tail boom removal on CPV3    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> tail boom removal on CPV3
Page: [1]
Login
tail boom removal on CPV3 - 3/17/2010 3:16 AM
snobelt
Score: 100
Last Login: 2/9/2013
Status: offline
I have removed the four screws on the frame and the boom still won't budge. Even a pliers won't turn it - it just wants to crush the tube. It must be glued in. How do I get it out without destroying the frame? Thanks.
Hide Signatures
       Post #: 1
RE: tail boom removal on CPV3 - 3/17/2010 3:46 AM
dragus359
Score: 105
Last Login: 5/14/2013
Status: offline
Hopefully someone else has better advice, but when I did it, I used regular pliers (not needle-nose). I placed the tube in the oval-ish region of the piers, and moved the pliers as close to the tail boom clamp as possible. I then closed the pliers around the tube so that the "teeth" in the oval region would clamp down, and that caused a slight depression of that region on the tube. Having done this as well as having loosened the screws, the oval region of the pliers had enough grip to allow me to twist off the tail boom. I do believe I was able to continue using the tail boom afterwards; however I had to replace it after a violent crash. Anyway, this is probably the easiest way to take the tail boom off, but doing it this way will leave a dent and some scratches on your tail boom.
_____________________________
For all my flying videos, go to: http://www.youtube.com/user/dragus359
Hide Signatures
(in reply to snobelt)
       Post #: 2
RE: tail boom removal on CPV3 - 3/19/2010 4:52 AM
snobelt
Score: 100
Status: offline
Dragus - Okay, thanks for the response. I didn't try to twist very hard. I was worried the frame might break but since it worked for you - what the heck. The existing boom is only slightly bent (no kinks) and as long as it still works I think I'll use it. But if I ever need to replace it, now I know how - just force it. I've had the CP for a year and have not had a bad crash (yet) but I intend to push it a bit this summer. I've been on the sim for two years and still haven't had the guts to really wring out this heli. So here goes nothing. I'll probably be asking for lots of repair advice in the future.
Hide Signatures
(in reply to dragus359)
       Post #: 3
RE: tail boom removal on CPV3 - 3/19/2010 5:02 AM
dragus359
Score: 105
Status: offline
No problem. Be sure to exercise caution when forcing things, and you should be fine.
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.234RCU1
