OS FP.40 with a MECOA K&B RJL Diesel Head    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> OS FP.40 with a MECOA K&B RJL Diesel Head
Page: [1]
Login
OS FP.40 with a MECOA K&B RJL Diesel Head - 3/10/2010 5:53 AM
Recycled Flyer
Score: 101
Last Login: 6/19/2013
Status: offline
 Hi all,
Is an OS FP.40 with a MECOA K&B RJL Diesel Head much use these days?
They are both new and are available, and the intended use is for control line stunt.
Thanks in advance.
Hide Signatures
       Post #: 1
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/10/2010 11:39 AM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: Recycled Flyer
 Hi all,
Thanks in advance.
They are good for just as much use as they ever were, I would think.
I have a Magnum .40 GP and the same Diesel conversion head as you mentioned. Unfortunately, both are in the center of a two car garage that is stacked floor to ceiling with no way to get to them at the moment. Sure wish I could get to them to play with. Let us know how you make out if you decide to take the leap.
Ed Cregger
_____________________________
"Practice makes prefect"
Hide Signatures
(in reply to Recycled Flyer)
       Post #: 2
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/10/2010 11:59 PM
maxtenet
Score: 100
Last Login: 6/18/2013
Status: offline
I actually have the same MECOA head on a Tower .40 and it works flawlessly. The Tower .40 is basically a copy of the OS FP and the OS should perform well. Not a powerhouse but as docile as any diesel made. One flip starts and throttles very well! Mine is on a Stick trainer used for my nephews to get started in RC. Reliable as a Deere.
Max
Hide Signatures
(in reply to NM2K)
       Post #: 3
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/11/2010 1:51 AM
fiery
Score: 100
Status: offline
I have the same RJL head on an early ROYAL .40. , it's a nice ball raced engine (pretty much a copy of the O.S. .40 FSR, made by Thunder Tiger for ROYAL I believe), nice blue anodised head.
I have not run the ROYAL yet, too busy with work etc . I will also be putting a 6 mm throat carb on it, for better throttling.
Hide Signatures
(in reply to maxtenet)
       Post #: 4
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/11/2010 2:42 AM
Recycled Flyer
Score: 101
Status: offline
quote:
ORIGINAL: NM2K
 Hi all,
Thanks in advance.
Ed Cregger
Hi Ed,
I know that the head is as good as it ever was but was more wondering if it is the best buy now that there are more choices available.
For example, I could simply go out and buy a Davis Diesel OS Max LA 40 or 46 very easily with far better spares backup, so its more that should I use the older discontinued OS Max FP over a more modern available setup?
What makes me like the older setup is that its a bit unusual and cheaper, and it not that blue colour that some of the LA's are these days.
Thanks.
Hide Signatures
(in reply to NM2K)
       Post #: 5
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/11/2010 2:52 AM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: NM2K
 Hi all,
Thanks in advance.
Ed Cregger
Hi Ed,
Thanks.
Well, this is one decision that I can't help you with, as much as I would like to help. To me, the OS FP series of engines are still "new", even though they have been superceded by the LA series. If I didn't have the conversion head yet, I'd have to look at the Davis head with my scrutiny, versus buying another brand conversion head. Me, I already have the engine and the conversion head, so there is no debate for me.
Ed Cregger
Hide Signatures
       Post #: 6
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/11/2010 5:57 AM
FrancisPerson
Score: 100
Last Login: 3/14/2011
Status: offline
Recycled Flyer,
I have a OS FP .40 with a Davis head and it is a beautiful combination. The FP .40 is almost three oz lighter than a LA .40! If you have a chance for a new FP .40 then get it and if the RJL head does not work out then try a Davis head if you need to.
FP .40=Great engine!
Francis
I love Diesel
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 7
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/11/2010 6:08 AM
AMB
Score: 110
Status: offline
Francis what is that 4 banger in??? martin
Hide Signatures
(in reply to FrancisPerson)
       Post #: 8
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/11/2010 4:43 PM
Hobbsy
Score: 650
Status: offline
Hey Martin, Francis is the proud owner of a new Kubota 26hp tractor, he may correct me on the hp. In many cases Diesels are odd numbered cylinders because Diesels work better with larger cylinders. In other words 3 or 5 larger,(Audi) is better than 4 or 6 smaller sized ones.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to AMB)
       Post #: 9
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/11/2010 5:27 PM
AMB
Score: 110
Status: offline
Tx dave did not know it was a tractor,gotum beat though by 3 cylinders my dodge 2500 sports a 5.9 6 cyl Cummins martin
As a footnote as of yesterday 3/10/2010 retired from winn dixie as a full tme Pharmacist will now have time to mess on the bench and fly
my planes, the latter of course the real fun
Hide Signatures
(in reply to Hobbsy)
       Post #: 10
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/12/2010 1:06 AM
Recycled Flyer
Score: 101
Status: offline
I had a 3 cylinder K75 BMW motorcycle for years and much to my riding buddies disgust it ran as smooth as silk because both the primary and secondary vibrations were very low and there only remained a rocking couple along the crank shaft that was dealt with by a balance shaft that ran at the same speed as the crank.
