Futaba 9C and also cool tx cases
Tower Hobbies
Logged in as Guest
  Printable Version
Futaba 6EX w/2.4GHz FASST System - ARF
Seller:  pickelboy
Details:   $350.00   |  11/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Futaba 9C and also cool tx cases
Page: <<   < prev  1 [2] 3   next >   >>
Login
Futaba 9C and also cool tx cases - 4/15/2002 9:36:10 AM
hawkpilot
Status: offline
ok....I got my case form Home Depot, now where can I find some thick foam?
_____________________________
Pat
(in reply to hawkpilot)
       Post #: 26
Futaba 9C and also cool tx cases - 4/15/2002 12:11:27 PM
dgrant
Status: offline
You might try a larger craft store in your area. I don't use foam, I used the provided dividers, and set them up to closely hold the transmitter(s). The leather top tool holder in mine is cushy enough to hold things snug. I'm the only one that handles my case, and it's always handled with great care anyways. If your in need of added security of foam-rubber though, do try craft store.
       Post #: 27
Futaba 9C and also cool tx cases - 4/15/2002 1:28:54 PM
hawkpilot
Status: offline
Thanks, Dale! I will have to check into that. It would be nice to have that added little sense of security.
Pat
       Post #: 28
Futaba 9C and also cool tx cases - 4/16/2002 8:43:38 AM
Volfy
Status: offline
I got a bunch of these surplus cases made for Texas Instruments at a local Electronics Parts Outlet store for $7.95 each. I couldn't ask for a better fit, and didn't have to cut any foam either.
Click to see fullsize image.
Click for fullsize
< Message edited by Volfy-RCU -- Apr 16 2002 3:29PM >
       Post #: 29
Futaba 9C and also cool tx cases - 4/16/2002 11:47:56 AM
dgrant
Status: offline
No prob Pat...now I'm thinking a little more secure won't hurt too. I better add a touch of foam too. Thanks, for the "awareness". I've never had any problem, but "murphy's law" could catch up to me. I sure wouldn't want it to be with my 9C though. I might just pick up another case dedicated strictly to the 9C. I only have one, and store my transmitters in a very safe cabinet at home, and just draw from them as I need. I think I'm going to store my 9C permanently in a new case though.
       Post #: 30
Picture of the case from Lowe's - 4/16/2002 6:45:28 PM
bkf
Status: offline
Picture of the case from Lowe's.
$24 here in NY
Bkf
< Message edited by bkf -- Apr 22 2002 11:34AM >
       Post #: 31
Futaba 9C and also cool tx cases - 4/16/2002 8:24:57 PM
Volfy
Status: offline
bkf, I notice you put the TXs into the case with the antenna pointing to the bottom of the case. You might just have set them that way for quick photo illustration, but I've had to remind myself many times not to put mine in like that.
It probably isn't critical if you have tight fitting foam, but I still think TXs are more shock resistant when carried "right side up".
       Post #: 32
Case. - 4/16/2002 8:56:00 PM
hawkpilot
Status: offline
Dale, Im thinking about buying a few more of them myself, Murphy likes to stay on my tail. This is an awesome case for only $20!!! Makes it easy to justify buying one for each trans. I built a big plano field box and the case's feet fit into the grooves on top of the box like it was made for it. Im glad you gave me the tip on where to find it.
Pat
       Post #: 33
Hey BK!! - 4/16/2002 8:59:32 PM
hawkpilot
Status: offline
Your case looks pretty cool to. Where did you get your grey foam? I havent had a chance to get to the new Lowes yet to see if they have the case too. It looks very similar to the case that Dale and I have.
Pat
       Post #: 34
Futaba 9C and also cool tx cases - 4/16/2002 10:16:00 PM
bkf
Status: offline
I just got this case today after reading you guys thread here. The foam comes inside allready. Thanks for the heads up. Bkf
       Post #: 35
the spending never slows down - 4/16/2002 11:42:10 PM
hawkpilot
Status: offline
BK, is the foam removeable. or glued in? I like the rounded looks of that case. Since it comes with foam, now I am going to have to buy one of those too, :
Pat
       Post #: 36
Futaba 9C and also cool tx cases - 4/16/2002 11:45:57 PM
bkf
Status: offline
The bottom foam is cut into those 1/2" squares that you pull out to form your cutouts. The top foam is one piece of the bubble / pointed type to cover the knobs and such if you want to. Comes with some of those dividers and a strap as seen in the picture.
       Post #: 37
Futaba 9C and also cool tx cases - 4/16/2002 11:50:16 PM
hawkpilot
Status: offline
I didnt notice the strap before... SWEEEEET!!!!! OK now I definitely have to get one
Pat
       Post #: 38
Futaba 9C and also cool tx cases - 4/17/2002 12:11:33 AM
hilleyja
Status: offline
Anyone that has ever gone to a sizable fly-in could tell you that Lowe's aluminum tool case (Guardforce, VGC-5200) is very popular at most fields. They normally sell for ~$24.96.
The same case with an RC brand, like Tower Hobbies, sells for more than $44.99. (http://www2.towerhobbies.com/cgi-bin/wti0001p.pgm?Q=1&I=LXL376&P=7)
Watch out for eBay -- they cater to the uninformed. E.G., Harbor Freight's Mini Cutt-off saw sells for around $42.00 on eBay. You can buy them every day from Harobor Freight for $29.99.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42307
http://www.lowes.com/lkn?action=productDetail&productId=24981-000010203-VGC-5200
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
       Post #: 39
Foam - 4/17/2002 10:19:43 AM
hawkpilot
Status: offline
I went to JoAnne fabrics and got my foam. This junk is expensive. I bought the cheap stuff and it was $13.50/yd.
Went by the new Lowes, but it doesnt open till May 1st. I am going to get the case from there strictly for my 9c.
Pat
       Post #: 40
Futaba 9C and also cool tx cases - 4/17/2002 12:41:41 PM
bkf
Status: offline
[QUOTE]Originally posted by Volfy
[/QUOTE]
Good point sir. In that picture I just set them in for scale. Thanks Bkf
       Post #: 41
TX Case - 4/22/2002 3:13:17 AM
PhantomPhreak
Status: offline
I just bought the aluminum case from Lowes for $24.99 and let me say it is worth the money!--Carrying strap, locks, and plenty of room. I currently fly with a
