add the nose weight, the plane will fly super and still have great vertical with a DA-100. No BS.
       Post #: 14