The 5 cylinder Audi simply uses the same thinking as the 3 cylinder engine but uses cylinders 1 and 5 as the 'balance shaft.'
Combined with the above posts I think that odd numbers of cylinders in diesels also run better because of the above reasons.
Hide Signatures
(in reply to AMB)
       Post #: 11
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/12/2010 7:47 PM
FrancisPerson
Score: 100
Status: offline
The moral of this story is if you can get your hands on an OS FP .40 DO IT! This is a lightweight smooth and running as glow or as diesel. The LA series are fine sport engines and good diesel conversions but why do they weigh so much more?????????
Francis
Hide Signatures
       Post #: 12
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/12/2010 10:23 PM
Hobbsy
Score: 650
Status: offline
Next time someone says the odd cylindered engine should shake, remind them that inside the odd numbered engine no two parts are moving in the same direction at the same time nor by the same amount at the same time.
Hey Francis and Martin, long time no talk
RF, those K75s still bring big bucks if in decent shape. One of the salesmen at Mortons BMW in Fredericksburg has about three of them.
Hide Signatures
       Post #: 13
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/20/2010 10:14 PM
buzzard bait
Score: 115
Last Login: 6/17/2013
Status: offline
I'm puzzled by the comments about a weight difference between LA and FP. I have the FP and it is about 11 1/2 with muffler. I don't have an LA, but both the RC Report review and Tower website give the LA weight at a little over 12 oz. I've never heard of anything close to a 3 oz. weight difference. Power seems to be about the same, meaning not much
I might dieselize my 40 FP. It's an easy starting glow engine but I have smaller engines that are more powerful. It would be more useful swinging a large prop on something big and slow.
Jim
Hide Signatures
       Post #: 14
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/21/2010 8:11 PM
DeviousDave
Score: 110
Status: offline
Any of the FP series are better than the LA's that replaced them. Terrible decision on the part of OS-I won't buy any of the LA's.
Hide Signatures
(in reply to buzzard bait)
       Post #: 15
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/22/2010 2:06 AM
Hobbsy
Score: 650
Status: offline
Why, I have two LA .46s and perfect is about the only way to describe them, one is wearing a Davis head In the picture it is turning a Graupner 12x7 at 9,450. Since that picture I have added a Bissson Pitts muffler, if it follows the Webra .50 conversion it will turn the 12x7 about 400 rpm faster with the Pitts muffler. I'll have to do that.
Click for fullsize
Hide Signatures
(in reply to DeviousDave)
       Post #: 16
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/22/2010 2:13 AM
Hobbsy
Score: 650
Status: offline
Martin Congratulations on the retirement, Enjoy, you made Geri's day when I told her that.
Hide Signatures
(in reply to AMB)
       Post #: 17
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 3/22/2010 8:48 AM
Recycled Flyer
Score: 101
Status: offline
quote:
ORIGINAL: DeviousDave
Um, better in what way?
Hide Signatures
       Post #: 18
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 2/19/2012 5:29 AM
fiery
Score: 100
Status: offline
My OS FP .40 with RJL Diesel Head and Mac's Muffler. Pictured spinning a Taipan 10x6 prop at 12,000 RPM.
The RJL head is very nicely made and the engine throttles well.
Click for fullsize
Hide Signatures
       Post #: 19
RE: OS FP.40 with a MECOA K&B RJL Diesel Head - 2/19/2012 3:29 PM
Jim Thomerson
Score: 160
Status: offline
I have flown a Tower 40 with RJL head on an Old Time Stunt CL airplane, and had good luck with it up to a point. I had two problems. First, I went through four crankshafts. I think because I insisted on running a heavy hub. I converted back to glow and flew many, many flights with no heavy hub problem. The other problem is, perhaps, more relevant. The airplane is flying along, and all of a sudden the engine overcompresses and stops. The shelf under the O-ring on the contrapiston had come off and was stuck to the top of the piston. No damage to the engine. I designed a slightly modified contrapiston, with a thicker shelf, and the late Gene Hempel made it for me. Worked fine.
Hide Signatures
(in reply to fiery)
       Post #: 20
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> OS FP.40 with a MECOA K&B RJL Diesel Head
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.579RCU1
