amcross
IL, USA Status: offline
One of my favorite common questions, so i figured i'd get it out of the way early.... The G2300 sets up a little differently from smaller or larger Tigres. (Please remember we are solely the US distributor. If you are outside the US, you may wish to contact the ST distributor in your region of the world, as your choices of fuel/plug, etc may affect its performance.) First, the engine needs to be lean on top, as lean as you can possibly go without detonation. Second, the engine needs to idle low...below 2500 and preferably in the 2000 or less range. Third, the engine MUST be fed high quality high oil (18%+, at least partially castor) fuel. t will run on FAI fuel but prefers nitro in the 5-25% range. This sport engine performs fabulously under these conditions for most sport pilots. It is a real powerhouse and work horse of a sport engine. However, this reasonably price sport-performance engine is not designed or able to perform for extended lengths of time in the 2500-4000 range. If you choose to ask it to do so, you must come back to idle prior to applying full throttle to clear the carburetor, *OR* supply the engine with significantly higher fuel delivery pressure by utilizing a high volume pump such as a *Varsane Perry VP30 Regulating Pump* while also using muffler pressure. (Please see note below on pump set up requirements.) If the above steps do not resolve your concerns, then look to the muffler you are running. Fuel flow is a key concern of this engine, requiring good pressure to the fuel tank. In order to increase muffler pressure to the fuel tank, a twin exhaust outlet muffler needs to have the second stack partially or completely blocked. The same is true of exhaust systems made by other vendors, such as Bisson, or Slimline. We've had excellent results using a SuperTigre "Silent Muffler" for the S-2000/2500, although it's a bit large, and doesn't hide at all well inside engine cowlings. PUMP SET UP INSTRUCTIONS: The pump should be adjusted to leave only a 1/32" gap. keep the presure line as short as possible. Set the pump first DO NOT set your carb and try to match the pump to the carb. Use exhaust presure with the pump. Sincerely, Great Planes Model Distributors [email]productsupport@greatplanes.com[/email] [url]www.greatplanes.com[/url] [url]www.bestrc.com[/url] Phone: (217) 398-8970 Fax: (217) 398-7721
< Message edited by Bax -- Feb 21 2003 10:34PM >
