Hal deBolt
Joined: 4/12/2002 From: Sun City, FL, USA Status: offline
Hi Ollie, Good to have your input, we must have got your attention! Of course there is a lot more to a biplane force arrangement than surface incidences, wing vertical spacing is important, stagger helps in this regard. I did a lot of experiementing and development of bipes many years ago. Reason was equipment weight and wing loading, a reed system wieghed 1 1/2 lbs, needed slow flight so could not overpower, only answer left was a low wing loading. A bipe was found to fit the bill, could be compact and still have much area. Memory has faded as to source, could have been NACA. But info is still clear. For max efficency wing spacing was to be 1 1/2 chords. If stagger was 50% of chord width. spacing could be reduced to 1 chord width. Above assumes equal size wings. A dixtinct advantage was found with what I called "2/3 bipes" The basic aircraft was a cabin style monoplane of sufficent size to perform well. A lower wing 2/3 the size of the upper was added. Airfoils were NACA 65012s The lower wing was set at zero incidence so drag would be minimum in level flight. When the angle of attack was changed the lower wing went to work improving performance. Stagger was 50% of top chord, clearance was 1 bottom chord width. Basically a high wing the top wing was set at a "good" angle 2 deg. Horisontal tail was 20% of top wing area. Tail moment arm was 40% of top span. The last paragraph of your input was right on, the final verdict always comes with flight testing, very much so with full scale. Testing found the proper lift proportion to have level flight over a wide speed range required 3 deg. positive in horizontal tail With time this arrangement repeated well with several varieties of bipes and proved good enough to place high in the World R/C Chanpionship. There also is a unusual story in this regard, Designer Steen had put a major effort into his "Skybolt" biplane and evaluation flights revealed much to be desired. We had a fine mutual friend who suggested what I did worked very well in a model, why not give it a try? He did that and found he now had a lovely flying machine. Sometimes we modelers can be of assistance? OK? Do keep up the fine effort! Hal deBolt
_____________________________
hal deBolt
