SPAD Boat !
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> SPAD Boat !
Page: <<   < prev  1 2 [3]
Login
SPAD Boat ! - 8/7/2003 6:22:04 AM
mikenlapaz
Status: offline
very nice. Curious to see the standing and running rigging.
_____________________________
''A government big enough to give you everything you want, is big enough to take away everything you have.'' Thomas Jefferso
(in reply to Kon-Tiki)
       Post #: 51
SPAD Boat ! - 8/7/2003 6:29:43 PM
Kon-Tiki
Status: offline
Just fitted the middle deck, Sail Arm Servo etc. Still a few things to work out. Then take a picture or two . . . . . .
Steve Carey/G4MJW
http://www.kon-tiki.freeserve.co.uk
       Post #: 52
SPAD Polynesian Catamaran - nearly finished! - 8/10/2003 7:48:46 PM
Kon-Tiki
Status: offline
Just the Cabin module to make, Hatch tops and Jib sail:
http://www.skylites.freeserve.co.uk/kon-tiki/
I fancy making a "Pirate Ship" version next!
Steve Carey/G4MJW
       Post #: 53
SPAD Boat ! - 8/11/2003 2:38:06 AM
Woodsy
Status: offline
Looks great steve, pity the polynesians didnt have a coro farm
"If it's stuck.......... force it. If it breaks it needed replacing anyway"
www.nex.net.au/users/rwood
       Post #: 54
SPAD Boat ! - 8/11/2003 5:56:16 AM
MalaysianFlyer
Status: offline
Skylites, really looks good, can't wait to see it sailing.
YOU are a GENIUS!!!!
       Post #: 55
. . . . Launch day very close! - 8/18/2003 1:58:46 PM
Kon-Tiki
Status: offline
Checked out all the radio gear this weekend BUT it's apparent that the "Standard" Servo is NOT Man enough as a Sail Arm Servo. Didn't expect it to cope. It blew a gale here, first strong winds since before I started building Kon Tiki. I could position the sails in a breeze but in the gusts, the servo arm swung round out of control. Anyway, the geometry is correct so not a wasted exercise. There are a couple of "Monster" Servo's on eBay, so hopefully Kon Tiki will get Her maiden voyage this coming weekend!
Click to see fullsize image.
Click for fullsize
Steve Carey/G4MJW
       Post #: 56
New Kon Tiki website . . . - 8/18/2003 2:08:41 PM
Kon-Tiki
Status: offline
I've moved my Kon Tiki website to:
http://www.kon-tiki.freeserve.co.uk/
Steve Carey/G4MJW
       Post #: 57
. . . Sail Handling - 8/22/2003 3:29:56 AM
Kon-Tiki
Status: offline
After much experimenting and testing, this is how I am controlling the Sails.
A standard Servo is no where near powerful enough, so I have picked up a CS-650 BB FET Jumbo Servo 20kg (44lbs) torque on eBay for $35! However, this is a bit of an "over-kill" !
(A have a better quality image on my Kon Tiki website)
Click for fullsize
Steve Carey/G4MJW
       Post #: 58
Sail Winch - 9/1/2003 11:48:05 PM
Kon-Tiki
Status: offline
Still waiting for blocks to arrive . . . . can't wait any longer! I've now set up the "Sail Winch" and used "Brass Eyelets" in place of pulley's/blocks. The drag is actually very low. The JUMBO servo could move a house.
Grand Launch is on Wednesday!
Click for fullsize
Steve Carey/G4MJW
       Post #: 59
Sail Winch . . . . - 9/1/2003 11:49:54 PM
Kon-Tiki
Status: offline
Close up showing mainsail sheet
Click for fullsize
Steve Carey/G4MJW
       Post #: 60
SPAD Boat ! - 9/2/2003 12:08:03 AM
mikenlapaz
Status: offline
When is your summer season over? Will you sail this inland waters? Looking Good!
       Post #: 61
SPAD Boat ! - 9/2/2003 4:14:58 AM
Kon-Tiki
Status: offline
Summer is coming to an end, already. A few weeks ago, the sky was blue and daily temps reached an all time record for the UK of 100°F. It's barely 65-70 at the moment and dropping daily.
Just 7 miles from here is a town called Maldon, which is on the river Blackwater. There is a dedicated Model Boating Lake. It is salwater, so would rarely freeze in winter.
http://www.kon-tiki.freeserve.co.uk/lake.htm
Steve Carey/G4MJW
       Post #: 62
Kon Tiki SAILS . . . . . - 9/6/2003 4:22:47 AM
Kon-Tiki
Status: offline
Today was launch day. Kon Tiki sails very well, infact Her performance is excellent!
Few slight problems requiring modifications:
Kon Tiki turns very slowly. The Rudder surface area is too small. Rudder Needs increasing by 50%.
The 3 halyards are of thin yacht rope of the non-pre-stretched variety. The sail geometry completely changes with high wind loading. Need to be replaced with cycle brake wire or pre-stretched rope.
Kon Tiki although a large boat, is very light in weight. Perhaps too light. In strong winds she still sail straight and with little or no tendency to capsize. However She want to nose dive into the water thus bringing the aft end out high and also with little rudder left in the water. Reluctantly, I will try adding some ballast. None was actually require to trim her as she sits perfectly in the water.
Any suggestions on this point will be most welcome.
Latest updates:
Click for fullsize
Steve Carey/G4MJW
       Post #: 63
SPAD Boat ! - 9/6/2003 9:15:01 AM
mikenlapaz
Status: offline
Well now you know where to stow the rum!!!
You might try to find some Spyderwire(kevlar) fishing line to upgrade those stretching halyards. Yeah not tradional but no weight and no windage; (#6 mono diameter for 50# break rating)
cantilever or balanced rudder for keeping the tiller loads down?????
keep fine tuning looks good!
       Post #: 64
RE: Kon Tiki Cabin . . . . - 9/22/2003 10:06:32 PM
